GRR for a tolerance that has changed
Hi Everyone,
We performed a GRR for a part for a tolerance +/- 0.5 and passed. Now we changed the tolerance to +/-0.6mm. Should I redo or can I keep with the same result of GRR?
All comments are really important.
Cheers,
Luci
Welshwizard
Hi Lucienne,
Assuming that the tolerance change didn't also involve any change to the manufacturing process or the behaviour of approaching the new tolerance then widening the tolerance width will impact the % tolerance in a positive way if you measure your success by pass or fail.
You can, bearing all the above in mind and for the sake of completeness recompute the numbers with your new tolerance band if you wish but you shouldn't need to redo the test again.
Sebastian
Very good question. Answer relies on your organizational MSA strategy.
Strategy, which can be presented in one of documents required by IATF 16949 - laboratory scope.
In section 7.1.5.3.1 we read, that in this document, we shall identify our capabilities to perform required inspection activities.
So we have measurement systems, that need to be verified using analytical methods, e.g. presented in MSA manual as required by 7.1.5.1.1
Every measurement system has variables.
Let's say, there are at least three variables - equipment, inspected characteristic and characteristic specification or process variation.
This is a basic example.
In your case measurement system consisted of unidentified measuring gauge, unidentified characteristic and characteristic specification +/- 0,5 mm.
MSA result was satisfactory and you can transfer it to your laboratory scope descriptively stating, that "Measuring system consisting of "this" gauge, "this" characteristic and characteristic specification >= +/- 0,5 mm is capable to deliver valid inspection results." Or you can present it in form of table, with following columns: "Equipment", "Characteristic", "Specification".
Then every new/changed measuring system, that meets these criteria is automatically capable and does not require further verification.
Next steps can be searching for this particular measuring system boundaries, asking "What if specification is +/- 0,4 mm? Does a system is still capable?"
You can add another variables (column to above table), as e.g. material part is made of. There is significant difference between measuring with a caliper, internal diameter of part made, one from steel and another one from rubber, where specification for both is +/- 0,15 mm.
Another one could be part weight.
Ron Rompen
I agree with Welshwizard, and have done the same in the past. If the tolerance is changed (either larger or smaller) just rerun the study using your original measured values, and the new tolerance. As long as nothing else has changed (measurement method, manufacturing method, etc) then this should be sufficient.
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
T MSA - Should I compare my GRR to tolerance or to my sample? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M Minitab Type 1 Repeatability & GRR% of Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Evaluating GRR Scores %Tol vs %TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q What does % study variation of 20% mean in GRR? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
V GRR Study on a Finished Product - Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Hypothesis test for Bias, not for GRR. WHY ?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P New Part - How to choose what needs GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K The basics of GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Need MSA %GRR Interpretation Advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GRR approach for off line Measuring Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What the impact is of a high %GRR/TV Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F GRR (Gage R&R) with Different Scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Type 1 GRR (Gage R&R) on a One Sided Specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Analysis of GRR studies, MSA 4th Ed, Chapter III section B - Rigid Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R ndc=0 and GRR=14% ??? Interpretation - basic question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
Rameshwar25 What is the significance of Spread in Calculating GRR (Gage R&R)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
J CMM MSA - Can you use 1 GRR to satisfy requirement for all Key Features? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Cp calculation on page 193 of the MSA 3rd edition May 2003 with %GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L %GRR/TV or /TW for GRR of One Sided Specification - Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D GRR (Gage R&R) procedure for Mitutoyo Digital Micrometer wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T % Gage R&R Calculation - 100x(GRR/ (Spec/6)) or 100x(GRR/TV) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
O The Basis of %GRR (% Gage R&R) and other Statistics - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
A Effect of %GRR (% Gage R&R) on Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
