Heat Treat Data - Best method for determining the capability of a carburizing process
MrKopow1
I am looking for the best method for determining the capability from a carburizing process. In particular I’m concern about hardness data. I understand that the data would produce a non standard distribution but how would you determine the Cpk and Ppk? :thanx:
brahmaiah
Re: Heat Treat Data
The data need not necessarily be non-standard. Cpk calculation may not be possible but Ppk calculation can be done in the normal way. If the carburizing process is under control Cpk caln.can also be done. But we have to see the nature of variation in the data. Here the method picking samples.and the location of samples in the furnace is critical.
V.J.Brahmaiah
MrKopow1
Re: Heat Treat Data
V.J.Brahmaiah
I appreaciate the information, however, how do you handle things like surface and core hardness? They will only get so hard and a normal distribution shows that the parts can achieve a higher than maximum hardness which cause problems with the calculations. Let me know.
Thank you
brahmaiah
Re: Heat Treat Data
Thank you
Since core hardness checking is distuctive test it will not fall into normal Cpk calculation as we need large number of readings. You may go for X-MR control chart which requires ploting at longer intervals normally one per batch.In any cse the key for your problem lies in proces validation and strict control process parameters.If the process is not validated to achieve required results it is not acceptable by the standard.H.T. being a special process 100% inspection is out of question.After validating your process you may use following X-MR control chart to asses the process capability.:
V.J.Brahmaiah
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
P NADCAP Certified - Heat Treat Continuous Belt Driven Oven question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Is there a Heat Treat certification that is required at PPAP? APQP and PPAP 4
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
S Special Gages for Measuring Pre-Heat Treat Thread Size Measurement Uncertainty (MU) 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
V What should I require of a Heat Treat PPAP? Surface Hardness per SAE J664 APQP and PPAP 1
L Plug Gages and Tapered Holes - Compensation for Heat Treat Distortion General Measurement Device and Calibration Topics 1
L Heat Treat Calibration Records - API 6a sec 5.8 and annex M Requirements Oil and Gas Industry Standards and Regulations 3
I Medical, Vacuum Heat Treat or Not if Subsequent Finishing Operations are Performed Benchmarking 3
D Foreward Looking KPI's (Key Performance Indicators) - Heat Treat Company Misc. Quality Assurance and Business Systems Related Topics 4
F Recent ISO 9001 audit - Pallet/spool heat treat records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Is Ford's W-HTX heat treat survey replaced by CQI-9? Customer and Company Specific Requirements 15
D Aircraft Training Standard - TI-2000-01 Training for Heat Treat Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
K I am looking for CQI-9 "Heat treat system assessment" Various Other Specifications, Standards, and related Requirements 3
B FORD Supplier CQI-9 rollout letter, Oct. 16th, 2006 - Heat treat suppliers Customer and Company Specific Requirements 1
B Application of CQI-9 Heat Treat Survey for an Annealing Process - Steel Coils Various Other Specifications, Standards, and related Requirements 8
C 6061-T6 Aluminum - Any reason Heat Treat can't hit Minimum of RB/50? Supplier Quality Assurance and other Supplier Issues 12
L Heat Treat anaylsis quench cracks - Seeking possible causes Various Other Specifications, Standards, and related Requirements 1
T PFMEA for Heat Treat Service Provider - Trying To Develop RPNs FMEA and Control Plans 11
G Does Outsource of Processes refer to things like heat treat of the product? Preventive Action and Continuous Improvement 5
M Control chart application for post heat treat processes Statistical Analysis Tools, Techniques and SPC 4
D Receiving Inspection by Subcontractors? Heat Treat Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
