Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes
qu1nn
Newb question:
If you have a 1.5" x 2"x 6" block of S7 that has been heat treated to approximately Rockwell C50. Knowing that the block (prior to heat treat) is machined into a complex shape and lets say that the thinnest member is 0.25"
Rockwell C testing at various locations gives results from 44-55.
It seems like when testing at the thickest section you will get the lowest reading, whereas testing at the thinnest section (0.25") you will get the highest reading.
for the purpose of this post lets assume that the rockwell hardness tester is perfect.
I understand the following question is vague , and there seems to be a multitude of reasons for hardness changes, but
Could the variance seen (44-55 RHC) possibly be attributed due to the thickness of the material? or is it more reasonable to believe that the variation could it be due to how the piece is heat treated?
Thanks for your time
qu1nn
What type of steel and what type of heat treatment?
If the material is case hardened, you may machine through the case into softer material.
qu1nn
material = S7
Vacuum Heat treat to roughly rockwell C50
The question is not about machining, it is about consistency of rockwell hardness across different depths of material after heat treat.
Qu1nn
I missed your comment that the HT was post-machining.
HT is always a time vs temperature process. Thicker sections require longer times to change temperature during heating and when cooling.
If the process is correctly established, you will have better consistency between sections of different thickness. If the process is poorly established, you can get marked differences between sections.
qu1nn
Thank you for the responses.
what could better consistency mean?
so let me change up my question a bit....
do you think it is even possible to for the material / dimensions (rough, above) to obtain a Rockwell throughout the entire part within a couple of counts (ie C49-C51) even though there are sections of different thicknesses ...
what would be reasonable to expect?
(again errors due to Rockwell measurement tester are not intended to be discussed)
qu1nn
Big Jim
Think of it somewhat as cooking a steak. The thinner portions of the steak cook faster and will be more done than the center portions.
Hardening from heat treating is only a surface hardening. The depth of the hardening will vary from several factors including the thickness of the material, the composition of the material, the oven temperature, the length of time in the oven, and how it is quenched.
Usually, there are two problems with heat treating before machining. First, it makes it harder to machine. Second, the machining removes some of the effects of the heat treatment as it removes surface metal. Machining before heat treatment sometimes causes problems too, in that sometimes the metal warps or distorts. That is why in some critical cases a part may be rough machined, heat treated, then finished machined.
I
iamtroll
Not only would you expect to get natural variation in the hardness of the material, but if you have a .250" cross section that is unsupported over any length, the part may flex under load which I would expect to give you a false hardness reading lower rather than higher as the section gives way. Although you say you are seeing the opposite.
dbulak
I would also consider changing the rockwell scale. Try using a 30N or even a 15N scale on the thiner areas of the part. The readings could be converted back to the C scale.
B Application of CQI-9 Heat Treat Survey for an Annealing Process - Steel Coils Various Other Specifications, Standards, and related Requirements 8
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
P NADCAP Certified - Heat Treat Continuous Belt Driven Oven question AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
V Is there a Heat Treat certification that is required at PPAP? APQP and PPAP 4
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
S Special Gages for Measuring Pre-Heat Treat Thread Size Measurement Uncertainty (MU) 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
V What should I require of a Heat Treat PPAP? Surface Hardness per SAE J664 APQP and PPAP 1
L Plug Gages and Tapered Holes - Compensation for Heat Treat Distortion General Measurement Device and Calibration Topics 1
L Heat Treat Calibration Records - API 6a sec 5.8 and annex M Requirements Oil and Gas Industry Standards and Regulations 3
I Medical, Vacuum Heat Treat or Not if Subsequent Finishing Operations are Performed Benchmarking 3
D Foreward Looking KPI's (Key Performance Indicators) - Heat Treat Company Misc. Quality Assurance and Business Systems Related Topics 4
M Heat Treat Data - Best method for determining the capability of a carburizing process Statistical Analysis Tools, Techniques and SPC 3
F Recent ISO 9001 audit - Pallet/spool heat treat records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Is Ford's W-HTX heat treat survey replaced by CQI-9? Customer and Company Specific Requirements 15
D Aircraft Training Standard - TI-2000-01 Training for Heat Treat Personnel AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
K I am looking for CQI-9 "Heat treat system assessment" Various Other Specifications, Standards, and related Requirements 3
B FORD Supplier CQI-9 rollout letter, Oct. 16th, 2006 - Heat treat suppliers Customer and Company Specific Requirements 1
C 6061-T6 Aluminum - Any reason Heat Treat can't hit Minimum of RB/50? Supplier Quality Assurance and other Supplier Issues 12
L Heat Treat anaylsis quench cracks - Seeking possible causes Various Other Specifications, Standards, and related Requirements 1
Tom W PFMEA for Heat Treat Service Provider - Trying To Develop RPNs FMEA and Control Plans 11
G Does Outsource of Processes refer to things like heat treat of the product? Preventive Action and Continuous Improvement 5
M Control chart application for post heat treat processes Statistical Analysis Tools, Techniques and SPC 4
D Receiving Inspection by Subcontractors? Heat Treat Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
elkel CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
S Heat Map ISO/TS 16949:2009 Clauses IATF 16949 - Automotive Quality Systems Standard 1
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
