Hard to change factors in DOE (Split Plot Designs) - Injection Molded Parts
davis007
#11
Sample size
THis defect seems to take some time before it starts to appear. If we start up a machine that has been cleaned and polished we see no defects for ~4 hours. Then somtimes we begin to see the defects. And they tend to get worse over the first 24 hours until we reach some kind of steady state.
So my plan for each run is:
1. Clean machine and start up.
2. After four hours take a 1000 part sample ~45 min run time.
3. After 8, 12, 16, 20 and 24 hours take a 1000 part sample.
4. Stop machine and set up for next test.
We already 100% sort these parts because of this defect so I will get 6 1000 part tests at each condition. I can ether treat each as a seperate response, or lump all 6000 smaples together to "hopefully" increase power.
The last issue is that a batch of material is only enogh to run for 4 days. So I will need to block the tests over four batches.
THanks again to everyone for the help I will keep you postedon how this turns out. Should be done with the testing in about 30 days.
#12
Another response variable that you can track and analyze is the time before the first defect appears.
supreecha
#13
DOE: Handling Hard-to-Change Factors with Split-Plot Designs in Minitab
Consider the case of a Low Preessure Die Casting company that wants to use design of experiments (DOE) to simultaneously study three factors to optimize the formula for its Al wheel. Two of these factors are easy to change: the Die Coat Thickness and the Cycle Time of Die Casting in the mix. But another factor, Mold & Al. temperature, aren’t so easy to change. Changing this factor is difficult because the enormous Mold & Al Temp. the company uses take several hours to attain a stable temperature. An experiment that includes a hard-to-change factor, such as the AL Wheel’s Mold & Al. temperature, calls for a special type of DOE called a split-plot design.
Creating a split-plot experiment in Minitab 16 is easy—just choose the 2-level split-plot option under Stat > DOE > Factorial > Create Factorial Design to create a design with up to 3 hard-to-change factors.
Statistical Steven
Statistician
#14
I tend to use blocking if Split Plot is not feasible.
On the analysis side of things, use the Binary Logistic regression with a binary response like defect.
supreecha
#15
Split-plot designs are experimental designs that include at least one hard-to-change factor that is difficult to completely randomize due to time or cost constraints. By making the creation of split-plot experiment designs simple, Minitab 16 makes the benefits of this powerful statistical technique accessible to everyone.
Consider the case of a baking company that wants to use design of experiments (DOE) to simultaneously study three factors to optimize the formula for its chocolate cake. Two of these factors are easy to change: the amount of flour and the amount of sugar in the mix. But another factor, oven temperature, isn?t so easy to change. Changing this factor is difficult because the enormous ovens the company uses take several hours to attain a stable temperature. An experiment that includes a hard-to-change factor, such as the bakery?s oven temperature, calls for a special type of DOE called a split-plot design.
Creating a split-plot experiment in Minitab 16 is easy?just choose the 2-level split-plot option under Stat > DOE > Factorial > Create Factorial Design to create a design with up to 3 hard-to-change factors.
Marc ISO9001:2000 Interpretations - Year 2000 Change Easy Or Hard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C CMM Granite too hard General Measurement Device and Calibration Topics 4
J Argentina Asked for FSC Hard-Copy Edition Only Other Medical Device Regulations World-Wide 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod Non conformity, do nothing? Employee experiencing "hard times" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
W Is it required to stamp obsolete hard copy DHR's "obsolete"? ISO 13485:2016 - Medical Device Quality Management Systems 6
supadrai Just found out the hard way that only one registration per manufacturer is allowed in Yemen, regardless of OEM or private label arrangement. Other Medical Device Regulations World-Wide 0
L Do you need to save hard copies of obsolete documents? Document Control Systems, Procedures, Forms and Templates 10
Q Do hard copies of quality records have to be retained? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
W Great way to work hard for your career Career and Occupation Discussions 4
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S Why is it so hard to close out the CAPAs ? Nonconformance and Corrective Action 16
G Could I destroy my DHR hard copy after 2 years after pdf'ing them ? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Best Fit Alignment vs. Hard Datums Calibration and Metrology Software and Hardware 5
H Layered Process Audit Hard Copy Records Retention Records and Data - Quality, Legal and Other Evidence 6
N Boss is too hard on me.... Career and Occupation Discussions 48
G Document Control - Are hard copies required in addition to soft copies maintained? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Does ISO 9001 require that hard copies of documents be archived? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Hard Copy Documents not in Fireproof Cabinets - Document Storage Questions... ISO 13485:2016 - Medical Device Quality Management Systems 3
I MDNR (Medical Devices National Registry) and Hard Copy Other Medical Device Regulations World-Wide 3
T Eliminating "Hard Copy" Manuals from our Office and Shop Floor - Documentation Medium ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Why are GOOD Internal Auditors so hard to find? Internal Auditing 35
P Hard Milling Process - Dealing with Within Part Variation for SPC Statistical Analysis Tools, Techniques and SPC 18
Q Uncontrolled Hard Copy (Paper) Document Validity Period Document Control Systems, Procedures, Forms and Templates 12
B Hard Gage Rentals - Thread Gages or Thread Rings General Measurement Device and Calibration Topics 3
Marc Tearing Apart a McAfee Hard-Sell Anti-Virus Ad After Work and Weekend Discussion Topics 6
Jen Kirley Trying to back up a dead hard drive - how to do it? Coffee Break and Water Cooler Discussions 17
S Auslogics Defrag - Hard Drive Defragmentation After Work and Weekend Discussion Topics 9
J U.S. National Archives offers reward for missing hard drive After Work and Weekend Discussion Topics 1
C Specification (hardness) for stainless steel SUS 310 3/4 Hard Manufacturing and Related Processes 3
BradM It's a hard luck life Funny Stuff - Jokes and Humour 0
S MSDS Records - Is a hard copy required if I have a scanned copy? Miscellaneous Environmental Standards and EMS Related Discussions 14
I FMEA Detection Rating - What is Soft or Hard? FMEA and Control Plans 7
V Hard copies from 10-20 years ago - Document Control and Retention Times question Document Control Systems, Procedures, Forms and Templates 19
P Six Sigma Certification Test - How hard is the Six Sigma Certification Test? Professional Certifications and Degrees 6
ScottK Disposing of old hard drives - Best method to destroy data? After Work and Weekend Discussion Topics 17
J What Hardness for .090 Thick Silicone Bronze, Extra Hard Temper (cda 65500-h06) Manufacturing and Related Processes 5
M Does ISO9001 require that a hard copy of a signed procedure be kept? Document Control Systems, Procedures, Forms and Templates 7
J MS Windows XP Pro Hard Drive Defrag (defragmentation) question After Work and Weekend Discussion Topics 26
J Engineering having a hard time defining Objectives - ISO 9k2k 5.4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Marc 50th Anniversary of the First Hard Drive - Sept. 13, 1956 After Work and Weekend Discussion Topics 8
J New QA Manager - Top Management is Divided - Between a rock and a hard place IATF 16949 - Automotive Quality Systems Standard 73
M Long hard work pays off - 8 months - ISO9001 Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Need help about being more socialized - Hard to fit into my groups to some extent Career and Occupation Discussions 4
