Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer
aramono
It's my first post and before every thing I’m so sorry for my bad English.
I need to develop a SOP for calibration of temperature and pressure of the autoclave's chamber when machine is working (during machine working on) But I didn’t find any guideline to do this.
I read many related standard ( because in time I develop a non complete sop for validation according to EN17665) such as: EN 285, EN 13060, EN 17665, HTM2010, PDA tr no.1,
And also I can’t find the scope that I need, in some temperature calibration standard (that are specially for testing Environmental & climatic chambers) such as IEC 60068 ( I review approx. all parts) afnor nfx 15-140, dkd-r 5-7. Because all of them need to stable condition for temperature recording and also need to calibrate at atmospheric pressure.
Unfortunately the validation process that explained in these standards (EN 285, EN17665) had many critical parameters like how to measuring equilibration time, fluctuation, variances, and more item but didn’t focus how to calibration.
I need to calibrate for example 8 points of sterilizer chamber in 2 temperature points 121C and 134C, and also for pressure.
I need a guideline that explained a procedure for calibration temperature, in pressure about 3300 mbar absolute and also another one to calibration pressure, in 134C.
Thanks for your cooperation.
harry
I'm still waiting for your feedback..
We are sorry, the Cove had been rather quiet because of the year end holiday season so many of those that can help you are not around. I will take a stab.
1. Don't mix-up validation with calibration. Validation is defined as the establishment of documented evidence which provides a high degree of assurance that a planned process will consistently perform according to the intended specified outcomes. The only relation as I can see is that all equipment must be calibrated first before validation is carried out.
2. With regards to calibration of autoclave, it is beyond me but you should get some information in this search: autoclave calibration
aramono
Thank you very much for your response harry,
1- According to your declaration, I believe that we need calibration before and after validation process.
If I told you regarding production and validation standards because I wanted just to inform you about references that I have already studied but didn?t find any good practice about calibration.
2- Unfortunately, problem is that I have already searched near 2 months by all kind of keywords which is related to calibration. (it drive me crazy because its first time that I can't find a stuff by searching on internet!!)
I have tested all keywords which is related to calibration temperature and pressure for Environmental, climatic, pressurized chamber/vessel that I thought.
And also all the companies which are working on validation and calibration for autoclaves, speak just about validation standards and they do not put information about calibration standard that they do their procedure accordingly.
Do you think that I should wait till the end of holiday period? Please be so kind to let me know how long does it take.
Thanks again..
dv8shane
I have calibrated a couple of sterilizer/autoclaves, it always entailed having the calibration temperature sensor in the chamber within 1 inch of the controller/recorder sensors depending which was under test, and having a T fixture inserted in the pressure line with the calibrated gauge or sensor attached. The rest is documenting the test points for standardized testing according to your process needs. It is a bit of work to set up but once done is usually easily repeatable.
BradM
Hopefully, as mentioned earlier, this chamber has been incorporated into a Validation Master Plan for your facility.
Hopefully you have a plan for qualification of this sterilizer prior to use; which would include establishing validated cycles. Also, you will probably have non-validated cycles and experimental cycles. There should be security levels which distinguish access to the different controls on the sterilizer; one of the highest levels being the calibration access.
Have you looked through the manual that came with the sterilizer? If this is GmP-designed sterilizer, I'm sure you paid a fair amount of money for it. It either came with a service manual; or one is available. You are probably going to need it, as it will specify how to make adjustments to the sensors.
So I would proceed in this manner:
  • Before beginning, assure you have sufficient calibration equipment to perform this activity (pressure calibrator, pressure/vacuum simulation, oil/ice baths, suitable temp. standard, etc.) That stuff can get very pricey very quickly; so if you're small, you may want to contract that service out. Assure your standards have suitable accuracy.
  • Review the functional requirements, mfg. information, and (hopefully accessible) is the initial calibration on the chamber. This information should guide you to what sensors are needed for calibration, the test points that are to be verified, and the acceptable tolerance. So using whatever method your organization has, formally identify which instruments are to be calibrated and the corresponding criteria.
  • Note: Some sensors may not have direct product impact, but can affect the proper operation of the sterilizer. You may want to assess these as a maintenance function: calibrate/adjust as needed, but no out of tolerance reporting required.
  • Find a procedure in your organization that would be similar. It may be easier to start from scratch, but at least it will initially be in the proper format.
  • Go through the sequence of steps with the person writing/executing the IQ/OQ. They have an understanding of the chamber, the valves, etc. You need to have a clear series of steps as to how to isolate steam, air, water (and where required, electrical) sources to perform this service. This may need to be accompanied with lockout/tag-out procedures.
  • Verify that there is no environmental conditions (differential pressure, particulate counts, etc.) that will be affected.
  • I would recommend proceduralizing who is to be contacted prior to calibration to assure no production is disrupted, and no sterile product is affected.
  • If available, I would write down all calibration offsets/parameters prior to calibration. That way, if something really goes wrong, you can at least have the information to return to a working state.
  • Note: I would not replicate the service manual in the procedure; rather, I would point to it where relevant. You should "control" that service manual so it doesn't disappear. Some of those manuals are extremely expensive and replacement costs are over $1,000 (USD).;)
  • Turn all utilities back on, and remove any logout/tagout identifiers that may have been used.
  • Once calibration is complete, I would run a test run to assure the chamber works properly and there are no alarms/etc. associated with the calibration you performed.
  • Assure the calibration technician cleans up the area, notes any logbook entries (for some processes,any/all run should be accounted for), and notifies the appropriate individuals as to being complete.
aramono
I really appreciate for your kind information.​
In fact I am going to establish a test and calibration laboratory only for steam autoclaves. Also, we want to get ISO17025 till next year.( Hope so!!)​
We do not have any problem regarding equipment. I use Ebro data logger EBI10 temperature and pressure data logger (8 Temperature sensor and 1 pressure sensor- according to the structural and type tests equipment of EN285 and EN13060)​
The laboratory that we founded, is a part of our company does not have any problem since we are working in sterilization field for a long time and we do the after sale service of small and big sterilizers(3 italian brands).​
As I have already told you, I found enough information in the different part of standard IEC60068 about the calibration of temperature for the climatic chamber. But the problem is: The test procedures that explained in this standard is for atmospheric pressure condition of this chambers (normal pressure).​
I want to know if there is some guideline or standards like IEC60068 or dkd-r 5-7 for calibration of temperature but in high pressure condition ( high pressure chambers)?? A standard that I could refer to it directly. A guideline that could to be used in similar conditions, even not only for autoclaves.
I know if there is not some standard or certain rule, I can use the method of normal temperature calibration and do the test . Then repeat this method and change it for standardized our procedure.​
Sidney Vianna IATF 16949 News IATF Observer Guideline IATF 16949 - Automotive Quality Systems Standard 5
M Informational Draft ANSM’S GUIDELINE Cybersecurity of medical devices integrating software during their life cycle Medical Device and FDA Regulations and Standards News 0
M Informational EMA – Consultation on draft guideline on quality requirements for medical devices in combination products Medical Device and FDA Regulations and Standards News 0
Richard Regalado ISMS Auditing Guideline V2 (based from ISO/IEC 27001:2013) IEC 27001 - Information Security Management Systems (ISMS) 7
I UDI requirements vs Japanese Barcode Marking guideline Japan Medical Device Regulations 1
W IEC 62304 vs. IMDRF SaMD Guideline Risk Class IEC 62304 - Medical Device Software Life Cycle Processes 5
Ajit Basrur New Guideline from ICH proposed on Lifecycle Management - Q12 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
E Korean GMP Guideline updated to Second Revision - April 2014 Other Medical Device Regulations World-Wide 1
0 GMP Guideline for Recycled Plastic Flakes used in Food Applications Quality Manager and Management Related Issues 4
G Interim PPAP Guideline and what Documents are Needed APQP and PPAP 3
N MEDDEV guideline on Post Market Surveillance (PMS) EU Medical Device Regulations 8
bio_subbu CDSCO-India: Draft Guideline to Calculate Compensation for Victims of Clinical Trials Other Medical Device Regulations World-Wide 0
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
D General Guideline for an appropriate Sample Size for measuring Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 11
J International standards or guideline for the use of CMM (Cordinate measuring machine) Various Other Specifications, Standards, and related Requirements 5
0 Guideline/Method for Raw Material Roll Stock Bioburden Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Ajit Basrur New FDA Guideline on Process Validation - General Principles and Practices US Food and Drug Administration (FDA) 12
N New MEDDEV 2.7/3 Guideline: Clinical Investigations: Serious Adverse Event Reporting EU Medical Device Regulations 4
B Is anyone familar with ISO 10005 Guideline for Quality Plans? Other ISO and International Standards and European Regulations 2
S GMP guideline for Manufacturing of Inhaled Dosage Forms Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
bio_subbu Eucomed published revised guideline on Good Distribution Practice ISO 13485:2016 - Medical Device Quality Management Systems 3
C Need your guideline for CQA exam Professional Certifications and Degrees 3
T On-line SPC Monitoring guideline Statistical Analysis Tools, Techniques and SPC 1
Michael Malis CLSI Proposed Guideline for Validation and Verification of Tubes for Blood Collection US Food and Drug Administration (FDA) 1
somashekar Standing vs Sitting at work, any guideline ? Occupational Health & Safety Management Standards 2
P Medical Device Releasing - Guideline and who is held accountable Other Medical Device and Orthopedic Related Topics 7
C Guideline for streamlined batch record review process - cGMP compliance - Needed Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
C Need guideline for setting Training Goal Training - Internal, External, Online and Distance Learning 10
P Ford APQP Guideline - Is Release Level: 3.2, August 2003 current/up-to date? Customer and Company Specific Requirements 2
J Materials Management Operations Guideline (MMOG) form... Customer and Company Specific Requirements 11
Sidney Vianna IAQG Guidance PCAP 001 - Competence Management Guideline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R IWA latest Guideline wanted Other ISO and International Standards and European Regulations 3
Stijloor Guideline to Standardize the Transp. Damage Claim Process for Finished Veh. IATF 16949 - Automotive Quality Systems Standard 0
Stijloor New Guideline for a Standardized Bill of Lading World News 0
Stijloor eAPQP Technical Guideline and Business Object Document (BODs) Now Available APQP and PPAP 2
P Which ISO guideline or system is relevant for Hospitals? Hospitals, Clinics & other Health Care Providers 5
K Is Identification and Traceability a procedure or more of a guideline? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
D Urgently need VDA6.3 guideline ! Thanks. VDA Standards - Germany's Automotive Standards 12
H Is there a guideline document for a Facility Cleaning Business? Service Industry Specific Topics 2
A Specifications or guideline for topical patch medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
P Linearity & Bias Acceptable Percentage Guideline - Digimatic micrometer General Measurement Device and Calibration Topics 2
A Is there a Guideline document of ISO 9001 for Civil Engineering Services Service Industry Specific Topics 3
A TS 16949 Clause 6.3.1 and Lean Manufacturing - Any guideline for implementation? IATF 16949 - Automotive Quality Systems Standard 3
R Ford APQP Status Reporting Guideline APQP and PPAP 1
C Defininitions and differences: Form vs. Guideline vs. Template, etc Document Control Systems, Procedures, Forms and Templates 9
J Lean Maintenance - Six Sigma's DMAIC guideline serving as a roadmap Lean in Manufacturing and Service Industries 3
G MMOG (Materials Management Operations Guideline) - Ford logistics self assessment Customer and Company Specific Requirements 10
C Audit based on guideline General Auditing Discussions 8
D Feature-Based Processing Recommended Business Process Guideline (THE-5) Various Other Specifications, Standards, and related Requirements 0
S What is the meaning of performance? Is ISO 9004 the guideline for improvement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
