HACCP on Time and Temperature Control - Microbiological Contamination
Sartaj Bedi
While creating HACCP plan why can one just use time and temp controls.
Do I really need to know what microbilogical contaminbation may exist in chicken.
All I really need to know that chciken has to be grilled properly and stored properly.
Am I correct?
F
frawat
Re: HACCP on time and temp control
Sartaj
You need to validate that your cooking procedure is effective (heat penetration trials, lethality requirements, scientific literature, etc.). Also I think you should check your microbiological load after cooking (as a verifying procedure), but I guess you could do this in a weekly or monthly basis.
Yes, monitoring should not involve any microbiological analysis.
Regards,
Francis
Jimmy the Brit
Am I correct?
:2cents:
Yes, you most certainly do need to know what microbial contamination exists in chicken prior to cooking. Time and temperature will tell you that you have reached a suitable temperature to ensure that the food is properly cooked and bacteria inactivated, but what it will not tell you is what toxins remain in your chicken from that bacterial population. Not all "food poisoning" occurs as a result of living bacteria - most is from residual toxins left in the food, which cannot be destroyed by cooking. In order to understand the risk associated with this you need to know what organisms are present, in what numbers, and what toxic contribution they may have.
You don't need to do this every batch, but it would be prudent to check each supplier initially, to give you confiidence that they are sourcing and handling the chicken correctly, and then periodically to check that links in the supply chain you cannot see are under control.
Jimmy
F
frawat
Yes, Jimmy is right.
I forgot to address the issue of the microbiological load (and potential toxins) in the chicken before cooking.
I guess this may not be a CCP, but just a pre-requisite program (equally very important).
regards,
Francis
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
D HACCP question Imported Legacy Blogs 1
Q HACCP Plan under ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D HACCP Internal Audit Template wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
D Pesticides in Food Process Areas - HACCP in a Restaurant Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M HACCP Plan without CCPs Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M HACCP vs. ISO 22000 Documented Procedure requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 1
C I am looking for a GMP / HACCP Checklist Quality Manager and Management Related Issues 2
S Source of Online or Home Based HACCP - FSSC22K Training Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Food Services Hygiene - ISO 22000 Certificate or HACCP Certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Evidence of Management Commitment to HACCP Food Safety - ISO 22000, HACCP (21 CFR 120) 3
P HACCP for Poultry Slaughter House Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Locating HACCP Training and Certification Resources Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P HACCP Product Description Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 3
F HACCP Certification for Single Use Disposable Food Contact Grade Gloves Food Safety - ISO 22000, HACCP (21 CFR 120) 1
R HACCP for Packaging, Labeling and Warehouse of Food Products Food Safety - ISO 22000, HACCP (21 CFR 120) 13
P Food Safety - Presentations and Information pertaining to Food Safety & HACCP Manufacturing and Related Processes 1
A HACCP Plans - OPRP's and CCP's - Difference, please Food Safety - ISO 22000, HACCP (21 CFR 120) 10
6 Catering HACCP/Food Safety - Traceability from Receipt to Finished Product Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J HACCP and ISO22000 - Brewery and Warehouse Food Safety - ISO 22000, HACCP (21 CFR 120) 13
L Implementation of GMP and HACCP on a Spice Packaging Facility Food Safety - ISO 22000, HACCP (21 CFR 120) 7
C HACCP for Pizza Restaurants Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S HACCP Implementation Issues Food Safety - ISO 22000, HACCP (21 CFR 120) 4
K Can tobacco companies be certified against HACCP/ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 12
G Question about OPRP and PRP with regards to HACCP and ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
M ISO 22000 - HACCP plan for ingredients like Egg Powder, Strawberry Flavour and Butter Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J ISO 22000, PAS 220 and HACCP Combination. Food Safety - ISO 22000, HACCP (21 CFR 120) 10
S HACCP for Animal Feed - Writing a form and report about Animal Feed Food Safety - ISO 22000, HACCP (21 CFR 120) 10
V Certified Quality Improvement Associate vs. CSSGB, About HACCP Professional Certifications and Degrees 7
B Implementing an HACCP system - Scheme for company Food Safety - ISO 22000, HACCP (21 CFR 120) 3
K General HACCP (Hazard Analysis Critical Control Point) Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 8
K HACCP Document Control vs. ISO 9001 Document Control Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 20
S OPRP or HACCP Plan - Opinions and Practical Example Wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 17
A HACCP Flow Diagram for Powdered Milk? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S Quality Control Processes in a Mineral Water Company and HACCP Food Safety - ISO 22000, HACCP (21 CFR 120) 20
P Differences between Codex, HACCP and ISO Food Safety - ISO 22000, HACCP (21 CFR 120) 3
E HACCP in our Dairy Farm (Milk Processing) Food Safety - ISO 22000, HACCP (21 CFR 120) 4
C HACCP in Egg Production - Controlling hazards at the farm level Food Safety - ISO 22000, HACCP (21 CFR 120) 7
B Safe-Menu - System used in restaurants based on HACCP called Safe-Menu Food Safety - ISO 22000, HACCP (21 CFR 120) 2
B HACCP plan for Frozen Shrimp - Required toxicity tests Food Safety - ISO 22000, HACCP (21 CFR 120) 6
D Difference between ISO 22000 certificate and HACCP certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 4
B What we must do to transfer from HACCP to ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 7
B HACCP and GMP Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 2
B Is CQP (Critical Quality Points) a requirement for HACCP? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
H Where to learn about ISO 22000, HACCP and FS (food safety) Food Safety - ISO 22000, HACCP (21 CFR 120) 10
R HACCP-ISO 22000 cross reference wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P HACCP certification program - Help needed Professional Certifications and Degrees 5
V Implementing FSMS in a Tourist Resort - HACCP plan and SOP help wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
A Dietary supplement: GMP or HACCP? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
