Height Gage Compensation Block Calibration
Kingsld1
We have a Mitutoyo LH-600 and a Tesa Hite 600 height gage. These height gages have the capability to touch off on opposing surfaces and report the distance between them.
An artifact comes with the height gages that basically looks like two gage blocks stacked on top of each other with some overlap. You touch off on the downward facing and upward facing surfaces and that sets the effective ball diameter. Once this procedure is done the height gage is ready to measure opposing surfaces.
Does anyone here (especially from Medical Device) have similar height gages and do you have or should you have the artifact calibrated?
BTW, the artifacts are listed as accessories by the manufacturers and do not come with a seperate calibration certificate. Only spec I could get after several calls to tech support is 0.2 MICRON parallelism and 0.1 MICRON flatness
Eredhel
Quality Manager
I'm not in medical but we use "standards" to verify and calibrate our micrometers. The standards are sent out annually to be done to NIST. Do you all have other things you get calibrated outside where you could send that with them?
D Procedure for use of a Digital Indicator and a Height Gage Document Control Systems, Procedures, Forms and Templates 6
R The best brand of Electronic Height Gage Calibration and Metrology Software and Hardware 5
A Extent of Gage R&R necessary on two Digital Height Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Gage Blocks for a Mitutoyo Height Master 515-310 HM-12 General Measurement Device and Calibration Topics 1
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
Z What electronic height gage to buy? (micro-hite, fowler mestra, etc) General Measurement Device and Calibration Topics 6
J Calibration Procedure for Digi-Check style Height Gage General Measurement Device and Calibration Topics 5
E Digital Height Gauge Gage R&R - Need Advise and Help Quick Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
M Maximum Height for the stored material or stock materials Occupational Health & Safety Management Standards 1
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
Q Number of Calibration Verification Points - Calipers, height gages, etc General Measurement Device and Calibration Topics 6
K Average height of adults by sex by state Other Medical Device and Orthopedic Related Topics 10
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
D IPC WHMA-A-620A vs. UL UL468A - Pull Test or Crimp Height Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S How to Locate Parts during Measuring with an Electronic Height Gauge General Measurement Device and Calibration Topics 1
K Measuring of Wire Crimp Height Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
M Uncertainty a Angle using Linear Height (goniometer) Measurement Uncertainty (MU) 2
S Which type of study would be better for Solder Paste Height Measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
P Width comes before height measurements Various Other Specifications, Standards, and related Requirements 2
M Wrong Calibration / Verification Result - Height gauge IATF 16949 - Automotive Quality Systems Standard 6
D Lapping of height stands etc. General Measurement Device and Calibration Topics 1
rivariva Number of decimal places : Gage R and R Using Minitab Software 1
J What Device Should I use for Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Minitab formulas regarding anova gage r&r Using Minitab Software 1
T Borescope Mentor Visual IQ Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Gage R&R IATF 16949 - Automotive Quality Systems Standard 2
D HELP gage card not popping up Using GAGEpack Software 2
F How often should Gage R&R's be updated? Is there a recommended time-frame? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W What is dimensional layout of the gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Does a gage used for a visual verification need to be calibrated? Manufacturing and Related Processes 7
T Gage Numbering Using GAGEpack Software 6
S Gage R&R for inline measuring machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
PastorBee13 Attribute Gage R&R with no bad samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage type and data base maintainence Using GAGEpack Software 2
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Faro Arm, Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Gage Block Grade 1 - Calibration Measurement Uncertainty (MU) 15
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
