HELP NEEDED ! Risk Management Exercise
Hi All - Can anyone help me, I am trying to fill out the exercise attached and I am struggling, I did my company training a while ago, however was then off sick and cannot find my notes ! Any help would be appreciated. The example is relating to a hospital setting, I work for a respiratory device company
Welcome to the Cove. :bigwave: If you could be more specific and tell us what you're struggling with, you'll get better answers.
Hi Jim, Thank you for the welcome !
Im worried I am thinking along the wrong lines when filling out the exercise table, My initial thought on the questions for the first scenario are the following,
So, I need to evaluate the scenario of a product recall.
RISK
(identify)
- A recalled product could be used in a clinical environment
RISK
(to who)
- Patient or clinician
Assess
(impact/likelihood)
X
(1-5)
- Here I am a little confused, is there a scale within ISO14971 ?
Jen Kirley
Quality and Auditing Expert
Welcome Jessicawabbit!
I think you have made it through the first two steps, unless your group wants more detail. (An internally used or externally used product? An accessory or a finished medical device? Maybe you should cite an example product)
As for Assessment Impact/likelihood X (1-5), your organization should have a procedure for identifying that. Under no circumstances should you be required to guess or even estimate.
As for control, there are multiple considerations: preventing product from reaching the clinician, recall process and end users' awareness to prevent inadvertent use. The end user should always be included in considerations for medical devices.
How to monitor/evaluate is not a one-size-fits-all concept. Advice based on ISO 14971 is available here, also here.
I hope this helps.
I am not affiliated with Clever Compliance or San Jose State University.
Steve Prevette
Deming Disciple
I am assuming this is more of a training or classroom exercise than real-world, or is what we referred to as a pre-mortem. The risk may be the recall is not broadcast well, so there for someone uses the recalled device for XYZ. Now the risk - we have to look at how good are our recall practices. Do we know who exactly purchased all devices and can track them down. What if they were resold? We also need to ask - is it a given that a recall has happened, or do we want to say - this is how we avoid needing to do a recall. So we identify what makes up the likelihood. Then comes the severity of the event. If we have a faulty unit out there, that the recall doesn't reach, will it cause a death of a patient? Serious injury? Are there built in safeguards that should mitigate an issue with the unit? I'm bringing in some FMEA thoughts here, but if the point of the exercise is to identify the risk (probability and impact) then this is the general route one would take.
Hi Steve,
Yes, this is a classroom activity, The product is a Nasal High Flow humidifier, used in various clinical settings within hospitals.
In this scenario, what would advise the hazard would be ?
Thank you for your very informative and detailed response, I appreciate the time you have taken to respond to me.
Thank
Jen Kirley
Jessicawabbit, was FMEA covered in your class? What about PHA?
Here in the Cove we are not well prepared to provide details from training we were not present for. You did say this was about product recall, so I found this site for you, also this site.
Steve Prevette
Deming Disciple
Must admit I don't know what a nasal high flow humidifier is, but you have to ask yourself (at least as a bounding question) - what is the worst malfunction that can happen? I suppose it could overheat and send scalding steam into your sinuses. If you say - well no that can't happen because . .. then what is the worst that can happen?
J Help needed on clauses identification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
A Help needed with locating conector Design and Development of Products and Processes 0
D Help needed for Compliance Road-Map - Startup making their first device (IVD) IEC 62304 - Medical Device Software Life Cycle Processes 1
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W TL9000 transition from 5.5 to 6.0 - help needed TL 9000 Telecommunications Standard and QuEST 1
K Processing Time Tracking Software Program Help Needed Lean in Manufacturing and Service Industries 3
N VDA 1 Critical Characteristics Requirements Help needed VDA Standards - Germany's Automotive Standards 6
G Help needed on 2 TS 16949 Elements - 7.5.5 & 7.5.3 IATF 16949 - Automotive Quality Systems Standard 2
R Excel 2003 and Capability Studies for Dummies - Help needed! Excel .xls Spreadsheet Templates and Tools 4
R ISO 13485 Software Validation Requirements - Help needed ISO 13485:2016 - Medical Device Quality Management Systems 4
D Generating a detailed Process Plan - Help needed Process Audits and Layered Process Audits 6
R ISO 9001 Implementation in the Bus/Coach Industry - Confused and Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
O ISO 9000 section 7.2.1(c) Compliance help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Help needed on the TS 16949 External Auditor Exam IATF 16949 - Automotive Quality Systems Standard 8
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
S Interpreting Level of Confidence - Round Robin for Tensile Testing - Help needed Statistical Analysis Tools, Techniques and SPC 4
J ISO 9001 and Improvement of Business Performance - Research help Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Dew Point Meter: DPL4000 - help needed Manufacturing and Related Processes 1
W Australian Approval for Class I Medical Device - Help needed. Other Medical Device Regulations World-Wide 1
R Student Question - Help needed with statistics questions Statistical Analysis Tools, Techniques and SPC 6
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
P Sample Size Calculation help needed Reliability Analysis - Predictions, Testing and Standards 4
6 Preventive Action - Help Needed. Input for Training and Sustenance Preventive Action and Continuous Improvement 3
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
V Help needed with ISO 14001 Procedures please ISO 14001:2015 Specific Discussions 7
A Help needed for Fighting a specifically identified Organism found during Dose Audit Miscellaneous Environmental Standards and EMS Related Discussions 2
D AASHTO R18 Accreditation (quite similar to ISO 17025) QMS - Help needed ISO 17025 related Discussions 4
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
H Husky 1750PSI Pressure Washer - Help needed! Manufacturing and Related Processes 3
L Medical Device FDA Product Classification help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Trend Review and Process Improvement help needed Capability, Accuracy and Stability - Processes, Machines, etc. 6
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T FDA Single Use Instruments - Classification Help Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T PFMEA of Die casting Process--Help needed? FMEA and Control Plans 5
P Design FMEA (DFMEA) Basics - Help needed IATF 16949 - Automotive Quality Systems Standard 3
K ISO 13485 Audit help needed General Auditing Discussions 20
U Issue with Labelling of Outer Container - help needed for clarification EU Medical Device Regulations 3
B 5 Why help needed Please kindly review Problem Solving, Root Cause Fault and Failure Analysis 15
S Excel Spreadsheet Conditional Formatting help needed Excel .xls Spreadsheet Templates and Tools 12
G Help needed to complete a Financial Audit of a Nonprofit Organization Various Other Specifications, Standards, and related Requirements 7
K Low Volume Products Data Analysis help needed Statistical Analysis Tools, Techniques and SPC 6
somashekar Water and Air Pollution Load Calculations help needed Miscellaneous Environmental Standards and EMS Related Discussions 6
S Master Document Register Project Procedures help needed Document Control Systems, Procedures, Forms and Templates 2
Ajit Basrur Tabulating Improvement Plan Status - Help and suggestions needed Excel .xls Spreadsheet Templates and Tools 9
R Sample Audit Report of an Investment Company - Audit help needed Document Control Systems, Procedures, Forms and Templates 1
E FDA New Product Introduction Regulations help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Process VSM (Value Stream Mapping) help needed Lean in Manufacturing and Service Industries 5
K Virtual DMIS vs. PC-DMIS - Help needed Calibration and Metrology Software and Hardware 3
