Hardness Testing - Low Cpk's using Minitab
Curtis317
Our supplier had provided there test results. Using Mini tab I calculated the Cpk's. Of course with hardness testing the only specification limit is a minimum. But the Cpk's are .96, .7 and .710. that seems extremely low. These are 3 measurements taken on different portions of the part. If we tried asking the supplier to improve the consistency of the hardness would it increase the hardness overall to get a better Cpk? Notes: yes the distribution is normal for all 3 measurements. The Cpk was done on 95 measurements over time.
sitapaty
Re: Hardness testing low Cpk's
Calculation of cpk for a single limit tolerance ie only + side or only minus is theoretically misleading.
Curtis317
Sitapaty, Your comment has no validity. If I redo the calculation with an upper limit the Cpk stays the same.
Most likely the supplier will just increase the hardness.
Reducing variation would be difficult. Have they done an R&R study on the tester? Depending on the type of equipment they might be able to improve (e.g., go from hand held to bench top), but if they are using the latest equipment will be limited.
There is probably considerable within part variation. If there are critical locations, they might improve by specifying a test location. Finally there is usually a lot of part to part variation from the location in the HT oven.
Curtis317
The material is steel that is case hardened. The people who are measuring it specialize heat treatment. So I would think they know what they are doing but do not really appreciate statistics and how it can show you that with a low Cpk you have a potential for 20,000 PPM under specification.
ScottK
Not out of the crisis
You're crunching the data from a process you don't control.
If they don't care about the statistics and only care if they meet a minimum hardness I think it's going to be tough to get the number you're looking for.
Especially if their data say "we've never had a complaint for under spec material so why should I care about this Cpk value?"
You might have to train them and contractually agree, or find another supplier who gets it.
Steve Prevette
Deming Disciple
One thing - have you looked at the time series SPC chart to see if the data are stable and predictable prior to calculation of the Cpk.
First remember the goal- no nonconforming parts. The goal isn't to get a high Cpk. Cpk is a silly number that requires many theoretical things to be met to have real world validity...
Most people don't understand statistics because they are conceptual. You need to make them concrete...graphs of the data do this. Can you provide the data you used with the appropriate labeling so we can plot it in time series with the within piece data identified and maybe even the oven locations and lot numbers? A multi vari chart is the best start for analyzing the capability of a process.
Ron Rompen
Capability on a one-sided specification (where it is possible to go outside of that limit) is very difficult to accomplish. As you know, Cpk is derived (in part) from Cp, and if you do not have an upper and lower limit, you can't calculate Cp. Introducing an artificial limit doesn't help, as it can influence the results without really being meaningful. I do not know of a statistical model which can take something like that into account and still calculate Cp and Cpk accurately.
Have you tried plotting your suppliers measurements as a run chart, with precontrol limits (based on historical data from them) to demonstrate that their process is within control? That may be the easier way to do this.
O Hardness Testing and Certifying Product AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
L Hardness Testing - Rockwell 15T Scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Hardness Testing E error requirement, Why? Various Other Specifications, Standards, and related Requirements 4
J Rockwell Hardness Testing Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Ron Rompen HV Hardness Testing Conversions - CRA 1070, tempered 440-520 HV10 Various Other Specifications, Standards, and related Requirements 2
B Certifying our house for Hardness and Conductivity Testing General Measurement Device and Calibration Topics 8
ScottK Portable Hardness Testing and Testers for Incoming Bar Stock Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
B Portable hardness testing recommendations - Upper Rockwell B scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Hardness Testing - Rockwell C, on 2" OD x 1" ID Tube of SAE 4140 steel Manufacturing and Related Processes 9
Geoff Cotton Vickers hardness testing - Gage R&R Study for Hardness m/c Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Hardness testing of Ceramic Fibre Shapes General Measurement Device and Calibration Topics 1
M Proper terms for describing Hardness General Measurement Device and Calibration Topics 5
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
S GR&R for Hardness Tester and Arc Spark Spectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
S Portable Magnetic Hardness Testers - Aerospace Manufacturing and Related Processes 4
P Very cheap Hardness Blocks unfortunately without Traceability General Measurement Device and Calibration Topics 11
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Wilson Hardness Tester Model 525 Accuracy/Repeatability issues help General Measurement Device and Calibration Topics 4
Johnnymo62 What oil do I use for our Starrett 3814 Hardness Tester? General Measurement Device and Calibration Topics 1
kedarg6500 CA111-SAE Copper Washer Hardness Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
W MSA on a Hardness Tester to satisfy a Customer who is requiring Hardness Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
Geoff Cotton Measurement Uncertainty (MU) of HR-150A Rockwell Hardness Tester Measurement Uncertainty (MU) 1
M MSA - What method should we use for the stability of hardness? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ASTM Standard for Hardness Spec for 6063 T6 Aluminum Extrusions Various Other Specifications, Standards, and related Requirements 1
Q Definition Rockwell Hardness definitions - BW 96 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
V What should I require of a Heat Treat PPAP? Surface Hardness per SAE J664 APQP and PPAP 1
J Requirements for Hardness of Metrology Instrument Parts General Measurement Device and Calibration Topics 3
Ron Rompen Recommended Rockwell 30T Scale Hardness Tester to verify Incoming Product General Measurement Device and Calibration Topics 1
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
W Cpk for Hardness - PPAP rejected due to no Cpk value being given for a hardness FMEA and Control Plans 10
Ron Rompen Affri MetalTest Portable Hardness Tester Review General Measurement Device and Calibration Topics 1
C MSA for Hardness Machine and Tensile/Compressive Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Any Difference Between Bench Top and Portable Hardness Tester? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Hardness Inspection Test - Rockwell in Lieu of Brinell General Measurement Device and Calibration Topics 6
somashekar Information sharing: Week 22, 2010 (HARDNESS, THREADS, BEARINGS) The Reading Room 3
Q Calibration of Hardness Tester ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Sources of Potential Measurement Variation for Brinell Hardness Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Difficulties in performing MSA on Rockwell Hardness Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
A Cause and Effect Analysis - Hardness of Rubber (i.e., durometer) Quality Tools, Improvement and Analysis 11
I Are there any Procedures or Standard relating to Retesting of Hardness of bolts? Quality Manager and Management Related Issues 5
C Specification (hardness) for stainless steel SUS 310 3/4 Hard Manufacturing and Related Processes 3
A Calibration of Rockwell Hardness Tester IATF 16949 - Automotive Quality Systems Standard 10
P Micro Hardness Tester Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Rockwell Hardness Testers ? Brand Recommendation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Expiration Date for Standardized Rockwell Hardness Blocks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Certifying Existing Hardness Tester Indenters / Penetrators General Measurement Device and Calibration Topics 9
kedarg6500 Potential Failure Mode - Mix Charge for Hardness - Casting Process FMEA and Control Plans 1
E Units of Measure for Case Hardness such as HV, HRB, HRC, etc. Various Other Specifications, Standards, and related Requirements 7
J How to calibrate Hardness Rockwell, Brinnell & Vickers Tester machine General Measurement Device and Calibration Topics 5
