Heat Treat Calibration Records - API 6a sec 5.8 and annex M Requirements
L
lilly35
was wondering does API 6a sec 5.8 and annex M heat treating equipment qualification does this section only pertain to manufactured parts getting heat treatment after machining or is it when raw material is purchased with heat treat tempature requirments. because if its needed through raw material purchase im having problem gettting calibration records due to steel suppliers purchase out of country. i had one audtor tell me doesnt matter and an API auditor say no because it impossible to recieve from raw material suppliers but yes if you do it after machining stage. can anyone shed any light on this thanks.
Stijloor
was wondering does API 6a sec 5.8 and annex M heat treating equipment qualification does this section only pertain to manufactured parts getting heat treatment after machining or is it when raw material is purchased with heat treat temperature requirements. because if it's needed through raw material purchase I'm having problem getting calibration records due to steel suppliers purchase out of country. I had one auditor tell me doesn't matter and an API auditor say no because it impossible to receive from raw material suppliers but yes if you do it after machining stage. can anyone shed any light on this thanks.
Can someone with API (heat treat) expertise help?
Thank you.
Stijloor.
Billy M
The heat treating is for parts that are being manufactured, not raw material. Section 5.8 refers to Production furnaces used for parts, test coupons, or qualified test coupons.
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
P NADCAP Certified - Heat Treat Continuous Belt Driven Oven question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Is there a Heat Treat certification that is required at PPAP? APQP and PPAP 4
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
S Special Gages for Measuring Pre-Heat Treat Thread Size Measurement Uncertainty (MU) 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
V What should I require of a Heat Treat PPAP? Surface Hardness per SAE J664 APQP and PPAP 1
L Plug Gages and Tapered Holes - Compensation for Heat Treat Distortion General Measurement Device and Calibration Topics 1
I Medical, Vacuum Heat Treat or Not if Subsequent Finishing Operations are Performed Benchmarking 3
D Foreward Looking KPI's (Key Performance Indicators) - Heat Treat Company Misc. Quality Assurance and Business Systems Related Topics 4
M Heat Treat Data - Best method for determining the capability of a carburizing process Statistical Analysis Tools, Techniques and SPC 3
F Recent ISO 9001 audit - Pallet/spool heat treat records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Is Ford's W-HTX heat treat survey replaced by CQI-9? Customer and Company Specific Requirements 15
D Aircraft Training Standard - TI-2000-01 Training for Heat Treat Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
K I am looking for CQI-9 "Heat treat system assessment" Various Other Specifications, Standards, and related Requirements 3
B FORD Supplier CQI-9 rollout letter, Oct. 16th, 2006 - Heat treat suppliers Customer and Company Specific Requirements 1
B Application of CQI-9 Heat Treat Survey for an Annealing Process - Steel Coils Various Other Specifications, Standards, and related Requirements 8
C 6061-T6 Aluminum - Any reason Heat Treat can't hit Minimum of RB/50? Supplier Quality Assurance and other Supplier Issues 12
L Heat Treat anaylsis quench cracks - Seeking possible causes Various Other Specifications, Standards, and related Requirements 1
T PFMEA for Heat Treat Service Provider - Trying To Develop RPNs FMEA and Control Plans 11
G Does Outsource of Processes refer to things like heat treat of the product? Preventive Action and Continuous Improvement 5
M Control chart application for post heat treat processes Statistical Analysis Tools, Techniques and SPC 4
D Receiving Inspection by Subcontractors? Heat Treat Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
