HACCP Document Control vs. ISO 9001 Document Control Requirements
K
Ka Pilo
Is HACCP document control a difficult task to do? What are the controls required for HACCP documentation? Where these different than those of ISO 9001 4.2.3 and 4.2.4?
mguilbert
Re: HACCP control of document vs ISO 9001 control of document
My understanding is that with HACCP you must be able to track every lb of raw product to finished reworked, or rendered product all the way through the process. The retention of records can also be longer. In case you should need to have a recall you must be able to call back all lots/lines where the raw material that is suspect has been used. For example, I am making Italian Deli Meats and a specific lot of pork cheeks is recalled. That lot of pork cheeks may have been used in Pepperoni, Hard Salami, Genoa Salami, etc. I must be able to account for all of the initial lot of pork cheeks.
Another example, lets say I have the Pepperoni, Salami's, etc in an incubator that did not reach high internal temperature (a critical control point), all lines/lots that were incubated in that incubator need to be accounted for. To me the HACCP paperwork is a little more involved than ISO 9001. HACCP deals with critical control points which may affect product safety a component of product quality.
For example I am making proscuitto ham bone out (Italian spiced ham). I have meet all of my CCP's which means the product is ready for the consumer. But when I slice it the seam where I removed the bone from the ham gives me two thin slices instead of one larger slice.
HTH,
Matt
Bilijaf
The same requirements of ISO 9001 stated in 4.2.3 and 4.2.4 can be applied for HACCP (remember HACCP is a program and not a standard).
Talking about retention period of rHACCP records you should take into consideration the legal and customer requirements and your internal regulations. As a recommendation, the records for food manufacturing are to be kept for the shelf life of the products plus one calendar year.
Robert jr
It has been recommended that in food industry documents to be retained for a minimum three years and in product recall events even up to 10 years.
Regarding documentation in HACCP Plan, as per Principle 7 efficient and accurate record-keeping is essential to the application of an HACCP system. HACCP procedures should be documented. Documentation and record-keeping should be appropriate to the nature and size of the operation and sufficient to assist the business to verify that the HACCP controls are in place and being maintained.
The principle requires the maintenance of records generated during the operation of the plan. The record keeping associated with HACCP procedures ultimately makes the system work. The requirement to record events at CCPs on a regular basis ensures that preventive monitoring is occurring in a systematic way. Unusual occurrences that are discovered as CCPs are monitored or that otherwise come to light must be corrected and recorded immediately with notation of the corrective action taken.
mguilbert
More than just a return for unsatisfactory purchase but more importantly harmful to intended users. i.e Toyota recalls for unsafe brakes or gas pedals, Eggs in US for salmonella.
K
Ka Pilo
The real challenge is to know when the documentation is appropriate/sufficient. Anyway, let me provide additional details and follow-up questions. We will be practicing HACCP. The management instructed us to adopt ISO 9001 control of documents and control of records. My questions are:
Is it possible for an organization to pick up from the six mandatory procedures what to be adopted?
If so, what specific requirement in ISO 9001 would you advice to be integrated in HACCP program?
If not, why all ISO 9001 requirements should be implemented?
Do anyone here have implemented HACCP without practicing ISO 9001?
mguilbert
1)You can select which every parts of ISO 9001 you wish to adopt but you can not be certified ISO 9001 if you do not adopt them all unless you have exclusions acceptable to your registrar. See the this thread for more details.
http://elsmar.com/Forums/showthread.php?t=19564
2)There are many companies that are HACCP but not ISO 9001. Have you looked at ISO 22000? The ISO 22000 standard deals specifically with HACCP. ISO 9001 is mainly a Quality Standard.
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
D HACCP question Imported Legacy Blogs 1
Q HACCP Plan under ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D HACCP Internal Audit Template wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
D Pesticides in Food Process Areas - HACCP in a Restaurant Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M HACCP Plan without CCPs Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M HACCP vs. ISO 22000 Documented Procedure requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 1
C I am looking for a GMP / HACCP Checklist Quality Manager and Management Related Issues 2
S Source of Online or Home Based HACCP - FSSC22K Training Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Food Services Hygiene - ISO 22000 Certificate or HACCP Certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Evidence of Management Commitment to HACCP Food Safety - ISO 22000, HACCP (21 CFR 120) 3
P HACCP for Poultry Slaughter House Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Locating HACCP Training and Certification Resources Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P HACCP Product Description Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 3
F HACCP Certification for Single Use Disposable Food Contact Grade Gloves Food Safety - ISO 22000, HACCP (21 CFR 120) 1
R HACCP for Packaging, Labeling and Warehouse of Food Products Food Safety - ISO 22000, HACCP (21 CFR 120) 13
P Food Safety - Presentations and Information pertaining to Food Safety & HACCP Manufacturing and Related Processes 1
A HACCP Plans - OPRP's and CCP's - Difference, please Food Safety - ISO 22000, HACCP (21 CFR 120) 10
6 Catering HACCP/Food Safety - Traceability from Receipt to Finished Product Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J HACCP and ISO22000 - Brewery and Warehouse Food Safety - ISO 22000, HACCP (21 CFR 120) 13
L Implementation of GMP and HACCP on a Spice Packaging Facility Food Safety - ISO 22000, HACCP (21 CFR 120) 7
C HACCP for Pizza Restaurants Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S HACCP Implementation Issues Food Safety - ISO 22000, HACCP (21 CFR 120) 4
K Can tobacco companies be certified against HACCP/ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 12
G Question about OPRP and PRP with regards to HACCP and ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
M ISO 22000 - HACCP plan for ingredients like Egg Powder, Strawberry Flavour and Butter Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J ISO 22000, PAS 220 and HACCP Combination. Food Safety - ISO 22000, HACCP (21 CFR 120) 10
S HACCP for Animal Feed - Writing a form and report about Animal Feed Food Safety - ISO 22000, HACCP (21 CFR 120) 10
V Certified Quality Improvement Associate vs. CSSGB, About HACCP Professional Certifications and Degrees 7
B Implementing an HACCP system - Scheme for company Food Safety - ISO 22000, HACCP (21 CFR 120) 3
K General HACCP (Hazard Analysis Critical Control Point) Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 8
S OPRP or HACCP Plan - Opinions and Practical Example Wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 17
A HACCP Flow Diagram for Powdered Milk? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S Quality Control Processes in a Mineral Water Company and HACCP Food Safety - ISO 22000, HACCP (21 CFR 120) 20
P Differences between Codex, HACCP and ISO Food Safety - ISO 22000, HACCP (21 CFR 120) 3
E HACCP in our Dairy Farm (Milk Processing) Food Safety - ISO 22000, HACCP (21 CFR 120) 4
C HACCP in Egg Production - Controlling hazards at the farm level Food Safety - ISO 22000, HACCP (21 CFR 120) 7
B Safe-Menu - System used in restaurants based on HACCP called Safe-Menu Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S HACCP on Time and Temperature Control - Microbiological Contamination Food Safety - ISO 22000, HACCP (21 CFR 120) 3
B HACCP plan for Frozen Shrimp - Required toxicity tests Food Safety - ISO 22000, HACCP (21 CFR 120) 6
D Difference between ISO 22000 certificate and HACCP certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 4
B What we must do to transfer from HACCP to ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 7
B HACCP and GMP Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 2
B Is CQP (Critical Quality Points) a requirement for HACCP? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
H Where to learn about ISO 22000, HACCP and FS (food safety) Food Safety - ISO 22000, HACCP (21 CFR 120) 10
R HACCP-ISO 22000 cross reference wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P HACCP certification program - Help needed Professional Certifications and Degrees 5
V Implementing FSMS in a Tourist Resort - HACCP plan and SOP help wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
A Dietary supplement: GMP or HACCP? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
