K1,K2,K3 have changed in the 3rd edition. They are just the old numbers divided by 5.15. The 5.15 multiplier has been removed from the formulas- so it should not change your R&R results significantly.
What if a person uses total tolerance for his GR&R?(In contrast to PV) Will this change in the "k"'s affect the outcome of the study more? I have not had time to actually use the new forms furnished. Thank you very much, by the way.
Pat
Pat
I do not think there will be any appreciable difference. Ultimately the standard deviations will be the same. Remember that the 2nd edition considered a 99% as the "full" spread of measurement error. Hence the muliplier of 5.15. The third edition gives you the choice between 99% and 99.73% (Factor = 6) .
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to the use of cookies.
