Help needed on clauses identification
Jared
Hi everyone,
I've been auditing a data process where I think some automation is needed for a small part which will eliminate some user manual editing. I think there is a risk to the validity of the data when a human needs to make a change. I'm thinking a built in macro can be implemented to eradicate risk.
I have identified this as an OFI rather than a NC and below are the 2 9001 clauses I feel fit the audit finding
6.1 of ISO 9001 - Actions to Address Risks and Opportunities
10.3 Continuous Improvement
Obviously 6.1 covers the risk element but do you think 10. 3 covers the automation (macro) suggestion?
Also I feel there could be a section from clause 8 noted here too.
I would be interested to know what people here think.
Jared
Jen Kirley
Quality and Auditing Expert
Hello Jared,
Would this macro be used for one part or for the system?
If it was for a single part I would think of it as an innovation in design of part or process involved with producing that part.
If the macro was to be used widely, I think 10.3 applies better because I consider that to be a system-related clause.
Hi everyone,
Jared
Was this an internal audit? How did you come about finding the potential weakness? Why do you feel a need to link it to ISO 9001 clauses?
Jared
Hi Jen
Thanks very much for the reply.
The macro is for a single part. Yes I think what you suggest about design makes sense.
I get very overwhelmed with the number of clauses and sub-clauses. Do you think 6.1 fits into my audit finding here?
Jared
Jared
Hi Jim
Thanks for the reply. Yes this is an internal audit. I discovered this weakness by interviewing the auditee. The reason why I want to link my findings to clauses is more for my own learning and also I think if I documented the clauses in the internal audit report it will also help upcoming auditors in my company as we are hoping to grow audit team which at the moment is basically just me.
Jared
Hi Jim
Jared
It sounds like you did a good job on the audit. Discovering system weaknesses is always a good thing. If you base your internal requirements on the clauses of the standard, then you only need to reference your internal requirements in internal audits. In the present case, since there doesn't appear to be a nonconformity, you should document what you found and what's ultimately done about it. If you document continual improvement efforts, that's the place to do it. In other words, your internal audit report should invoke the continual improvement effort.
Jared
Thanks for the encouraging words Jim.
What you say about continual improvement makes sense.
Tagin
I do not think 6.1 is the clause to use. You did not find an issue or OFI in your organization's system of finding and addressing risks.
Instead, you found a process that had a potential to create an error due to human data entry. Therefore, I think he appropriate clause is 8.5.1g:
g) the implementation of actions to prevent human error;
Certainly, 6.1 should be ever present in your mind, as should 10.3, but they are not the clauses specific to this issue/opportunity.
If you thought that your organization's system of finding and addressing risks should have already found this issue (e.g., it should have been in a PFMEA), yet it hadn't, then that would be a different matter, and 6.1 would be more central to the issue.
Jen Kirley
I want to understand this better.
Did you know of this macro while the auditee did not? If that is the case, it does sound like an OFI.
I can offer that I have conveyed many ideas that did not end up in the audit report. Simply because the fact that I knew about idea XYZ did not mean they ended up reported as a system weakness. It just means I have something to offer. Is there a reason they shoud have known/heard about idea XYZ? If so, it sounds like a recordable OFI to me. If not, it seems like you just offered a good idea.
This can make auditing very confusing. It can be be very difficult to know when to call out something officially, and when to just convey an idea as the walking benchmark machines that we very often become.
I think the Internal Auditor's question of "What to do?" becomes one of "What will serve my organization?" primarily. We can certainly discuss clauses but this thread has eventually come down to what sort of finding (if any) this would be.
:2cents:
Jared
Hi Tagin,
Okay what you say there makes sense to me, 8.5.1g fits perfectly.
In terms of addressing risk, top management do look at risk but I discovered this risk on a more micro level and when I see the word risk I tend to jump straight to clause 6.1.
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
A Help needed with locating conector Design and Development of Products and Processes 0
D Help needed for Compliance Road-Map - Startup making their first device (IVD) IEC 62304 - Medical Device Software Life Cycle Processes 1
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W TL9000 transition from 5.5 to 6.0 - help needed TL 9000 Telecommunications Standard and QuEST 1
K Processing Time Tracking Software Program Help Needed Lean in Manufacturing and Service Industries 3
N VDA 1 Critical Characteristics Requirements Help needed VDA Standards - Germany's Automotive Standards 6
G Help needed on 2 TS 16949 Elements - 7.5.5 & 7.5.3 IATF 16949 - Automotive Quality Systems Standard 2
R Excel 2003 and Capability Studies for Dummies - Help needed! Excel .xls Spreadsheet Templates and Tools 4
R ISO 13485 Software Validation Requirements - Help needed ISO 13485:2016 - Medical Device Quality Management Systems 4
D Generating a detailed Process Plan - Help needed Process Audits and Layered Process Audits 6
R ISO 9001 Implementation in the Bus/Coach Industry - Confused and Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
O ISO 9000 section 7.2.1(c) Compliance help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Help needed on the TS 16949 External Auditor Exam IATF 16949 - Automotive Quality Systems Standard 8
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
S Interpreting Level of Confidence - Round Robin for Tensile Testing - Help needed Statistical Analysis Tools, Techniques and SPC 4
J ISO 9001 and Improvement of Business Performance - Research help Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Dew Point Meter: DPL4000 - help needed Manufacturing and Related Processes 1
W Australian Approval for Class I Medical Device - Help needed. Other Medical Device Regulations World-Wide 1
R Student Question - Help needed with statistics questions Statistical Analysis Tools, Techniques and SPC 6
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
P Sample Size Calculation help needed Reliability Analysis - Predictions, Testing and Standards 4
6 Preventive Action - Help Needed. Input for Training and Sustenance Preventive Action and Continuous Improvement 3
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
V Help needed with ISO 14001 Procedures please ISO 14001:2015 Specific Discussions 7
A Help needed for Fighting a specifically identified Organism found during Dose Audit Miscellaneous Environmental Standards and EMS Related Discussions 2
D AASHTO R18 Accreditation (quite similar to ISO 17025) QMS - Help needed ISO 17025 related Discussions 4
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
H Husky 1750PSI Pressure Washer - Help needed! Manufacturing and Related Processes 3
L Medical Device FDA Product Classification help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Trend Review and Process Improvement help needed Capability, Accuracy and Stability - Processes, Machines, etc. 6
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T FDA Single Use Instruments - Classification Help Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T PFMEA of Die casting Process--Help needed? FMEA and Control Plans 5
P Design FMEA (DFMEA) Basics - Help needed IATF 16949 - Automotive Quality Systems Standard 3
K ISO 13485 Audit help needed General Auditing Discussions 20
U Issue with Labelling of Outer Container - help needed for clarification EU Medical Device Regulations 3
B 5 Why help needed Please kindly review Problem Solving, Root Cause Fault and Failure Analysis 15
S Excel Spreadsheet Conditional Formatting help needed Excel .xls Spreadsheet Templates and Tools 12
G Help needed to complete a Financial Audit of a Nonprofit Organization Various Other Specifications, Standards, and related Requirements 7
K Low Volume Products Data Analysis help needed Statistical Analysis Tools, Techniques and SPC 6
somashekar Water and Air Pollution Load Calculations help needed Miscellaneous Environmental Standards and EMS Related Discussions 6
S Master Document Register Project Procedures help needed Document Control Systems, Procedures, Forms and Templates 2
Ajit Basrur Tabulating Improvement Plan Status - Help and suggestions needed Excel .xls Spreadsheet Templates and Tools 9
R Sample Audit Report of an Investment Company - Audit help needed Document Control Systems, Procedures, Forms and Templates 1
E FDA New Product Introduction Regulations help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Process VSM (Value Stream Mapping) help needed Lean in Manufacturing and Service Industries 5
K Virtual DMIS vs. PC-DMIS - Help needed Calibration and Metrology Software and Hardware 3
