Help DOD inspection - Standard temperature calipers should be calibrated at?
megan c
Could somebody help me with standdard temperture calipers should be calibrated at???????????????
DOD requires this info in there caibration reports of inspection equipment.We are going through a pre-award inspection by the dod. WE cant afford to fail.
Southern Girl
Use 68 degrees F and you can not go wrong. Just make sure that is what you are doing and your standards are kept at the same temperature. Good luck with your audit. If that is the only thing that you have to worry about, you'll be fine!
K
Kevin H
Caliper Calibration
Megan, I can't comment about DOD requirements, but I ran an ISO Guide 25 lab for a steel mill - we were testing per ASTM and AMS standards. We calibrated calipers at their usage temperature. For us this was between 60 degrees F and 90 degrees F (which was spelled out in our calibration procedure). They were used for % elongation measurements in tensile testing, and the usage areas were somewhat temperature controlled as they were in an older building that hadn't had its temperature sytem brought up to the best standard.
Ususally in the tests you do, something spells out calibration temperature requirements - look at the tests and see if there are requirements if so, use those. If not I'd report what you're doing, better to report reality and get a corrective action request than to tweak something and run into problems later.
Hope this helps. Kevin
Note: Gage blocks were certified by an independent calibration lab at I believe 68 F. I calcualted the effect of temperature on the gage blocks used based on published coefficients of expansion & determined over the temperature and measurement ranges used for our lab calibrations, the change in length was below the resolution for the calipers. The calculation was maintained as a record within the lab system.
Kevin
Mike S.
Happy to be Alive
68 deg. F seems popular, but I just had my gage block set done by a reputable lab and they were done at 72 F. Considering caliper resolution is limited to .0005" or .001" I'd say 68-72 would be just fine.
Ryan Wilde
Standard temperature of ANY dimensional calibration is 20°C (68°F). Any variance from that temperature adds uncertainty, but does not invalidate the calibration. Your calipers, for instance, do not have the resolution to really show the variance due to temperature in any reasonable environment (example: ± 10°F, measuring at 6 inches, assuming you were using steel gauge blocks, would only bring uncertainty up about 80 µin, or 0.00008 in from doing them in a perfect environment).
But, having said that, I believe that what the DOD is looking for is for you to state your environment at the time of calibration on your certificate, regardless of what temperature it is. I worked at a DOD facility, and we did calipers at 73°F as a regular course of business, and it was well within the DOD required temperature range for doing so. You should have a specified range in your quality system that defines what temperature you have deemed adequate for performing calibrations.
Ryan
Ryan Wilde
Now, I would sweat if my gage block set was calibrated at 72°F. Just the uncertainty added by thermal expansion (supposedly, for steel gauge blocks it is about 6.4µin/in/°F, but NIST states that the uncertainty of that expansion is in the 10% range) would really catch my attention. If I were doing a 1" block, my uncertainty DUE TO TEMPERATURE would be in the 5µin range, which on a Class 2 set is over half of the tolerance.
Ryan
Hershal
Metrologist-Auditor
All branches of the military are currently using ANSI/NCSL Z540-1-1994. Some are also using elements of ISO/IEC 17025:1999. Neither of those Standards provide requirements for specific temperatures.
Southern Girl brought up a good point. If you cal at 20 C or 23 C you can't go wrong. If you are outside that (say 28 C) then the cal may can still be valid but your uncertainties must reflect the increased temp, thermal coefficient of expansion for the gage blocks AND the calipers (different rates by the way), if the tech holds the gage block - even with gloves - there is an expansion factor there also.
If the caliper is only going to .01" then even with all the expansion figured in, you'll be better than 4:1 so just document it under Z540 and go on with life. If you are going much more than that, then calculate the uncertainties and maintain them. You may well be greater than 4:1 anyway, but you'll need evidence.
Hope this helps.
Hershal
Wes Bucey
As an aside:
In my high tech, tight tolerance machining environment, we frequently "normalized" sample, gages, and instruments in a temperature controlled room for 24 hours before making crucial measurements. (the actual temperature is less important as long as EVERTHING is the same)
We were careful not to inadvertently heat anything by touching with hot hands or breath once they were normalized. It took most of the question of coefficient of expansion off the table.
Of course, in most cases, this is overkill unless you are dealing in measurements to fifty millionths of an inch. Going much smaller (nanometers, for example), puts you in the world of electron microscopes.
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
M Thanks for the help Coffee Break and Water Cooler Discussions 0
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Burn out - Tips to help combat QC burnout Career and Occupation Discussions 9
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational From RAPS: Danish Regulators Seek to Help Smaller Companies With EU MDR Compliance Medical Device and FDA Regulations and Standards News 0
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
B [Help] Customer Engagement Survey for MBA Project - due Apr19 Manufacturing and Related Processes 0
B Help with Customer Engagement Survey for MBA Project - due Apr19 General Measurement Device and Calibration Topics 0
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
JoshuaFroud FDA Form MDSAP AU F0029.1.004 - Help with Completion US Food and Drug Administration (FDA) 0
supadrai Aviation MRO Project facility coming to U-Tapao airport in Thailand - Help Career and Occupation Discussions 2
E Small one man shop with QMS (shoptech e2) | AS9100 cert help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 46
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
