Hardness Testing E error requirement, Why?
J Allen
During a recent Nadcap audit, the auditor found that we were not address error E or repeatability R as per ASTM 18-08 section A1.5.3.5
I explained that when performing my daily verification, I test two blocks within 10 points of my test required point by taking 3 readings. If the readings fall outside of the tolerance of the hardness blocks, I do not need to perform an error E evaluation as requested by the spec because my procedure does not allow the use of a machine that reads outside the block tolerances. I red tag the machine and call for repair and recalibration.
His write up says my procedure does not address the requirement and issued me a major finding!
If your test always falls within the tolerance of the hardness block you would never have an eror that required a repeatability check.
What am I missing here??? :confused:
Stijloor
Can someone help?
Thank you!!
Stijloor.
andygr
From the Nadcap Audit process you are dealing with a mandatory requirement of the E 18 standard and so you have to perform the daily checks as identified in the standard.
Your only out is to get with the design function that requires the use of the ASTM E 18 standard and have them add the exception to cover you current practice. Short of this you will not receive any satisfaction from the staff engineer or the task group.
The issuance of a major finding would appear to be incorrect IF all that is violated is the lack of the required calculation and your overall hardness check system was in good shape otherwise.
:2cents:
J Allen
I guess that is what it boils down to is whether our procedure addressed it or not. But what doesn't make sense is the fact that I would never have a need to perform a repeatability check if I do not use the machine if it ever fell out of the error E tolerance which could not happen because it never falls out side the hardness block tolerance.
We stated in root cause that we belived we were in compliance because of staying within the block tolerance. Nadcap wants to know why it wasn't discovered in the self audit where it asks if we meet specification requirements. We thought we did which is why we didn't list it as a finding on our internal audit. The response was not acceptable to Nadcap.
andygr
Ahh the old why did you not find it in the self audit question :lmao:
You logically identify why you believed we were in compliance at the time of the self audit and identify you lack of worth and knowledge :truce: adding the C/A to your audit process of contacting the staff engineer for any condition that is not clearly in compliance with the checklist requirement to assure proper compliance before the audit occures.
Most important talk to the staff engineer before you post to assure he/she will sign of on your response. Do not waste a round.
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
O Hardness Testing and Certifying Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Hardness Testing - Rockwell 15T Scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Rockwell Hardness Testing Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Ron Rompen HV Hardness Testing Conversions - CRA 1070, tempered 440-520 HV10 Various Other Specifications, Standards, and related Requirements 2
B Certifying our house for Hardness and Conductivity Testing General Measurement Device and Calibration Topics 8
ScottK Portable Hardness Testing and Testers for Incoming Bar Stock Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
B Portable hardness testing recommendations - Upper Rockwell B scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Hardness Testing - Rockwell C, on 2" OD x 1" ID Tube of SAE 4140 steel Manufacturing and Related Processes 9
Geoff Cotton Vickers hardness testing - Gage R&R Study for Hardness m/c Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Hardness testing of Ceramic Fibre Shapes General Measurement Device and Calibration Topics 1
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M Proper terms for describing Hardness General Measurement Device and Calibration Topics 5
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
S GR&R for Hardness Tester and Arc Spark Spectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
S Portable Magnetic Hardness Testers - Aerospace Manufacturing and Related Processes 4
P Very cheap Hardness Blocks unfortunately without Traceability General Measurement Device and Calibration Topics 11
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Wilson Hardness Tester Model 525 Accuracy/Repeatability issues help General Measurement Device and Calibration Topics 4
Johnnymo62 What oil do I use for our Starrett 3814 Hardness Tester? General Measurement Device and Calibration Topics 1
kedarg6500 CA111-SAE Copper Washer Hardness Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
W MSA on a Hardness Tester to satisfy a Customer who is requiring Hardness Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
Geoff Cotton Measurement Uncertainty (MU) of HR-150A Rockwell Hardness Tester Measurement Uncertainty (MU) 1
M MSA - What method should we use for the stability of hardness? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ASTM Standard for Hardness Spec for 6063 T6 Aluminum Extrusions Various Other Specifications, Standards, and related Requirements 1
Q Definition Rockwell Hardness definitions - BW 96 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
V What should I require of a Heat Treat PPAP? Surface Hardness per SAE J664 APQP and PPAP 1
J Requirements for Hardness of Metrology Instrument Parts General Measurement Device and Calibration Topics 3
Ron Rompen Recommended Rockwell 30T Scale Hardness Tester to verify Incoming Product General Measurement Device and Calibration Topics 1
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
W Cpk for Hardness - PPAP rejected due to no Cpk value being given for a hardness FMEA and Control Plans 10
Ron Rompen Affri MetalTest Portable Hardness Tester Review General Measurement Device and Calibration Topics 1
C MSA for Hardness Machine and Tensile/Compressive Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Any Difference Between Bench Top and Portable Hardness Tester? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Hardness Inspection Test - Rockwell in Lieu of Brinell General Measurement Device and Calibration Topics 6
somashekar Information sharing: Week 22, 2010 (HARDNESS, THREADS, BEARINGS) The Reading Room 3
Q Calibration of Hardness Tester ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Sources of Potential Measurement Variation for Brinell Hardness Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Difficulties in performing MSA on Rockwell Hardness Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
A Cause and Effect Analysis - Hardness of Rubber (i.e., durometer) Quality Tools, Improvement and Analysis 11
I Are there any Procedures or Standard relating to Retesting of Hardness of bolts? Quality Manager and Management Related Issues 5
C Specification (hardness) for stainless steel SUS 310 3/4 Hard Manufacturing and Related Processes 3
A Calibration of Rockwell Hardness Tester IATF 16949 - Automotive Quality Systems Standard 10
P Micro Hardness Tester Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Rockwell Hardness Testers ? Brand Recommendation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Expiration Date for Standardized Rockwell Hardness Blocks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Certifying Existing Hardness Tester Indenters / Penetrators General Measurement Device and Calibration Topics 9
