Ground bond test when no ground is accessible
ale_pb
Hello.
I have a medical equipment which is like a bathtub and its only part that is under voltage is a motor.
This motor comes from the supplier attached with the power supply cable (which is also the supply cable of my equipment). This motor is covered by a plastic material, so I don`t have access to its metal cage.
The doubt is: How can I do the ground bond test is my equipment if the only part which is grounded is the motor but it has a plastic cover all around?
Is the test necessary in this case?
Thanks in advance.
Peter Selvey
In design phase (and in third party testing) you will need to pull apart and test the internal earthed parts accordingly. This is mandatory if the earthed parts have only basic insulation (1 MOP) to mains parts.
In production it is expected also to have an earth resistance test. It would make sense to have the test prior to adding the plastic case. If the motor is supplied with the case, ask the motor supplier for evidence of a production earthing resistance test.
If the part is certified by a recognized agency, you can reasonably assume that both of these are already done (design and production tests), although it might be best to check the paperwork (test reports, requested production tests) to be sure.
BradM
Just to add a bit to Peter's excellent response....
When I am performing grounding/ bonding tests, I always perform resistance verifications to anything that could conduct electricity. So I will verify resistance from the grounded conductor from the power connection cable to the motor, motor mount, and anything else which is connected to assure it is effectively grounded. While the motor casing (which you stated is made of plastic) might not be conductive (thus not requiring a ground) other parts of the connected system are possibly conductive.
Also, even though the motor housing is plastic, generally there are metal screws/fasteners that connect the housing to the motor; and these are generally intimate with the motor. So if you cannot remove the plastic housing to verify to the motor, you could (aside from evidence received from the mfg.) verify that the metal components are bonded.
A IEC 60601 Ground Bond Test Requirements for a Plastic Enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Ground stud requirements on our medical device in IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
J Bees or Hornets Nesting in the Ground Coffee Break and Water Cooler Discussions 28
somashekar Mangoes ground Air India flight ~~~ Travel - Hotels, Motels, Planes and Trains 1
G How many Airbus A380 planes must blow Rolls-Royce motors to ground the fleet? Coffee Break and Water Cooler Discussions 36
apestate Ground Tooling produced from OEM Blueprints - Part 21? Of WHAT? Federal Aviation Administration (FAA) Standards and Requirements 9
W Sunday Business Systems Ground Control? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C How long does it take to clear back ground checking? Career and Occupation Discussions 7
J ISAGO - IATA Safety Audit for Ground Operations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
C Applicability of AS9100 to Aircraft Ground Support Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D Aeronautical regulations JAR145, JAR21G - Aircraft ground handling AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Paint booth prints - Painters using them as ?ground cloth? after the job is shipped Document Control Systems, Procedures, Forms and Templates 2
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
E Composites - Metal Bond - Removal of excess film adhesive Manufacturing and Related Processes 1
Z My first Gage R&R - Paper/Poly/Foil Material Bond Test, need help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
R How to bond PVC (Tygon) Tubing and Validate the Process ISO 13485:2016 - Medical Device Quality Management Systems 13
A Adhesive Longevity Tests - Glued Silicone used in a Shower to Bond Glass Panels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Any adhesive needed for PVC and PC natural bond? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Babbetting of Bearings - Improper bond between the Bearing shell and the Babbett Manufacturing and Related Processes 5
Marc S&P cuts both Ford and GM's bond ratings to Junk status World News 10
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
