Hand transmitted vibration 9.6.3 of IEC 60601-1
Hi Friends,
I would like to understand on the above mentioned clause. What kind of accessories or product would be applicable for this clause.
Hi Thank you response ,
I have a product having an accessory which function is to trigger/actuate the switch which helps to deliver the drug to a body.
In the accessory there is a small Haptic motor which vibrates for 10ms only when the button is pressed. In that case 9.6.3 of IEC 60601-1 is applicable ? Please advise.
The clause is applicable to the ME Equipment. It is up to you to decide if this accessory is part of the ME equipment, generally yes accessories are included.
However, the requirement is stated for a cumulative time of 8 hours and can be adjusted for less time. With your vibration lasting for 10 ms (depending on how frequently they will be using it) the calculated acceleration limit will be huge and probably not a concern. You should estimate how much the button will be used, calculated the allowable acceleration using the provided formula, and check that the acceleration of your device is less than the limit using ISO 5349-1. Your test house will probably be able to do this for you.
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
A Components of a medical device - Hardware robotic hand EU Medical Device Regulations 3
G Is impact test according to IEC 60601-1 applicable for HAND-HELD equipment if also classified as BODY-WORN? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
U PATIENT CONNECTION for HAND-HELD Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
L Part 11 Certified to legally binding of hand written signatures Other Medical Device Regulations World-Wide 3
D Use of hand cream inside gloves in the cleanroom for medical devices Occupational Health & Safety Management Standards 7
B Figure A.20 of IEC60601-1 about definition of "Hand-held" & "Portable" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Hand-held Digital Tension Meter Calibration General Measurement Device and Calibration Topics 1
S 21 CFR 11 - Require paper and hand signatures not electronic Other US Medical Device Regulations 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
L Hand-starting threaded fasteners Benchmarking 3
B Flammability Ratings for Internal Battery & Hand-Held ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D Test Report written by hand or electronically ISO 13485:2016 - Medical Device Quality Management Systems 7
R Approving a New Hand Assembly Line at a Supplier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
GURU SDI VDA 6.3 Hand Book - Two sections for Potential Analysis VDA Standards - Germany's Automotive Standards 1
K Preventing Shortage of Product Quantity - Hand Count and Scale Count Manufacturing and Related Processes 13
S Medical Device or Cosmetic Device in Korea? Hand Held Wrinkle Reduction LED Light Other Medical Device Regulations World-Wide 1
S Medical Device or Cosmetic Device in Japan? Hand Held Wrinkle Reduction LED Light Japan Medical Device Regulations 3
T Thread Gaging: Hand Tight Definition Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Should a low cost hand held refractometer be in a calibration program? Calibration Frequency (Interval) 8
B Hand Swabbing Employees - Guidelines of micro limits and procedures and frequency Food Safety - ISO 22000, HACCP (21 CFR 120) 2
R Silicone in Hand Lotion in Electronics Manufacturing Manufacturing and Related Processes 4
A Configuration Management and On-Hand/In-Transit Inventory Quality Manager and Management Related Issues 3
G I hope someone can give me a hand.. Various Other Specifications, Standards, and related Requirements 4
S Critical Limits for Hand Washing Food Safety - ISO 22000, HACCP (21 CFR 120) 13
A Microbial Limit (Bioburden)on dry nonwoven that used for making Hand sanitizing wipes ISO 13485:2016 - Medical Device Quality Management Systems 1
M Microbiological Standards (Limits) for Hand Swabs for Coliforms and S. Aureus Food Safety - ISO 22000, HACCP (21 CFR 120) 15
C Testing Agencies - Gas Meters and Hand Held Analyzers General Measurement Device and Calibration Topics 2
Icy Mountain Alcohol Based Hand Sanitizers in Electronics Manufacturing Manufacturing and Related Processes 10
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
S Confusion DPU, PPM & DPMO vs. Sigma Level - ASQ Six Sigma Black Belt hand book Six Sigma 14
T Sanitary "Green" Restrooms - Hand Driers and Waterless Urinals - Food Manufacturing Sustainability, Green Initiatives and Ecology 20
R Hand tool to measure angles that has been machined into stock Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Hand-Out for Human Factors Training Training - Internal, External, Online and Distance Learning 7
F Production Employees and hand gage issues Human Factors and Ergonomics in Engineering 13
L Original Documentation - Need to maintain any original hand written documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
D Is CE Mark required for Hand Sanitizers to be sold in Europe ? EU Medical Device Regulations 6
M Hand Tool Selection to Remove Microjoints and Slivers off of Small Parts - Advice Manufacturing and Related Processes 6
Q Using Faxed Hand Signatures for Approval Records US Food and Drug Administration (FDA) 17
S How can I die cut foam - I'm thinking of a simple hand machine? Manufacturing and Related Processes 15
A Removing the liner from disposable nicotine patch without using hand ISO 13485:2016 - Medical Device Quality Management Systems 11
R CAPA (Corrective and Preventive Action) Discussions are Getting Out of Hand Nonconformance and Corrective Action 41
T Control Plans - Right hand side of the control plan was a flow chart FMEA and Control Plans 3
Q Qualifying Persons to Reflow Solder by hand - Circuit boards Various Other Specifications, Standards, and related Requirements 3
S Hand Solder Board/Component Temperature Requirements for Repair Various Other Specifications, Standards, and related Requirements 7
K Process Validation - Hand soldering of components & wires on PCB - Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Hand processes - How can you error proof human systems with out automation? Preventive Action and Continuous Improvement 7
Q CQE (Certified Quality Engineer) Exam - Are Hand Generated Notes Allowed? Professional Certifications and Degrees 29
