Help me to decide which test to use - If each proportion belongs to the same population
L
loukas
Hi all
Please see the attached table.
I'd like to test if each proportion belongs to the same population.
Can you please indicate which statistical test is the appropriate to use?
Regards
Loukas
indubioush
There is not enough information to understand your question or to answer it. It looks like the proportion is the percent of defects. You cannot determine similarities in population by looking at percent of defects. What is the defect? Is there more than one defect? What attributes were measured?
What is the process? How were the samples collected.? Sequential? Over time?
There is a lot more to real analysis than some statistical test...
L
loukas
Dear indubioush and Bev D,
thanks for your replies.
Let me clarify the table.
The process concerns surgical procedures. The data are operating room times. All data drawn on January 1st, 2015, from 08:00 to 15:00 hours, for the 14 clinics. For example the first row expresses that, from 5745 minutes of surgeries, it was found that the 872 minutes was dead time (e.g. delays). The proportion is the quotient of 872/5745.
I applied to P control chart and found out the the data is over-dispersed, so the Laney P prime chart explains better the process.
My thought is to perform a proportion hypothesis testing (or any other one like ANOVA for example), to find out if each proportion comes from the same population of 51570 minutes and the whole significance interval.
I hope the above are clear to you.
Regards
Loukas
Nice to hear that you are aware of the Laney p prime chart...
Unfortunately no statistical test is appropriate for your data. There is not enough independence and replication in your data set. The issue is that your samples are all from a single day. Data from a single day will not be completely independent from each other.
A control chart from each individual hospital is the appropriate ‘test’ but there must be multiple days involved. Remember that each day will have it’s own common causes of delay (volumes, types of surgery, material delivery, nursing attendance, etc.). So you must collect data over many days (20 or so) to make any reliable conclusions. For cycle times I have found that the I, MR chart is usually best even for proportional data, although the p prime chart is a better choice than the p chart. The p chart requires homogeneity while the p prime chart adjusts for natural non-homogeneity that isn’t handled through rational subgrouping.
‘Hypothesis tests’ such as ANOVA or even the better ANOM for proportions are NOT appropriate when you have more than 3 or 4 comparisons. The probabaility of a ‘false’ positive is just too high once the number of comparisons becomes large. And since the effect of factors that are related to time are involved in this type of situation any point estimate comparison is simply not appropriate.
L
loukas
Dear Bev D hi,
I have a large database of these data for three years, collected daily.
I can make a table collected data in different days.
Then do you think that hypothesis testing for proportion, is applicable for relating each defect with the population?
Regards
Loukas
No. Under no circumstances is a hypothesis test of any kind appropriate for this data.
You will find “Data Sanity” by Davis Balestracci very helpful.
I also suggest you think about waht you really want to know about these surgery functions...that is teh most important step...then what do you think you will do to improve things?
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
A Nonconformity help IATF 16949 - Automotive Quality Systems Standard 5
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A Help needed with locating conector Design and Development of Products and Processes 0
Y CER: can "state of the art" help to make up for literature search on equivalant devices? EU Medical Device Regulations 1
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Help on formulating a LP minimization problem Manufacturing and Related Processes 2
N Help with understanding Process Controls Manufacturing and Related Processes 7
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
M Thanks for the help Coffee Break and Water Cooler Discussions 0
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Burn out - Tips to help combat QC burnout Career and Occupation Discussions 19
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational From RAPS: Danish Regulators Seek to Help Smaller Companies With EU MDR Compliance Medical Device and FDA Regulations and Standards News 0
