GUDID Packaging - Two part package
Pmarszal
Our company is in the process of creating GUDID submissions to an "unpublished" state and had a questions about a packaging.
We currently have a individual "part" that is also packaged into a "part" pack of 2. The 2-pack in our system is assigned a different catalog number then the individual part.
My initial though was to create the 2-pack as a "Package DI" but am second questioning if this is the correct way to assign this. I have also tried to assign the "device count" of 2 and insert the unit of use "DI number" (of the individual part) to the record but record review notes that I cannot use an already used DI number for this.
Your help would be greatly appreciated and am thanking you in advance for reviewing my technical question.
Q
QA-Man
Re: GUDID: Packaging Question
Don't use the unit of use DI in GUDID (I'm assuming you're using web interface)
Enter the unit of use in the primary DI and then make the device count 1. You'll see unit of use is then "greyed out". The primary DI will the act as your unit of use.
You can then add whatever packaging DI's you want, including those that contain only one 1 of the primary DI.
Pmarszal
Thanks QA-Man!
So just to verify your recommendation: Im using Web User Interface.
Create a DI record for the base package of a single pin (qty.1) which has a catalog number.
Add the Package DI for the qty of 2, even though the Package DI has its own catalog number in our system and will be labeled with that catalog number?
Again, I am appreciative of all recommendations as we are down to crunch time soon :)
Q
QA-Man
Re: Question on GUDID
If you're worried about identifying the catalog number, you can put it under the Package Type field.
I had a similar situation where two different catalog numbers were using the same unit of use. I put "Box (XXXX)" and "Box (YYYY)", where XXXX or YYYY is the catalog number, in the Package Type field.
Pmarszal
QA Man!
I appreciate all your help and will take your advice and create it as a Package ID.
Another question you might be familiar with:
Our single use device contains MDD symbols on labels and these are then packaged into a box of 5 to ship to customer/hospital etc. UDI and GUDID guidance specifies that all non-variable information needs to be on the 5-pack label and am guessing this is implying UDI information ONLY and not symbols and all other information that is on the single label.
You have provided great advice to our company as I have tried contacting the FDA Help Desk with these questions but am sure they are loaded with questions before the deadline and haven't received a response.
Thanks!
Q
QA-Man
Single-use devices don't necessarily need a UDI on the immediate packaging. 21CFR801.30(a)(3) states:
Individual single-use devices, all of a single version or model, that are distributed together in a single device package, intended to be stored in that device package until removed for use, and which are not intended for individual commercial distribution. This exception is not available for any implantable device. The device package containing these individual devices is not excepted from the requirement of 801.20, and must bear a UDI.
I assume MDD is Medical Device Directive It depends upon the symbols and purpose of outer packaging. If it is a CE mark, then I would put it on all packaging levels. If its the "do not use if package is damaged" symbol (ISO 15223-1 5.2.8/ISO 7000 Reg. No 2606), maybe that should just go on the immediate packaging.
The FDA released a final rule on the use of symbol in June here (you may already be aware of this).
A GUDID - Packaging Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J GUDID Labeling and Levels of Packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M GUDID/UDI Packaging and Labeling Questions Other US Medical Device Regulations 6
C GUDID Device record history Medical Device and FDA Regulations and Standards News 2
D How to list multi-product sample pack in GUDID 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M GUDID data deficiency communication - IS THIS A SCAM? ISO 13485:2016 - Medical Device Quality Management Systems 29
S Which department manages Establishment Registration, Device Listing and GUDID? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M FDA News USFDA Proposes to End Temporary Extension of GUDID’s Grace Period Medical Device and FDA Regulations and Standards News 3
M Medical Device News FDA News - 27-08-18 - 2018 Learning program and GUDID updates Other US Medical Device Regulations 0
shimonv Commercialisation challenge related to FURLS & GUDID Other US Medical Device Regulations 0
M GUDID - Change in Quantity Other US Medical Device Regulations 0
Pmarszal Label Printing: Medical Device related UDI Requirements - GUDID Aspects Other US Medical Device Regulations 0
K GUDID / UDI and Company Relocation Other US Medical Device Regulations 3
I Request an FDA GUDID Account - Problems Other US Medical Device Regulations 3
I GUDID listing - Inputting data into the GUDID database Other US Medical Device Regulations 3
bio_subbu USFDA issues final guidance on Global Unique Device Identification Database (GUDID) Other US Medical Device Regulations 1
N Barcode Registration Requirements for Japan and GUDID Japan Medical Device Regulations 2
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
C Packaging Long Parts Manufacturing and Related Processes 3
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
V Packaging in Distributor Practices EU Medical Device Regulations 0
R Green dot required on packaging? Medical Device and FDA Regulations and Standards News 2
shimonv Single lot release for sterile packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
E Latex in packaging Other Medical Device Related Standards 4
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
A Packaging device with accessories already on the market Other Medical Device Regulations World-Wide 0
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Packaging unsterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
M UDI size on packaging EU Medical Device Regulations 3
M UDI placement - Packaging levels EU Medical Device Regulations 2
E Unit Dose Packaging Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
T Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
R Labels on sterile packaging EU Medical Device Regulations 5
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
