Haimer Universal 3-D Sensor Calibration - No Calibration Needed?
AudreyPrue
#11
That was my thought too but for the range am I sure I am doing the right calibration / variation between blocks to capture the travel of the 3-D Sensor. Also, is this calibrating the CNC equipment, the 3-D Sensor or the combination? Thanks for the continued interaction.
BradM
#12
Hmmm.... this is interesting...
I looked at their website (thanks Marc) and saw nothing that represented a requirement for calibration/verification. I thought that was odd.
There was no certificate with this? That is odder than odd. :tg:
What are you planning on using this device for? When I looked at the video on the website, it seemed they were using it for positioning and such.
A thought I had on this is if a verification would work. If you have some lathes and such with precise x,y,z measurements, you could make this instrument as part of a verification device in the system. Connect this gauge, and then move the spindle a certain distance and verify the displayed distance with that displayed by this 3-D sensor.
Another thought is contacting someone with some precise laser measurement and such. This sensor could be mounted and 'touch' a protrusion on a movable base. Then verify the indicated distance with that of the precision laser after the base was moved. This would be done for x, y, and z measurements.
Best thing I would recommend is contacting their office and explain what you are looking for.
Do assure that, given your use of this, that you have to calibrate it. Otherwise, maybe you can set up some kind of verification system in-house.
AudreyPrue
#13
BradM, Thanks for your thoughts. You are right this is attached to the spindle of a CNC and then use to indicate (locate) the zero point XYZ then this offset is entered into the program They can also use as a crude CMM for measurement depending on tolerance. I didn't preface that I am QM for a Mold shop with CNC and other high speed precision machining equipment. Ideally you are right a high precision laser would be best, but expensive, will verify with gage blocks.
K
Ka Pilo
#14
I think it depends on your setup. Generally speaking, it is best to calibrate equipment individually and then the combination.
J Universal Power Cord with Adapters - IVD IEC 61010-2-101 CE Marking (Conformité Européene) / CB Scheme 6
Marc Definition UBL - Universal Business Language Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
M Universal Process Audit Form Document Control Systems, Procedures, Forms and Templates 1
N Any ULM (Universal Length Measuring device) Users? Calibration and Metrology Software and Hardware 5
G Revision Control - Per document vs Universal control Document Control Systems, Procedures, Forms and Templates 7
P Finding UMDNS (Universal Medical Device Nomenclature System) Codes Other Medical Device Related Standards 6
B Universal Medical Device vs. Global Medical Device Nomenclature Systems Other Medical Device Regulations World-Wide 2
T Universal Testing Machine - Calibration and Measurement Uncertainty General Measurement Device and Calibration Topics 1
G Universal FMEA - Small job shop stamper FMEA and Control Plans 3
J Universal phone charger approved After Work and Weekend Discussion Topics 4
M Universal Master Square/Toolmakers Surface Plate Square Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I Laboratory for Checking Tensile Strength using UTM (Universal Tensile Machine) General Measurement Device and Calibration Topics 13
I Does Anyone know how to check Universal Tensile Machine (UTM) ? Reliability Analysis - Predictions, Testing and Standards 5
N Universal/International Symbol for Tolerance and/or Calibration Levels? General Measurement Device and Calibration Topics 7
F What the heck is Universal 57 font? MS Word asks for the font Universal 57 After Work and Weekend Discussion Topics 7
D Line clearance - Routine components in the prep room for universal use ISO 13485:2016 - Medical Device Quality Management Systems 8
B Non-sterile - Does anyone know of a universal symbol? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Looking for a universal(?) example to illustrate what happens when an error occurs Nonconformance and Corrective Action 4
W Nonconformance ID tags - Seeking universal non-conforming Red Tag - Approx. 4" x 6" Document Control Systems, Procedures, Forms and Templates 3
Marc Rule discussion 2 - Universal Healthcare Coffee Break and Water Cooler Discussions 15
L Universal Studios Coffee Break and Water Cooler Discussions 2
N Composites - Freezer sensor requirements Manufacturing and Related Processes 2
F Firmware as SOUP - Sensor with third party produced firmware IEC 62304 - Medical Device Software Life Cycle Processes 2
A Uncertainty Budget - Externally produced sensor module Measurement Uncertainty (MU) 1
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Wristwatch Skin-proximal glucose sensor - Classification under MDR EU Medical Device Regulations 4
M Contactless Hospital Bed Sensor Certification IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M SAE AMS 2750E Relocation Hot or Cold Recording Sensor Manufacturing and Related Processes 1
A Calibrating a PRT sensor - Temperature Sensitivity Coefficient General Measurement Device and Calibration Topics 2
C Degrees of Freedom with Linear Regression - Pressure Sensor Uncertainty Measurement Uncertainty (MU) 15
B Unaccredited Test using my Temperature Sensor as a Reference General Measurement Device and Calibration Topics 1
G Gage R&R for an On-Line Device - Continuous Monitoring Dew Point Sensor in a Furnace Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Gage R&R - Sensor Tester with Multiple Operators and Multiple Sensor Test Channels Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
somashekar Waste Categorization - Medical Device (Disposable Sensor) Miscellaneous Environmental Standards and EMS Related Discussions 4
M Vision System - Camera vs. Sensor to perform 100% EOL Inspection Quality Tools, Improvement and Analysis 2
R HP8481A Power Sensor Calibration - What standards are normally required? General Measurement Device and Calibration Topics 5
somashekar Health, hygiene and contamination control procedure for a sensor cable product. ISO 13485:2016 - Medical Device Quality Management Systems 1
H Opinions on and finding a Thread Sensor General Measurement Device and Calibration Topics 1
M Qualification of a Poron Gasket for a Silicon Acoustic Sensor Chip Manufacturing and Related Processes 3
J Agilent Power Sensor Calibration - Need a Calibration Procedure General Measurement Device and Calibration Topics 13
Marc Researchers Pinpoint Brain's Sarcasm Sensor World News 3
F U-Chart? Product is a temperature sensor Statistical Analysis Tools, Techniques and SPC 3
