Help Engineers understand the differences between Bill of Materials and Routers
auclairdiana
I am working in a start up medical device company that has begun moving from an R & D environment to manufacturing and I'm struggling with a way to help engineers understand the difference between an engineering BOM, manufacturing BOM and a router. We do not have any type of BOM in place at the moment and are trying to develop.
Any suggestions?
Many thanks!
Re: Bill of Materials and Routers
Any suggestions?
Many thanks!
The best solution, if the amount of work permits it, is to have an experienced manufacturing engineer in the house. Trying to teach this type of thing to electrical and mechanical engineers can be a daunting project.
in any event, you won't get anywhere until you construct some kind of sample BOM at the appropriate level of complexity. What you're referring to as an "engineering BOM" is commonly known as an "indented BOM"; it shows the completely hierarchy of component assemblies down to piece-parts. A "manufacturing" BOM, if I understand your usage correctly, is a "collapsed" indented BOM, meaning that it shows only the component assembly levels and not the piece-parts of each assembly. A router, on the other hand, usually just shows the manufacturing sequence, but can become more elaborate showing such things as tooling and gaging used at each step.
If you can't hire a manufacturing engineer (even on a consulting basis), the best thing to do would be to get everyone together and construct an example BOM.
RCW
I have to plead ignorance on the difference between an Engineering BOM and a Manufacturing BOM but here goes on the other difference.
A BOM is a list of components required to manufacture a product. A router on the other hand controls the manufacturing process, guiding the process through each step and allowing an operator to sign off when a step is completed.
I've never seen it done but I would suppose a BOM could be included as part of the router how ever you back yourself into a corner with regards to design changes and revision control.
Did you need more detail than this?
Bogie
Very simplistically, in my company:
An Engineering BOM is a BOM that is not released for production/manufacturing (for experimental or developmental purposes only)
A Manufacturing BOM is a BOM to build sellable product.
A Router is a list of steps/departments, in order from start to finish, that the assembly goes thru to make product.
Of course it gets more detailed once the folks understand these basics, but that is what it boils down to.
Hope this is helpful for your industry.
auclairdiana
My understanding of the differences between a manufacturing BOM and an engineering BOM is the manufacturing BOM will contain all components required to build the final product and an engineering BOM represents only the physical product being engineered, not the packaging or manufacturing consumables. Since we've never had either type of BOM, I've been asked to train the engineers on how to create a manufacturing BOM and router.
auclairdiana
RCW and Bogie: Thanks so much for clarification on the BOM and router. Now I just have to find a way to convey this to our engineers...
RCW
A few words of advice, get your manufacturing people involved in the development of the routers. You want the people who know how to do the actually manufacturing giving their input to the process. This is a recommendation from personal experiece (Don't let the guy who doesn't know which end of the soldering iron to pick up mandate the process!)
JaxQC
Side note on BOMs relating to this is BOM vs. “shop supplies”. One bad habit I often see & have to correct is sticking things in the shop supplies category (misc budget & not in BOM) rather than in the actual BOM for the part.
ie.. cup of oil in every gear box, 2 lbs foam packing, 15” tape each box, plastic pouch on each box to hold bill of lading etc.
The determining factor should be the question “Do I expect this to be with every single product?” If so, it’s a BOM item and cost is tied back to that product. Otherwise
If it’s low volume and your profit margin is high enough you might not really care. Higher volume and having a more exact picture of your true costs not to mention not having a high misc $$$ group at the end of the year that you don’t know where it came from is better.
Teach them correctly right from the beginning.
Good point. :agree1: In addition to other functions, BOMs are used as the basis for determining whether or not a thing can be made/manufactured based on availability of materials. In general, if a tangible item is necessary to the final product it should be accounted for in the BOM.
S Can you help me on manpower planning for Supplier Quality Engineers ? Misc. Quality Assurance and Business Systems Related Topics 4
P AS9101 Supplier Audit Form - Teach and help new engineers at my company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Help with understanding Process Controls Manufacturing and Related Processes 4
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
M Thanks for the help Coffee Break and Water Cooler Discussions 0
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Burn out - Tips to help combat QC burnout Career and Occupation Discussions 19
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational From RAPS: Danish Regulators Seek to Help Smaller Companies With EU MDR Compliance Medical Device and FDA Regulations and Standards News 0
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
B [Help] Customer Engagement Survey for MBA Project - due Apr19 Manufacturing and Related Processes 0
B Help with Customer Engagement Survey for MBA Project - due Apr19 General Measurement Device and Calibration Topics 0
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
