Having trouble writing a directive (procedure) that points to the right place
biboy2012
I am looking for assistance in writing a conditional if statement in a narrative procedure. Please check my draft of a customer complaint procedure below. I'm having trouble making the flow logical. The directives didn’t point to the right place. For example, the CSR identifies severity level of customer complaint. He/she is allowed to select 3 conditions:
High priority
Medium priority
Low priority
I am not sure if my explanation is clear but you can undersand it from the attached file, a portion of a flowchart.
These tasks are performed whenever a Customer Service Representative recieves customer complaint.
1. Receive customer compalint.
2. Log complaint on the system and indicate all the applicable information with corresponding Ticket Number.
3. Try to solve the issue on his/her own.
If CSR able to solve the complaint, goto task #4. Otherwise, goto task #6.
4. Inform the customer that his/her complaint was resolved through call or email or snail mail.
5. Close the issue by updating the system indicating the remark “Resolved”, actual date of resolution and the department who made the resolution.
End of activity.
6. Identify customer complaint type.
If High Priority?, goto task #7. Otherwise, goto task #______.
7. Tags compliant as “Urgent” and escalate the issue to concerned department (within XX hours)
8. Informs the customer that complaint/s is/are now resolved.
9. Monitor the progress of the complaint.
If complaint resolved?, goto task #10. Otherwise, goto task #_____.
10. Inform customer that his/her complaint is resolved already through call or email or snail mail.
11. Close the issue by updating the system indicating the remark as "Resolved", actual date of resolution and department who made the resolution.
End of activity.
If Medium Priority?, goto task #12. Otherwise, goto task #______.
12. Tag complaint as "Important" and escalate the issue to concerned department (within XX hrs).
13. Inform the customer that complaint/s is/are resolved already.
14. Monitor the progress of complaint.
If complaint resolved?, goto task #15. Otherwise, goto task #_____.
15. Inform customer that his/her complaint was resolved already.
16. Close the issue by updating the system indicating the remarks as "Resolved", actual date of resolution and the department who made the resolution.
End of activity.
If Low Priority?, goto task #17. Otherwise, goto task #______.
17. Tag complaint as "Monitor" and escalate the issue to concerned department.
18. Ask feedback to the concerned department about the escalated complaint.
19. Inform the customer that complain/s is/are resolved already.
20. Monitor the progress of the complaint.
If complaint resolved?, goto task #21. Otherwise, goto task #_____.
21. Inform customer that his/her complaint was resolved already thru call or email or snail mail.
22. Close the issue by updating the system indicating remarks as "Resolved", actual date of resolution and the department who made the resolution.
End of activity.
Any help would be greatly appreciated.
Randy Lefferts
Re: Having trouble writing a directive that point to the right place
High priority
Medium priority
Low priority
End of activity.
End of activity.
End of activity.
End of activity.
It appears your difficulty is that High, Medium and Low priorities are not tagged with anything. Because they aren't actually a task, when you attempt to check if a high priority and they find that it isn't, you are trying to then send them to a task, which you can't since you have still to determine if the priority is either a medium or low priority, and so on.
Perhaps add a section tag to the high, med and low priority lines and then instead of sending them to a task in the narrative, send them to the section.
End of activity.
Section 1: If High Priority?, goto task #7. Otherwise, goto Section #__2____.
End of activity.
Section 2: If Medium Priority?, goto task #12. Otherwise, goto Section #__3____.
End of activity.
Section 3: Low Priority, goto task #17.
End of activity.
That fills in half the blanks. The remaining blanks are unable to be filled because there isn't an activity to send them to. Define what happens when you are unable to resolve complaints. The remaining blanks should send them to that new activity.
If I have totally misunderstood what you were asking, disregard what I posted. :)
RCW
Questions: Have you had the people in your company responsible for this process review this flowchart information yet? Could they follow the flow? As they are the ones most familiar with your business, be sure to get their input and feedback. Something might jump out at them a lot quicker than it would to any of us here.
biboy2012
Yes, we have. But I was not asking people here to check each task making sure the details is correct and consistent. Basically I was asking is to help me in writing a conditional statement that allows process owner to reach 3 different tasks.
Q
Quality_Steve
End of activity.
So what I am reading is
>CSR can't solve the problem
>CSR tells the department responsible for the problem
>CSR tells the customer it's all better
>CSR finds out if problem is actually solved
Shouldn't the Corrective Action Verification come before telling the customer the problem is fixed?:popcorn:
biboy2012
Right, but ignore (for now) the level of detail and correctness of the procedure. I have attached the draft of the complete process flow.
Is the flow logical? – Yes, the flow is logical by looking at it.
When it comes to this flowchart, I'm fine, but with regard to writing a narrative procedure with decision box, I can’t figure how all directives point to the right place given the 3 conditions (high priority, medium priority, low priority). If statement is answerable with a Yes/True or No/False.
Give me a popcorn. :D
W
widetrack
you are asking for a yes/no branch, however your flow chart does not use a yes/no branch at the decision block for priority type. the decision has 3 options as charted. should it not be is priority high, if no then next block, is priority medium, yes or no for low.
Q
Quality_Steve
I agree with widetrack.
:agree1:
biboy2012
Agreed. That's what I did in narrative procedure. Refer to OP for the draft procedure. But by looking at it you'll see that the trouble is about pointing directives to the right place out of 22 tasks/steps.
For example:
If High Priority?, goto task #7. Otherwise, goto task #______. (Task # what?)
If Medium Priority?, goto task #12. Otherwise, goto task #______. (Task # what?)
If Low Priority?, goto task #17. Otherwise, goto task #______. (Task # what?)
Q
Quality_Steve
I would consider writing it so if a low priority issue is not solved sufficiently within the allotted time it is escalated to a medium priority and if the problem is still not solved escalate to a high priority. Once you have reached the high priority level you should have your best resources working on it.:2cents:
H Still having trouble as to what equipment falls under 8.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Having trouble with corrective action on external audit nonconformance Nonconformance and Corrective Action 8
Y Goals and Objectives - I am having trouble defining new goals and objectives Other ISO and International Standards and European Regulations 9
NDesouza No Quality Professional vs Having a Quality Professional Benchmarking 24
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
O Inspecting paint and having workable standards in the supply chain Supplier Quality Assurance and other Supplier Issues 1
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
N GDP - Having to provide a reason when writing N/A? ISO 13485:2016 - Medical Device Quality Management Systems 1
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
D Having got ISO 13485:2016 are you dropping ISO 9001? ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Partial non applicability of ISO 9001 Cl. 7.1.5 (not having services)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Not having an internal audit during the year ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Having Fun While Learning ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
I Not having "effectiveness" in the Quality Policy ISO 13485:2016 - Medical Device Quality Management Systems 8
U Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
M How to compare 2 independent samples having 3 factors 3 levels Statistical Analysis Tools, Techniques and SPC 5
W Thoughts on having Safety Shower in ISO Class 7 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 5
T Customer Escape of a part having features reversed 180 degrees Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
ScottK Is anyone else having problems uploading Proprietary Names into the DRLM? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Calibration Standards - Master weight having more tolerance than our gram scale General Measurement Device and Calibration Topics 3
S Minor NC for Not Having Management Review When Scheduled Management Review Meetings and related Processes 12
B Example of Production Process Change having Significant Consequences AS9100C 7.5.1.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C Can a Company get away with not having Employees Trained to the Processes they use? Training - Internal, External, Online and Distance Learning 2
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
J Ever heard of having a Controlled SOP template? Document Control Systems, Procedures, Forms and Templates 12
J What is the advantage of having an NCA 3800 Quality Certificate Various Other Specifications, Standards, and related Requirements 3
N Benefits of having an EDMS in a Construction Company Various Other Specifications, Standards, and related Requirements 5
S CE Label having the indication for the applied part EU Medical Device Regulations 7
Marc Florida Professor Arrested for Having a "Suspicious" Bagel on a Plane Travel - Hotels, Motels, Planes and Trains 14
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
D What is the basis for having 1 or 6 Quality Manuals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Having quality in your resume in today's economy. Imported Legacy Blogs 3
C What is the Purpose of or Requirement for having a Gage Glossary? IATF 16949 - Automotive Quality Systems Standard 2
I Not having Training Records for Documentation Changes - ISO 13485 Clause 4.2.3 Document Control Systems, Procedures, Forms and Templates 22
C Objective Evidence of Internal Auditors having Audit Clause 4.1. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S Feasibility of having one Quality Manual that documents 2 businesses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ajit Basrur Anyone having procedure on "Handling Regulatory Audits" ? US Food and Drug Administration (FDA) 2
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
Q 510k for Exempt Class I Medical Device - Industry Advantage to having a 510k Approval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
L Having faith in your Layered Process Auditors - Pencil whipping audits Process Audits and Layered Process Audits 8
P Having only influential control for some Legal needs. Miscellaneous Environmental Standards and EMS Related Discussions 2
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Advantage of having 2 marks - RvA and ANAB, for example Registrars and Notified Bodies 5
L Objectives: Measurable or having a tangible value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Evaluate Customer Satisfaction without having to send questionnaires Supplier Quality Assurance and other Supplier Issues 2
eternal_atlas Is not having a controlled copy of ISO 9001 standard a NonConformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 114
Ajit Basrur Anyone having ppt file on Advisory Notices ? ISO 13485:2016 - Medical Device Quality Management Systems 2
Ajit Basrur Can you recommend websites having GMP posters? Training - Internal, External, Online and Distance Learning 6
