Hand-starting threaded fasteners
L
longview7
We supply welded sub assemblies to automotive Tier 1 and OEM manufacturers. Is it an industry-wide common practice to hand start nuts and bolts 3-5 turns before applying power tools? Because this has been my experience with all of our domestic and foriegn automotive customers for over ten years, I believe it is.
Just recently, a Tier 1 has imposed a new standard that "All fasteners must thread freely by hand to their full length." This seems like an excessive requirement. "freely by hand" varies by operator finger strength. While we are responsible to control weld spatter, it is impossible to assure to no debris will enter the threads prior to assembly. They impose 3rd party containment at each incident.
Have you ever heard of such a requirement?
Thank you,
smkeilman
Short answer: sort of, but I don't work in automotive, either.
Longer answer: This sounds to me like someone may have gotten burned recently, perhaps for giving an OK for some questionable parts. Case in point: we machine oil manifolds. When we started, we could pack them in crates however we wanted. There was one part that fit two to a crate very nicely. One day, we are told that all manifolds must be shipped in separate crates. We had never had a problem with our packing; we had even been complimented on it. We think the OEM was having problems with parts hitting each other and getting damaged in shipment. So, one part, one crate, packed in foam.
Properly made screw threads will assemble by hand to full length, so it's not outrageous to demand that your parts are made correctly. Since your concern is weld splatter (and you admit to this being your problem to control), I don't really see any path forward besides plugging all of the holes, perhaps with set screws. You could have small slots cut into the set screws to try to break any splatter off when they are removed.
L
longview7
Thank you for the reply. I suspect the new requirement is a reation to some other issue, but there was no explanation offered.
The parts we are shipping are made correctly. Weld splatter from out process will stop a bolt that is being driven by a power tool. Finger tightening fully can be stopped by a minor bit of dirt.
You have a good idea about the hole plugging, but that will be labor intensive. But we are dealing with 15,000 threaded holes per day. The concern I have is that this new requirement is well outside the norm and will be impossible to meet without a requote for the labor. Customer says "same price, no negotiation."
I have never heard of this requirement. What is the industry standard?
smkeilman
I don't think you're going to find much of anything. There are some clauses that could help you, however. For example:
ISO 2768-1:1989 Annex A-A.4: "Exceeding the general tolerance should lead to a rejection of the workpiece only if the function is impaired"
The ISO and ANSI/ASME thread specs will tell you that for a threaded hole to be conforming, a GO thread gage must assemble freely by hand for the entire thread length. We have had parts rejected and returned for this issue. Even if a gage won't assemble, you may be able to say function is not impaired if a fastener assembles. However, fighting a Tier 1 or OEM over that might not be in your best interest.
If the splatter will stop a power driven bolt, then you have a legitimate process problem. You are rendering components unusable because of your process. I assume that your business arrangement stipulates that you supply conforming product, which kind of backs you into a corner. If a component does not assemble, and weld splatter is determined to be the cause, you will likely find yourselves on the hook for it.
The reason I suggested set screws is that the only way to send conforming product is to remove them, and the only way you will remove them is if you have a good hole.
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Components of a medical device - Hardware robotic hand EU Medical Device Regulations 3
G Is impact test according to IEC 60601-1 applicable for HAND-HELD equipment if also classified as BODY-WORN? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
U PATIENT CONNECTION for HAND-HELD Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
L Part 11 Certified to legally binding of hand written signatures Other Medical Device Regulations World-Wide 3
D Use of hand cream inside gloves in the cleanroom for medical devices Occupational Health & Safety Management Standards 7
B Figure A.20 of IEC60601-1 about definition of "Hand-held" & "Portable" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Hand-held Digital Tension Meter Calibration General Measurement Device and Calibration Topics 1
S 21 CFR 11 - Require paper and hand signatures not electronic Other US Medical Device Regulations 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
B Flammability Ratings for Internal Battery & Hand-Held ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D Test Report written by hand or electronically ISO 13485:2016 - Medical Device Quality Management Systems 7
R Approving a New Hand Assembly Line at a Supplier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
GURU SDI VDA 6.3 Hand Book - Two sections for Potential Analysis VDA Standards - Germany's Automotive Standards 1
K Preventing Shortage of Product Quantity - Hand Count and Scale Count Manufacturing and Related Processes 13
S Medical Device or Cosmetic Device in Korea? Hand Held Wrinkle Reduction LED Light Other Medical Device Regulations World-Wide 1
S Medical Device or Cosmetic Device in Japan? Hand Held Wrinkle Reduction LED Light Japan Medical Device Regulations 3
T Thread Gaging: Hand Tight Definition Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Should a low cost hand held refractometer be in a calibration program? Calibration Frequency (Interval) 8
B Hand Swabbing Employees - Guidelines of micro limits and procedures and frequency Food Safety - ISO 22000, HACCP (21 CFR 120) 2
R Silicone in Hand Lotion in Electronics Manufacturing Manufacturing and Related Processes 4
A Configuration Management and On-Hand/In-Transit Inventory Quality Manager and Management Related Issues 3
G I hope someone can give me a hand.. Various Other Specifications, Standards, and related Requirements 4
S Critical Limits for Hand Washing Food Safety - ISO 22000, HACCP (21 CFR 120) 13
A Microbial Limit (Bioburden)on dry nonwoven that used for making Hand sanitizing wipes ISO 13485:2016 - Medical Device Quality Management Systems 1
M Microbiological Standards (Limits) for Hand Swabs for Coliforms and S. Aureus Food Safety - ISO 22000, HACCP (21 CFR 120) 15
C Testing Agencies - Gas Meters and Hand Held Analyzers General Measurement Device and Calibration Topics 2
Icy Mountain Alcohol Based Hand Sanitizers in Electronics Manufacturing Manufacturing and Related Processes 10
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
S Confusion DPU, PPM & DPMO vs. Sigma Level - ASQ Six Sigma Black Belt hand book Six Sigma 14
T Sanitary "Green" Restrooms - Hand Driers and Waterless Urinals - Food Manufacturing Sustainability, Green Initiatives and Ecology 20
R Hand tool to measure angles that has been machined into stock Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Hand-Out for Human Factors Training Training - Internal, External, Online and Distance Learning 7
F Production Employees and hand gage issues Human Factors and Ergonomics in Engineering 13
L Original Documentation - Need to maintain any original hand written documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
D Is CE Mark required for Hand Sanitizers to be sold in Europe ? EU Medical Device Regulations 6
M Hand Tool Selection to Remove Microjoints and Slivers off of Small Parts - Advice Manufacturing and Related Processes 6
Q Using Faxed Hand Signatures for Approval Records US Food and Drug Administration (FDA) 17
S How can I die cut foam - I'm thinking of a simple hand machine? Manufacturing and Related Processes 15
A Removing the liner from disposable nicotine patch without using hand ISO 13485:2016 - Medical Device Quality Management Systems 11
R CAPA (Corrective and Preventive Action) Discussions are Getting Out of Hand Nonconformance and Corrective Action 41
T Control Plans - Right hand side of the control plan was a flow chart FMEA and Control Plans 3
Q Qualifying Persons to Reflow Solder by hand - Circuit boards Various Other Specifications, Standards, and related Requirements 3
S Hand Solder Board/Component Temperature Requirements for Repair Various Other Specifications, Standards, and related Requirements 7
K Process Validation - Hand soldering of components & wires on PCB - Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Hand processes - How can you error proof human systems with out automation? Preventive Action and Continuous Improvement 7
Q CQE (Certified Quality Engineer) Exam - Are Hand Generated Notes Allowed? Professional Certifications and Degrees 29
