Has anyone heard of Run at Risk?
ScottK
Not out of the crisis
#11
Honestly, how is this different than sampling inspection?
If you're checking a critical feature hourly for example, you are "running at risk" in the 1 hour interval between checks. Standard practice is that if it fails an hourly check, everything run in the prior hour is suspect. I would hope that a failure on your CMM layout would trigger a similar reaction.
Run at risk, in my experience, means running without first piece or setup approval.
And not everyone does in-process inspection so sometimes a whole run can be at risk.
For Example - I worked for a time in Chemical Packaging. The bulk chemicals were supposed to be tested in the lab prior to packaging. But if there was an urgent need for the product, production could package the chemicals while the bulk test sample was in the lab queue. The packaged chemicals would be packaged but blocked from shipping until the lab testing was approved. There was no in-process check for chemical characteristics so the risk is that the whole lot could be rejected.
Matt's Quality Handle
#12
Exactly.
The risk is the scrap cost of the production during the checked time period. Multiply that by the probability (based on process history) of encountering a failure would give the expected cost of running at risk. Management should compare that to the cost of the 30 minutes of downtime, and decide accordingly.
All of this however assumes that:
1) Traceability is robust - You'll be able to contain all product produced during the at risk period
2) Management is honest - For example, if you produce $eleventy billion worth of product at risk, management won't say that it's too expensive to scrap if the CMM layout is bad.
I've authorized production to run at risk in some of these situations:
Gage is unavailable - Production started without a dimensional gage. They were allowed to send their first piece to CMM instead of the form gage. They produced parts while the ~30 minute CMM program was running.
Gage is out of calibration - The gage was used, but samples retained for CMM measurement at the end of the run.
#13
I can't say that it's common practice in my experience, but it does happen. The concept of "risk" assumes that the probability of something bad happening has been weighed and the risk has been found to be acceptable (or not). If it's done by the seat of the pants and a roll of the dice, it's not good practice, but if the risk has been properly assessed and potential effect on the customer is negligible, why not?
Johnnymo62
Haste Makes Waste
#14
I think that if you are not working under a QMS like ISO 9001:2015, you can do and make up whatever you want. If you are under a QMS then you are currently not producing to the documented processes. You need a CYA. If under a QMS you should have a process to deal with nonconforming material, like red tags and MRB sign off, etc. Whether the CMM layout passes or fails you have prevented shipping before knowing the results. Pass or fail, either way, you can have buy in and sign off at MRB to CYA.
Rich Shippy
#15
I have also recently heard this term and used in the same context you are describing. I recall years ago the term "positive recall" was used, to address the situation of running product before material certs, or COC's were obtained.
qualprod
#16
This is a increasingly used (almost daily) method at the plant I am in currently.
Production upper management deciding to "run at risk" while awaiting completion of first piece inspection. Blaming it on urgency to ship.
First piece has to include a check on the CMM which takes longer than just the dimensional gaging.
It can be managed with some customers, since exist an AQL established, so both are agree that some percentage of products might be bad, and under this zone they are working, on the other hand if this not the case, this relationship ship will not last too much. My two cents
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Has anyone heard of the 2 pan system? Manufacturing and Related Processes 6
P Has anyone ever heard of the Eastern Weighing and Inspection Bureau? Calibration and Metrology Software and Hardware 1
D ?Pa? Capability Index - Has anyone ever heard of this? Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Has Anyone Heard of Quality University (Online Courses) Training - Internal, External, Online and Distance Learning 2
P Has anyone ever heard of "Quality Gates" (Volkswagen term?) - APQP and PPAP APQP and PPAP 11
I Has anyone ever heard of Registrar QSRD-International? Registrars and Notified Bodies 36
C Has anyone ever heard of Informance software? Monitors machine uptime/downtime (OEE) Preventive Action and Continuous Improvement 11
P Has anyone heard of backwards traceability? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
Q The Thomas Institute - Has anyone heard of or used the Thomas Institute? Professional Certifications and Degrees 5
Q Has anyone heard of DST-PDCA or Cap-Do? Quality Tools, Improvement and Analysis 4
D "Bake Test" for a Matte Finish Tin Coated Product - Has anyone heard of this? General Measurement Device and Calibration Topics 1
T Has anyone heard of or used ITAZ doQuments for document control? Document Control Systems, Procedures, Forms and Templates 1
GStough Has Anyone Heard of Mil Std 155D? Various Other Specifications, Standards, and related Requirements 4
K Has anyone heard of Global MMOG LE? Customer and Company Specific Requirements 9
R Has anyone heard about ISO/TC 099? Other ISO and International Standards and European Regulations 1
P Has anyone ever heard of a Certificate of Quantity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Has anyone heard of "drop gauge policy"? If so, can you tell us what it means? General Measurement Device and Calibration Topics 17
G Has anyone heard of the Squeglia Zero (c=0) Acceptance Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S AIAG PPAP 4th Edition - Has anyone heard what the change(s) will be? APQP and PPAP 42
R QS9000 Software - Has anyone heard about QSP a UK Package QS-9000 - American Automotive Manufacturers Standard 0
A Has anyone heard anything about the Financial Industry standard FS9000 Various Other Specifications, Standards, and related Requirements 5
S Has anyone ever heard of an International Standard for date sequence? Other ISO and International Standards and European Regulations 2
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
M Has anyone here assessed the latest Abbreviated 510(K) guidance document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
K Has anyone used QAI for training? Training - Internal, External, Online and Distance Learning 7
D Has anyone here had any experience with PQ-FMEA software? FMEA and Control Plans 1
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
S Has anyone created a Turtle Diagram reflecting the new ISO 9001:2015 Structure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Has anyone done a Gage R&R for Spectrophotometer? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
T Has anyone completed the AS9100D Quality Manual transition? Quality Management System (QMS) Manuals 1
D Has anyone taken the AS9100 Delta course / exam? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
D Medica show in Dusseldorf - Has anyone else gone? Other Medical Device and Orthopedic Related Topics 3
A AS9100C to D - Has anyone done a gap analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Has anyone been through the ISO 14001:2015 process? ISO 14001:2015 Specific Discussions 12
Marc Has anyone here gotten Gigabyte Fiberoptics (Internet) to home? Coffee Break and Water Cooler Discussions 3
M Has anyone had their electronic system scrutinized in an FDA inspection? Records and Data - Quality, Legal and Other Evidence 16
M Has anyone successfully challenged the new IATF site extension change? IATF 16949 - Automotive Quality Systems Standard 36
R Does anyone know why the TC 176 website has been hijacked by CSA? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
GStough Rx-360 - Has Anyone Used This and What Was Your Experience? Supplier Quality Assurance and other Supplier Issues 3
A Has anyone made an ISO9001:2015 vs. ISO9001:2008 Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
I Has anyone read BIP 0115:2014? ISO 13485:2016 - Medical Device Quality Management Systems 5
optomist1 Has anyone recently taken the GD&T ASME Y14.5M Certification Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Has anyone considered what logic is? Coffee Break and Water Cooler Discussions 23
