Hand-held Digital Tension Meter Calibration
Dongzkie
Hello, need your experties here. I have some question regarding with calibration of dtm handheld. How material sizes related to when calibrating the dtm, like for example referring to the user manual on the dtm, I would like to calibrate the dtm with 1kg test weights and I am using 0.5mm wire for suspending the test weights, then on the calibration set-up you must also put the 0.5mm wire material, my question is that how important is the material size when calibrating this instrument, is it included on the calculation? or how it affects if my suspension wire is 0.3mm while I put on the dtm is 0.50mm, can this will cause an errors during the calibration?
thanks in advance.
