Has anyone made an ISO9001:2015 vs. ISO9001:2008 Matrix
Marcelo
#21
Well, I would say it?s a little more difficult than that.
In past standards, the role of the management representative was created to shield/separate top management from the QMS (as the management representative was the QMS "process" owner and thus responsible for the QMS). So, effectively, although top management in general was required to show commitment, they were not required to be all accountable or responsible for the system (only the management representative was responsible). Now they are required to be accountable.
However, they still are not required to be responsible. This is still open when the draft say:
Top management shall assign the responsibility and authority for:
- ensuring that the quality management system conforms to the requirements of this International Standard;
- ensuring that the processes are delivering their intended outputs;
- reporting on the performance of the quality management system, on opportunities for improvement and on the need for change or innovation, and especially for reporting to top management;
Those are still the same QMS "process" owner responsibilities from the past, only now, they do not need a function called management representative for it.
So I don?t think that?s really a change, and it?s even a little worse, because the management representative had to be part of management before (and thus at least some top management would be responsible), and the revised requirement don?t even require that!
John Broomfield
#22
Marcelo,
Thank you. Would you please comment on top management being responsible for the "quality performance" of their organization?
Do you share my view that this is more than the performance of the QMS?
John
Marcelo
#23
John
No. If I understand you comments correctly, you are basing this assumption in the following requirements:
Top management shall demonstrate leadership and commitment with respect to the quality management system by:
- taking accountability of the effectiveness of the quality management system;
- engaging, directing and supporting persons to contribute to the effectiveness of the quality management system;
However, and there?s the catch, I think, they are not required to be responsible, only "accountable"! There?s no definition of accountability in the series (even in this document - http://www.iso.org/iso/03_terminology_used_in_iso_9000_family.pdf), so, using the general idea of the word, I would assume that the accountability requirement in this particular case related to top management "being required to explain actions or decisions to someone" (for example, shareholders).
Accountability can also be interpreted as "required to be responsible for something", but I don?t think it fits this case, because there are clear requirements for responsibility and authorities in 5.3, and if you take a look at that, you will note that top management is required to assign QMS responsibility to someone (which can be someone else, even outside top management the way the requirement is written now).
Regarding the "- engaging, directing and supporting persons to contribute to the effectiveness of the quality management system", I do agree that this changes the role of top management to a little more active role, but this still do not require responsibility.
Also, I do not think "quality performance" means more than the QMS.
Performance was not defined in ISO 9000, but is defined now in the ISO 9000 DIS as
3.7.9
performance
measurable result
Note 1 to entry: Performance can relate either to quantitative or qualitative findings.
Note 2 to entry: Performance can relate to the management (3.3.3) of activities, processes (3.6.1), product (3.7.6) and services (3.7.7), systems (3.4.1) or organizations (3.2.1).
So, when I read "quality performance", I understand "measurable results related to quality. In my opinion, this would still only be constrained inside the QMS.
John Broomfield
#24
Marcelo,
Thanks, but you did not refer to clause 7.2.
Clause 7.2 refers to the quality performance of the organization.
Being as the organization is run by top management, they must be competent.
Who is going to verify their competence beyond the Board of a Directors?
Who, within the organization, is going to audit this?
I'm suggesting that a top manager would.
John
Marcelo
#25
John
7.2 in the draft is related to competency. The requirement was moved from 6.2.2 from the old version due to the restructuring.
The old requirement is
The organization shall
a) determine the necessary competence for personnel performing work affecting conformity to product requirements,
The revised requirement in the draft is:
The organization shall:
- determine the necessary competence of person(s) doing work under its control that affects its quality performance
My opinion is that is in practice the same requirement, with some polishing of words to accommodate the new "quality performance" "definition".
The organization is run by top management, but as I mentioned on the previous comments, the standard still seem to separate top management from the QMS.
So, unless you are saying that the 2008 version required to evaluate top management competency, I don?t see why this version would.
Paul Simpson
#27
Hi, Marcelo. Generally I agree with your approach on this. :applause: The standard is little changed in terms of hard requirements for the organization's leaders. I did have a slight issue with the following snip:
<snip>In past standards, the role of the management representative was created to shield/separate top management from the QMS (as the management representative was the QMS "process" owner and thus responsible for the QMS). So, effectively, although top management in general was required to show commitment, they were not required to be all accountable or responsible for the system (only the management representative was responsible). Now they are required to be accountable.</snip>
It is true that the MR role has disappeared but the original intention for the MR was not to act as a shield - far from it. :frust: The idea was that there would be a member of the top management team who would speak to his / her peers about the QMS. There has been a lot of debate about what 'a member of the organization's management' means here and elsewhere but the intent was for a conversation between equals.
Whether the new requirements for 'Leadership and commitment' address the need better than the old MR requirements we will see soon enough. :notme:
L
lk2012
#28
Here are the most significant changes from ISO 9001:2008 according to the DIS.
It looks as if the internal audit team should include at least one top manager.
I'm especially delighted to see this:
'Top managers are required to engage in the most important QMS activities...'
that means they can't shirk it anymore and treat the QA as a nuisance. <insert mad laughter> :whip:
Big Jim
#29
The way that I look at the role of the Management Representative is more like he is assigned to shepherd the quality management system. The concept of being a shield I would put more as how many less enlightened top managers applied it.
In general, top managers are better equipped to make sure the quality management system is functioning well, and the idea that it is up to them to determine what other leadership is needed is much more fitting than it was in 1987.
Marcelo
#30
It is true that the MR role has disappeared but the original intention for the MR was not to act as a shield - far from it. The idea was that there would be a member of the top management team who would speak to his / her peers about the QMS. There has been a lot of debate about what 'a member of the organization's management' means here and elsewhere but the intent was for a conversation between equals.
Hi Paul
Yes, "shield" was not a good word, what I wanted to say is that the requirement in effect "separated" top management from the other requirements for the QMS besides Clause 5 (meaning for example, in this case, the need for top management to show competency for quality related matters).
If I remember correctly, the original requirement comes directly from BS 5750-1:1979 and had not changed that much throughout the years:
The supplier should appoint a management representative (preferably independent of other functions) who shall have the necessary authority and the responsibility for ensuring that the requirements of the standard are implemented and maintained.
M Has anyone made a DCX PSO plant book? Customer and Company Specific Requirements 1
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 15
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
L Has anyone heard of the 2 pan system? Manufacturing and Related Processes 6
M Has anyone here assessed the latest Abbreviated 510(K) guidance document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
K Has anyone used QAI for training? Training - Internal, External, Online and Distance Learning 7
D Has anyone here had any experience with PQ-FMEA software? FMEA and Control Plans 1
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
S Has anyone created a Turtle Diagram reflecting the new ISO 9001:2015 Structure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Has anyone done a Gage R&R for Spectrophotometer? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
T Has anyone completed the AS9100D Quality Manual transition? Quality Management System (QMS) Manuals 1
D Has anyone taken the AS9100 Delta course / exam? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
D Medica show in Dusseldorf - Has anyone else gone? Other Medical Device and Orthopedic Related Topics 3
A AS9100C to D - Has anyone done a gap analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Has anyone been through the ISO 14001:2015 process? ISO 14001:2015 Specific Discussions 12
Marc Has anyone here gotten Gigabyte Fiberoptics (Internet) to home? Coffee Break and Water Cooler Discussions 3
M Has anyone had their electronic system scrutinized in an FDA inspection? Records and Data - Quality, Legal and Other Evidence 16
P Has anyone ever heard of the Eastern Weighing and Inspection Bureau? Calibration and Metrology Software and Hardware 1
M Has anyone successfully challenged the new IATF site extension change? IATF 16949 - Automotive Quality Systems Standard 36
R Does anyone know why the TC 176 website has been hijacked by CSA? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
GStough Rx-360 - Has Anyone Used This and What Was Your Experience? Supplier Quality Assurance and other Supplier Issues 3
I Has anyone read BIP 0115:2014? ISO 13485:2016 - Medical Device Quality Management Systems 5
D ?Pa? Capability Index - Has anyone ever heard of this? Capability, Accuracy and Stability - Processes, Machines, etc. 5
optomist1 Has anyone recently taken the GD&T ASME Y14.5M Certification Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Has anyone considered what logic is? Coffee Break and Water Cooler Discussions 23
Jim Wynne Has Anyone Had Trouble with IMDS 8.0? RoHS, REACH, ELV, IMDS and Restricted Substances 17
G Has anyone used shlomo Aviv-lean consultant? Lean in Manufacturing and Service Industries 1
M Has anyone purchased their powerball tickets? 17 May 2013 Coffee Break and Water Cooler Discussions 8
T Has anyone done both Quality and Facility Security Officer (FSO) roles ? Career and Occupation Discussions 8
M Has anyone used SGS as a CB (Certification Body)? Registrars and Notified Bodies 4
R Mix Multi-Site/Individual Certification - Has this ever happened to anyone? Miscellaneous Environmental Standards and EMS Related Discussions 14
B Has anyone used Arena Software Simulation? Process Maps, Process Mapping and Turtle Diagrams 10
C Has anyone used GageWare Software? Quality Assurance and Compliance Software Tools and Solutions 4
M Has anyone used "Paradigm 3" software to Control their Quality or Management System? Quality Tools, Improvement and Analysis 2
Q Has Anyone Heard of Quality University (Online Courses) Training - Internal, External, Online and Distance Learning 2
P Has anyone ever heard of "Quality Gates" (Volkswagen term?) - APQP and PPAP APQP and PPAP 11
A Has anyone tried a DAC (Digital to Analog Converter)? After Work and Weekend Discussion Topics 5
I Has anyone ever heard of Registrar QSRD-International? Registrars and Notified Bodies 36
M Has anyone of you have experience with the World Class Manufacturing system? Lean in Manufacturing and Service Industries 6
K Does anyone has experience with determining if Lubricants and Greases are Food Grade? Food Safety - ISO 22000, HACCP (21 CFR 120) 6
R SOPs in Manufacturing - Has anyone got a management process that works? Document Control Systems, Procedures, Forms and Templates 4
K Has anyone had experience dealing with SEDEX (Supplier Ethical Data Exchange)? Customer and Company Specific Requirements 4
B Has anyone developed an OHSAS 18001 Safety Management System Balanced Scorecard? Occupational Health & Safety Management Standards 13
