GRR based on part tolerance or process variation.
tongxiaozhi
Dear quality experts:
Can anybody kindly clarify the following content from MSA Fourth edition. Also, we have a molded plastic part with only 1 cavity. The dimesion between the parts are very close, so the process variation is also close to 0, which makes it impossible for GRR to be less than 10%, how to deal with this kind of situation? Many thanks in advance.
For Product Control situations where the measurement result and
decision criteria determine, “conformance or nonconformance to
the feature specification” (i.e., 100% inspection or sampling),
samples (or standards) must be selected, but need not cover the
entire process range. The assessment of the measurement system
is based on the feature tolerance (i.e., %GRR to TOLERANCE).
For Process Control situations where the measurement result and
decision criteria determine, “process stability, direction and
compliance with the natural process variation” (i.e., SPC, process
monitoring, capability, and process improvement), the availability of
samples over the entire operating range becomes very important.
An independent estimate of process variation (process capability
study) is recommended when assessing the adequacy of the
measurement system for process control (i.e., %GRR to process
variation).
GRP
In order to calculate the process index (Ppk/Cpk) you use the results of a measurement system. This means the index is affected both by the real variation between parts and the variation of the measurement process. Your actual index will always be better than the calculated because your measurement system variation will never be 0.
If you had a process with Ppk=Cpk=2.0 and you had not performed a GRR, you could argue that both your process and measurement system are good, but you will not know if the actual process index is 10 and this low variation is masked by the measurement variation.
In practical terms, if you need a GRR for submission to your client in order to determine that your measurement system is suitable for a certain characteristic, then use the GRR as a % of tolerance.
Additionally, if you feed your GRR parts with very little variation you will fail your ndc. Omitting for the moment the many sound rebukes of the MSA by Dr Wheeler, just inject a few parts with lower holding pressure, change the tool temperature, increase and reduce cooling time and get parts with variation spanning the entire range of tolerance.
In cases when I needed the GRR and for practical reasons I could not inject parts with different parameters I have gone as far as deforming parts (with engineering judgement) to obtain the required variation for the feature.
tongxiaozhi
Many thanks for your professtional answers. You also have good knowledge of injection process. I fully agree with you, more and more I feel that GRR is like Emperor's new clothes.
tongxiaozhi
To be honest, for injeciton mould, we had to manipulate the data in order to make GRR and ndc compliant. The dimension of molded parts are quite close, even between cavities. I don't see much value in this tool.
GRP
For me the GRR is a necessary tool. There are some nice threads to read in the Cove about honest GRR and also Miner´s blog on MSA
tongxiaozhi
Thanks for your answer. My knowledge of GRR is quite limited although I have read the mannual of 4th edition several times. Probably I jumped to conclusions that it is not useful. I will try to find more informaiton. I would appreciate it if you could share more of knowedge with me.
GRP
The reason why I say GRR is necessary can be supported with a quick example: once I had a medium-sized plastic part that required a measurement fixture. I had to prove capability to the client or measure 100%. The measurements were really off. So what was the problem, the part/process or the measurements? Long story short, the measurements. I had to chase the fixture supplier throughout 12 weeks of redesigns and tweaks until the measurements were OK. This definition could not have been made without a bias study and a GRR.
The GRR is just one of all the tools described in the MSA. You will find many useful threads in the Cove by searching for GRR, and also here https://elsmar.com/elsmarqualityforum/resources/miners-msa-blog-series.1/
Try to use software like Minitab and be wary of templates found around the net.
Stick to the ANOVA method in preference of X-bar and range.
Dave Cx
If you are not getting an acceptable NDC then trying using components with a greater variation, but this isn't so easy with mouldings. What I would suggest is keeping mouldings from the different tool tuning loops which you know have variation to get 'range'. Its only when you see the actual results of repeatedly measuring the same component that you can appreciate the MSA
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Evaluating GRR Scores %Tol vs %TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q What does % study variation of 20% mean in GRR? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
V GRR Study on a Finished Product - Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Hypothesis test for Bias, not for GRR. WHY ?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P New Part - How to choose what needs GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K The basics of GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Need MSA %GRR Interpretation Advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GRR approach for off line Measuring Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
T MSA - Should I compare my GRR to tolerance or to my sample? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D What the impact is of a high %GRR/TV Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F GRR (Gage R&R) with Different Scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Type 1 GRR (Gage R&R) on a One Sided Specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Analysis of GRR studies, MSA 4th Ed, Chapter III section B - Rigid Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R ndc=0 and GRR=14% ??? Interpretation - basic question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
Rameshwar25 What is the significance of Spread in Calculating GRR (Gage R&R)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
J CMM MSA - Can you use 1 GRR to satisfy requirement for all Key Features? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Minitab Type 1 Repeatability & GRR% of Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Cp calculation on page 193 of the MSA 3rd edition May 2003 with %GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L %GRR/TV or /TW for GRR of One Sided Specification - Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D GRR (Gage R&R) procedure for Mitutoyo Digital Micrometer wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T % Gage R&R Calculation - 100x(GRR/ (Spec/6)) or 100x(GRR/TV) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
O The Basis of %GRR (% Gage R&R) and other Statistics - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
A Effect of %GRR (% Gage R&R) on Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F GRR (Gage R&R aka GR&R) on Laser Gages for Plastic Extrusion Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
