Guidance for Transition from ISO9001:2008 to AS9100C
I
Irvingstark
We are registered to ISO9001:2008 and making the transition to AS9100C. We are very early in the process and I am trying to get my head around the requirements for AS9100C.
I understand the holes where I need now to develop/incorporate Risk Managment and FOD procedures.
My question revolves around which becomes the driving document? Is the documented Procedures/Work Instructions/Forms independent within each quality system (ISO and AS)? So when I revise the ISO document, I need to consider the AS impact and revise those as well (if appropriate)?
Any guidance is appreciated, light a candle, do not curse my darkness.
Thanks in advance!
RCW
It depends on what your game plan is and what works best for your company but....
I'm running 3 QMSs (ISO 9001, ISO 13485, & AS9100) at the same time and I try to use the same forms, procedures, work instructions, etc. as much as possible . I feel the more different paths there are to wander down, the more confusion there will be.
Thanks in advance!
I believe you're thinking about this the wrong way - your organization has ONE Quality System. You have, in this case, to meet 2 requirements: ISO 9001 (foundation) and then the "adders" of AS 9100 C.
You shouldn't be thinking of "2 systems". You define and document how your operate your processes and make sure the specifics are catered for. So in the process of dealing with how you control your non-conforming product, you should see in your documented procedure, firstly, the various requirements of identification, segregation, reporting, review, disposition etc (as required by ISO 9001) and then, for aerospace products how you handle the "extra" requirements.
Simples!
I
Irvingstark
Do you number then for each QMS or do you keep them the same number and reference them within the different QMS?
Thanks,
Irv.
I
Irvingstark
The clouds are starting to part...
So just tailor existing documents to meet each standard whether AS9100 or IS9000. The requirements of the standard will be addressed for each QMS within the particular guiding document for the Quality System Procedure, Work Instruction and Forms. Am I on the right path?
Thanks,
Irv.
John Broomfield
Thanks,
Irv.
Irving,
Instead of coding your organizational management system's documents for the standards, do what others did years ago. Code or uniquely identify them for your organization.
You could assign each of them a random number or you could code them to inform users, at a glance, the doc type, owner and issue status along the lines of:
A-B-C(D)
A = Doc Type
B = Dept of Process Owner
C = 01 to 99 for each unique combination of A and B
D = letter for draft or number for a doc that is approved for use (A indicates first draft - review comments requested and 1 indicates first issue for use and improvement.
No procedure should be called an ISO Procedure or a Quality Procedure come to that.
Name your management system for your company and avoid giving the impression that your management system is primarily for certification purposes.
Good luck,
John
John Broomfield
Thanks,
Irv.
Irv,
Most of your procedures should be a result of analyzing the processes needed by your management system for it to be effective. Document these procedures to the extent needed for effective planning, operation and control of these processes and no more.
I take it that you already understand how your organization works as a system and that you have determined the processes needed by your management system for it to be effective.
If not, study clause 4.1 and ask us about any aspect you do not understand.
John
Reg Morrison
I am in full agreement with Andy's comment. You CANT have multiple quality systems. You have 1 QMS that should be exercised in different ways depending on the contract and program requirements. Organizations that still function with multiple quality manuals are extinct. They might not know that yet, but they belong to the prehistoric world of QC.
Further, much more important than deciding document protocols is to understand the process approach. Documents serve no other purpose than to give definition to processes.
As a suggestion, I would encourage you to take the time and read the numerous threads we have on AS9100 transition. There is a lot of knowledge and wisdom captured in those discussions.
Good luck.
T MDR Guidance Book - Useful for MDR transition? EU Medical Device Regulations 1
O Guidance and/or assistance on Transition to AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
D FDA Guidance on Computer Software Assurance versus 21 CFR Part 11 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
N Guidance - Cost of Good Quality Misc. Quality Assurance and Business Systems Related Topics 2
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
M Labelling - Is there a guidance or regulations that specifically defines the 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Guidance for health institutions on in-house manufacture and use UK Medical Device Regulations 1
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
dgrainger Informational MHRA guidance on CE UKNI - Article 5.5 - 2021-02 EU Medical Device Regulations 0
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
A Which guidance do you use for guiding the requirements of IFU for 510(k) submission? Medical Device and FDA Regulations and Standards News 5
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
Aymaneh AAMI TIR45 guidance wanted IEC 62304 - Medical Device Software Life Cycle Processes 4
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
D GMDN code update - Canada - Do you know if there is guidance? Canada Medical Device Regulations 0
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
dgrainger Informational UK guidance on Device regulation from Jan 2021 published UK Medical Device Regulations 19
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
B EU MDR Perscription product guidance EU Medical Device Regulations 1
John Broomfield Guidance on Safe Working During Covid-19 Pandemic Misc. Quality Assurance and Business Systems Related Topics 5
dgrainger Informational UK guidance on FSNs - May 2020 EU Medical Device Regulations 1
dgrainger Informational UK guidance on FSNs - Published 20 May 2020 UK Medical Device Regulations 1
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
dgrainger Informational MHRA guidance update on withdrawal of Notified Bodies Medical Device and FDA Regulations and Standards News 0
M Advertising medical devices in the U.S - Advertising regulations or guidance documents Other US Medical Device Regulations 3
dgrainger Informational MHRA updated guidance: Clinical investigations of medical devices – guidance for manufacturers Medical Device and FDA Regulations and Standards News 0
rob73 MDCG guidance on class 1 devices and MDR EU Medical Device Regulations 0
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
J CEN/TR 17223:2018 Guidance on the relationship between13485 and MDR.. worth the money?? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Informational EU – Ongoing Guidance development within MDCG Subgroups Medical Device and FDA Regulations and Standards News 1
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
D Performance Qualification per GHTF Guidance Other Medical Device Related Standards 12
M Informational EU – Guidance on Qualification and Classification of Software in Regulation (EU) 2017/745 – MDR and Regulation (EU) 2017/746 – IVDR Medical Device and FDA Regulations and Standards News 2
dgrainger Informational MDCG 2019-11: Guidance on Qualification and Classification of Software in Regulation (EU) 2017/745 – MDR and Regulation (EU) 2017/746 – IVDR Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Clinical Decision Support Software Medical Device and FDA Regulations and Standards News 0
M Informational DSVG 04 – Breast Implants – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
