Gynecology Chair - Applicable EU Standards
czar323
Hello to everyone!
Our company encountered some problems with obtaining information upon EU applicable harmonized standards for Gynecology chairs (manual and electric) and Obstetric aid table. We conducted a research, but did not found any applicable standards. Maybe somebody can clear out what to do if there are no such applicable standards. Greatly appreciated!
G
Guillaume Prom
Re: Gynecology chair EU applicable standards
there are no harmonized standards specifically for your products.
But you must apply a lot of general standards (60601-1, 980, 1041,...).
I used EN 15373 to do mechanical testing of a weighing chair.
hope this helps !
czar323
Thanks a lot Guillaume Prom? for the information!:)
Standards that you mentioned (980, 1041, EN 15373) are BS and DIN standard…how are the applicable for obtaining right to affix CE Mark to our products?. The reason why I’m asking this question is because our company located in Belarus (former Soviet Union) and all CE mark processes are very much new to this area.
Marcelo
Standards are usually voluntary (and they are voluntary in the CE marking process).
Using harmonized standards means that, using them, you gain what is called a "presumption of conformity" to the related essential requirements of the directive.
If you don?t use harmonized standards (or there are no harmonized standards for your product, such as the case), you have to justify what you use, and the NB would need to verify that it really covers the related essential principles.
So, you can use any standard, and as mentioned, in your case you probably should (not must) use different tests from different standards (note that even in this case they are not mandatory, you could, for example, develop your testing for your device that you think cover the related essential principles, however, using one or more standards developed by an SDO - Standard Developing Organization - means that you are using consensus testing and thus packs more punch and usually makes it easier for you to get agreement from your NB.
czar323
Greatly appreciate Marcelo Antunes for your explanations!
Our company is 13485 certified and gynecology chair is Class 1 medical device. So if I understand correctly we don’t have to involve NB to affix the CE mark. Basically, as a company, can determine ourselves which standards to apply to show the conformity to MDD requirements?
Marcelo
gynecology chair is Class 1 medical device. So if I understand correctly we don?t have to involve NB to affix the CE mark. Basically, as a company, can determine ourselves which standards to apply to show the conformity to MDD requirements?
Oh yes, sorry, forgot that detail. If the device is class I without sterilization or measurement, you do not need to involve an NB.
Anyway, yes, it?s up to the manufacturer to choose how to comply with the requirements. Standards are one way to comply, and harmonized standards additionally give presumption of conformity.
Ronen E
Problem Solver
Moderator
Please also note that a BS version or a DIN version of an EN standard is acceptable as a harmonized standard since they are required by law to be identical in terms of requirements. I.e. if you're looking at EN 1041 then BS EN 1041 and DIN EN 1041 (as well as many other national transpositions) are acceptable. Perhaps even Belarus has its own national versions in your own language, which might be more convenient (sorry, I don't have any Belarus related experience so I don't know its system).
Cheers,
Ronen.
PS For the electrical models you might want to look at the EN 60601 standards family.
czar323
Good day to everyone!
Small question about the standards?We decided to use some parts of 60601-2-52 (Basic safety and essential performance of medical beds). When I am looking to purchase this standard it gives me 3 standards and they all differ in price:
EN 60601-2-52:2010/AC:2011
EN 60601-2-52:2010
IEC 60601-2-52:2009
Do I need to have all 3 of them?
Thanks for your kind help!
G
Guillaume Prom
EN 60601-2-52:2010 (harmonized European standard, based on IEC 60601-2-52:2009)
EN 60601-2-52:2010/AC:2011 (errata, isn't it free ?)
PS: I'm not sure that 60601-2-52 is OK for Obstetric aid table, see medical bed definition (60601-2-52 ?201.3.212):
"device for which the intended use is sleeping/resting that contains a mattress support platform and intended to assist in diagnosis, monitoring, prevention, treatment, alleviation of disease or compensation for an injury or handicap
Note 1 to entry: A bed-lift and/or a detachable mattress support platform in combination with a compatible nonmedical bed as specified by the manufacturer is also considered a medical bed.
Note 2 to entry: Excluded are devices for which the intended use is mainly for examination or transportation under medical supervision (e.g. stretcher, examination table)
Marcelo
Note 2 to entry: Excluded are devices for which the intended use is mainly for examination or transportation under medical supervision (e.g. stretcher, examination table)."
In this particular case, the applicability of the standard does not matter thattttt much.
From what the OP said, it seems he?s looking for verification testing, ways to verify that the device meets the requirements. So, if he has to verify that the patient will not fall from his chair, he would need to design a test for this requirement. There are some standards that already have a test like this, including 60601-2-52. As a good practice, he should evaluate if the test (which as you pointed out, was created based on a medical bed which is clear defined) can really be applied to his device, but probably it can be applied directly (or by changing some parameters, for example).
The high level idea on the discussion is that testing from a standard is simply nothing more than an verification test that you use to prove conformity to some requirement. Knowing the requirement, you need to choose the best way to verify it. Product standards are collections of possible testing and verification solutions, and they are easy to use because someone (the WG that created the standard) has already thought about the test. Otherwise the manufacturer would need to design the test itself. One of the main problems we have is that people usually blindly follow standards, without this background understanding of what a standard really is.
But again, as noted, it?s important to verify that the standard testing does fit the testing need. When creating ISO 24971, which has details on how to use standards with risk management, I remember a particular request from the FDA about a problem related to blind following standards and requirements that I also had experience noting - a lot of manufacturers were using tests which did not match the requirement - example, the particular testing was created for a patient with a maximum 100 kg. If your intended patient can have more that that weight, you could still use the testing principle, but would need to change the testing parameters (and, depending on the case, either change the testing itself, or not use the testing because changing the parameters would invalid the testing itself.
All in all, understand what you are doing and select the correct solution :)
M Medical Device News USFSA – 2019 Meeting Materials of the Obstetrics and Gynecology Devices Panel Medical Device and FDA Regulations and Standards News 0
Sidney Vianna Covegratulations to Paul Simpson, Chair-Elect of the ISO TC176 SC2 Covegratulations 8
JoCam Domestic to Medical Device Use - Riser/Recliner Chair or a Commode EU Medical Device Regulations 4
W What is the applicable standard for Chair Mounted Dental Unit for CE IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Dental Treatment Unit (aka Dentist's Chair) requirements EU Medical Device Regulations 7
J CE Mark Requirements for Dentist Chair EU Medical Device Regulations 6
Sidney Vianna Man flies 193 miles in lawn chair Coffee Break and Water Cooler Discussions 12
J Are complaints applicable to development of medical devices? Customer Complaints 2
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Machine directory (2006/42/EEC) is applicable or not Other Medical Device Related Standards 0
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
R An indication that the device is a medical device (MDR, Annex 23.2q) - applicable for accessories? EU Medical Device Regulations 5
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G App - Local regulations applicable EU Medical Device Regulations 2
M Do you need an Applicable general safety and performance requirements Checklist? EU Medical Device Regulations 2
S SOPs applicable for Regulatory Affairs department Other ISO and International Standards and European Regulations 1
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Is impact test according to IEC 60601-1 applicable for HAND-HELD equipment if also classified as BODY-WORN? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B EU MDR Quality System Requirements - Applicable to Class I? EU Medical Device Regulations 5
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
C Is IEC 60601 applicable to our smart bed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Applicable MDR Annex's for Class IIa Medical Devices EU Medical Device Regulations 0
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
DuncanGibbons To what extent are NASA standards applicable to commercial aviation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
M Accelerated Ageing Test for Orthopedic Implants -- ASTM F 1980 or ISO 11607 or both are applicable ? Other Medical Device and Orthopedic Related Topics 2
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
M CEP requirements in MEDDEV 2.7/1, rev 4 and MDR - Are all MEDDEV requirements still applicable? EU Medical Device Regulations 7
MrTetris GDPR - General Data Protection Regulation - Only applicable to EU data? Other ISO and International Standards and European Regulations 6
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
L Pneumatic powertool (Drill) - Is IEC 60601-1 applicable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Q Applicable Medical Device Wifi regulations for various Countries Other Medical Device Regulations World-Wide 7
pcoltsqe AS9100 - The statement 'applicable statutory and regulatory requirements' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
qualprod Is it a NC, if a clause is not declared as non applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A ISO 13485:2016 Applicable regulatory requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T To Identify the Applicable MDD Directive - Prepared blood smear EU Medical Device Regulations 13
qualprod Non applicable clauses in a reseller? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Class I 510(k) exempt - Applicable Standards 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T IATF16949:2016 8.7.1.4 Control of non-applicable reworked product IATF 16949 - Automotive Quality Systems Standard 3
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
M ISO13485:2016 - Exemption vs. Not Applicable ISO 13485:2016 - Medical Device Quality Management Systems 16
Y ISO 9001 Cl. 8.3 - Design and Development of Products and Services not applicable ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
