Help on Medical Device Manufacturing - New Medical Device Company
DDsystems
I started a new medical device company and we are currently going through a 3rd party review for our 510(k). We are a Class II device that uses an iPhone as the main component and has a holder around it. We are also GMP exempt.
My main question is that this is our first time manufacturing a medical device and we are confused on what you can and cannot do. After research it looks like only we have to be registered since we are the final component manufacture. Does that mean we can insert a battery then package the device and we are good to go?
Also onto the manufacturing side, are we able to outsource all the components to whoever we would like and FDA does not care about that? Are we able to create any kind of mold or does it have to be specially made from an approved factory?
Thanks for the help in advance.
Ronen E
Problem Solver
Moderator
Hello and welcome to the Cove :bigwave:
If you have the whole device manufactured somewhere else and all you do is insert a battery and package then I'd tend to think that the facility supplying you with the device (minus battery) should be registered as well, as a contract manufacturer. That would normally require you to register as a specification developer, but since you also perform an assembly step and the packaging you might need to register as a manufacturer as well.
Whoever supplies the components/ingredients to the manufacturer who supplies you the finished device is exempt from registration on account of that activity (if that's what you meant by "outsource all the components to whoever we would like and FDA does not care about that").
Regarding moulding, there are likely to be no applicable specific requirements since (I assume) this is not an invasive device and there are no special cleanliness expectations. However, please note that biocompatibility requirements apply where there is contact between the moulded part(s) and the user.
I hope that helped you a bit, please feel very welcome to post more questions here. If you want to share confidential information and receive more definite answers please send me a private message.
Cheers,
Ronen.
DDsystems
Hi Ronen,
Thank you so much for helping clarify. I have a couple more questions if that is alright.
Anyways, my product is very basic it is a goggle system that holds an iPhone in front of the user's eye so that it can record eye movements. It consists of a frame which houses a little LED system that is powered by a battery. We are a class II device like I stated and we are submitting our 510(k) to a 3rd party.
My question is what is our next steps for production. It is very hard to figure out exactly what FDA is requiring in terms of component manufacturing. We are trying to save money since we are a start up so we don't want to manufacture all ourselves as that would be too expensive. We haven't had good luck with getting a medical device manufacture as they were also very expensive. We are trying to get a regular manufacture that isn't interested in getting registered. So where do we go with it?
Any suggestions would be much appreciated!
Thanks,
Alex Bock
Ronen E
Problem Solver
Moderator
Hi Ronen,
Thanks,
Alex Bock
Hi Alex,
I understand that it might be a little overwhelming for first timers but actually it's quite simple in terms of FDA expectations and what you should or shouldn't do. Component manufacturers are not routinely overseen by FDA, especially where device intended use is straightforward and low-risk. On the other hand, some single entity has to be accountable to the FDA, either you (the legal manufacturer) or a contract manufacturer. In some cases 2 or 3 entities might take on that role in a coordinated, shared manner, but that's normally when a complicated system is at hand. Not in your case.
Your options are either source all the components from non-registered manufacturers and do the assembly in house, registering as the manufacturer; or engage a contract manufacturer who's already registered as such and will (optionally) source the components from their supply chain; or find a non-registered contract manufacturer who's willing to register. You won't be allowed to source a finished product (minus battery) from a single manufacturer who's not registered and not willing to register.
The key is someone needs to be accountable to the FDA over manufacturing a finished device. Inserting a battery does not - in my opinion - constitute manufacturing a finished device out of components. Usually retail packaging of finished devices supplied in wholesale packaging also doesn't qualify for that purpose.
Regards,
Ronen.
I'm curious to know how you established that the device is Class II and GMP exempt?
Julie is right...the very fact that you are submitting a 510(K) you are saying you are a manufacturer introducing a device into the market. All medical devices must follow the QSR's from CFR Part 820. The quality system must be planned, developed and implemented.
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
F MDD Article 12 Labeling Requirements for CE Marked Medical Device - Help CE Marking (Conformité Européene) / CB Scheme 4
A Global Medical Device Quality Compliance Overview Presentation - Help Wanted Other Medical Device Regulations World-Wide 2
R Medical Device Registration and Listing Help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T Risk Analysis help for CE Marking Class I Medical Device ISO 14971 - Medical Device Risk Management 10
E Medical Device Directive 93/42/EEC definitions help EU Medical Device Regulations 3
S Help with EU Medical Device Vigilance Reporting Requirements EU Medical Device Regulations 0
5 Help with Medical Device Class IIa Annex V CE Marking Document Control Systems, Procedures, Forms and Templates 1
N Need Help Preparing for Medical Device Quality Engineer Interview Career and Occupation Discussions 2
S Please help on ISO 13485 medical device related services Other Medical Device Related Standards 1
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
X Help with ISO 13485 Clause 6.4 as it applies to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 25
M Medical Device Regulation in Mongolia - Can someone help? Other Medical Device and Orthopedic Related Topics 3
W Australian Approval for Class I Medical Device - Help needed. Other Medical Device Regulations World-Wide 1
L Medical Device FDA Product Classification help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Medical Device Design and Development Plan Procedures help wanted 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T New Medical Device QA Manager Needs Help Other Medical Device and Orthopedic Related Topics 5
P 510K Help for Individual Medical Device Inventor 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
T US FDA Medical Device Reporting SOP help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Looking for help to give me some idea about my thesis project (Medical Device Design) Design and Development of Products and Processes 3
R Medical device facility validation - Need help ISO 13485:2016 - Medical Device Quality Management Systems 11
F History of Canadian Medical Device Regulations - Help needed Other ISO and International Standards and European Regulations 2
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
L Making a Medical Devices Registration Database - Help and Suggestions Wanted Other Medical Device and Orthopedic Related Topics 2
T SPSS for Analysis of Medical Data - Need help Statistical Analysis Tools, Techniques and SPC 12
F Help with Electrical Safety Testing - Medical Equipment Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Z Conformity Assessment Route from the Medical Devices Directive (93/42/EEC) Help EU Medical Device Regulations 6
E Starting to write a Quality System Manual - Import/export medical devices - Need help ISO 13485:2016 - Medical Device Quality Management Systems 1
W Need help finding medical grade wire Manufacturing and Related Processes 1
A ISO14971:2001 - Risk Management for Medical Devices - Help need copy ISO 14971 - Medical Device Risk Management 10
A Help in rolling out a Quality Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T 5 Why's Help Needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 32
M Lead Auditor Log book Help. General Information Resources 1
J Help Needed Customer and Company Specific Requirements 1
P True position with bonus Excel help Manufacturing and Related Processes 8
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
D Little Help with "Tooling Change Program" for perishable tooling (8.5.1.6) IATF 16949 - Automotive Quality Systems Standard 4
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
A Help required in establishing Laboratory Information Management System as per ISO 17025, Cl.7.11.2 ISO 17025 related Discussions 0
R Help Understanding Current Role; Distributor, Manufacturer, or Importer EU Medical Device Regulations 4
D HELP gage card not popping up Using GAGEpack Software 2
bryan willemot Wanted: in need of start up Lock out Tag out program in Excel or Word, your help is much appreciated Occupational Health & Safety Management Standards 3
L Quality Manual Help for Service Sector/Service Organization (Government Contractor/IT Services) Quality Management System (QMS) Manuals 5
K Help with ISO 14971: Benefit-Risk Analysis ISO 14971 - Medical Device Risk Management 3
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
A Help understanding what it takes to implement a QMS that is ISO 13485 compliant ISO 13485:2016 - Medical Device Quality Management Systems 4
T Need 5 why’s help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
