Ground stud requirements on our medical device in IEC 60601
mouse7
Hi all, appreciate your clarification on this point.
I cannot find a requirement for a ground stud on our medical device in 60601. Our chassis is plastic, do we need to add a ground stud just for testing purposes?
If we don't have a ground stud, how will leakage tests be conducted?
Thanks!
Medical electrical equipment (MEE) may be Class II - double insulated. As such they would not have a 'Protective Earth' and would not be fitted with a ground stud.
(MEE for home healthcare settings is required to be Class II).
To measure leakage currents - for enclosure leakage (Touch Current) the measurement is taken between ground and foil applied to the outside of the enclosure. The size of the foil represents an adult open hand (or bigger if risk analysis demands). The foil is moved around the enclosure to find the 'worst case' positioning.
Internally powered MEE is not tested for Touch Current unless you have SIP/SOP.
The other tests are done in similar ways - using foil on the outside of the enclosure or insulated applied parts.
phase90
Along the same lines, if you have a product that is Class I with a plastic enclosure, does it need a ground stud?
Assuming that you are thinking of an external ground stud, then I would suggest that, no you do not have to have one.
However, electrical equipment, especially medical devices, are routinely tested often by a hospitals own engineering / equipment management service. A key test that they will try to do is earth bond integrity. If they cannot find a suitable earth point they may attempt to use something like the metal shell of a connector. As this test is usually done with 25 amps of current it would likely cause damage if that current was passed through unsuitable conductors, such as a PCB trace.
But if you provide an external earth point, with strong bonding then the test is easy to complete and no damage is caused.
As with just about everything in this game it's all down to risk analysis.
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
J Bees or Hornets Nesting in the Ground Coffee Break and Water Cooler Discussions 28
A Ground bond test when no ground is accessible IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601 Ground Bond Test Requirements for a Plastic Enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
somashekar Mangoes ground Air India flight ~~~ Travel - Hotels, Motels, Planes and Trains 1
G How many Airbus A380 planes must blow Rolls-Royce motors to ground the fleet? Coffee Break and Water Cooler Discussions 36
apestate Ground Tooling produced from OEM Blueprints - Part 21? Of WHAT? Federal Aviation Administration (FAA) Standards and Requirements 9
W Sunday Business Systems Ground Control? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C How long does it take to clear back ground checking? Career and Occupation Discussions 7
J ISAGO - IATA Safety Audit for Ground Operations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
C Applicability of AS9100 to Aircraft Ground Support Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D Aeronautical regulations JAR145, JAR21G - Aircraft ground handling AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Paint booth prints - Painters using them as ?ground cloth? after the job is shipped Document Control Systems, Procedures, Forms and Templates 2
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
H What does the abbreviation for ?POAG? terminal/stud stand for? Manufacturing and Related Processes 3
J Screw Thread Inspection Standards? Double Ended Stud Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
CarolX I am looking for some information on stud welding Manufacturing and Related Processes 28
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
P Requirements for being an European Representative EU Medical Device Regulations 3
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
A GPS Regulatory requirements? Manufacturing and Related Processes 6
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V MDSAP Requirements for Device Designer Canada Medical Device Regulations 1
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
S What are the International Forging Requirements for Nitrogen Strengthened Stainless Steel? EU Medical Device Regulations 3
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
S Distributor requirements in US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K AS9100D 8.2.1 Review Requirements for Products and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
F Environmental Requirements E-Lab General Measurement Device and Calibration Topics 0
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Composites - Freezer sensor requirements Manufacturing and Related Processes 2
A Requirements for Contract Manufacturers Other Medical Device and Orthopedic Related Topics 3
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
