Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE
PeterLe
Hello everyone! I'm hoping to get some assistance with analyzing a DOE I conducted. I'm a total newbie when it comes to minitab and it's actually my first time using this.
I have 3 factors: RPM level, Nozzle size and Pressure. My output variable is force.
So I got stat-->DOE and create a factorial design. I have no clue what else to input besides changing the number of factors from 2 to 3 and also creating the factors but I have left them as -1 and 1 which the factors above. Should I use numeric, for example typing down the exact case for -1 for pressure? Also I select full factorial design. After this, I'll select "OK."
So after, this I have my output variable as force and I type in my results (attached picture).
Then I'll go: stat --> DOE --> Analyze factorial design. Then I'll type in 'Force (N)' then I'll click okay and I get the results (attached as well). Is this the right output? I'm also not very familiar with what the results say. So I'm befuddled!
Also, I also measured my nominal, how would I incorporate it into my analysis?
Any help would be greatly appreciated!
It is acceptable to retain the coded levels of -1 and 1. If you are only trying to determine what factors are significant and to determine directionality that is sufficient. If you intent to use the final model to make predictions, you must remember that the model applies to the coded levels, not the natural levels.
The results are typical for a saturated design. That is, a design with only one replicate and all possible factors still in the model. There are two possible steps forward.
One would be to repeat the experiment as a second block. That will allow you to analyze all possible terms, including the three way interaction.
The second approach is to remove the three way interaction from the model. Three way interactions are extremely rare for electro-mechanical systems and are of little practical value even if significant. This is not the case for chemical systems. Removing the three way interaction will allow you to evaluate the remaining terms in the model by providing a p-value for each.
Regarding the nominal, if this is the 0 level for all three factors, this can be included in the design as a center point. This will allow you to test for possible curvature.
I analyzed the data that you attached and attached my analysis below. The interaction between RPM and Pressure was significant. I also created a second worksheet that is formatted to allow you to enter the data for a Center Point (all values at level 0). This worksheet has already been defined as a Custom Design, so you should be able to enter the data and begin analysis.
PeterLe
Thank you Miner! I really appreciate all the help you put in. Your input has helped me a lot. I'm still learning more and more about minitab and learning how to do a DOE.
Again, I really appreciate the help and if anything I'll post more if I have questions!
S MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Setting up a Vendor (Supplier) and Internal Audit System - Need help Internal Auditing 4
K Need help in Setting up a Process for Tracking RMAs with Traceability Manufacturing and Related Processes 11
J Need Documents and help setting up a QC program Document Control Systems, Procedures, Forms and Templates 6
J Need help setting up a QC program Document Control Systems, Procedures, Forms and Templates 6
L Senior Project Help - Setting up a calibration laboratory General Measurement Device and Calibration Topics 5
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 15
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
A Nonconformity help IATF 16949 - Automotive Quality Systems Standard 5
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A Help needed with locating conector Design and Development of Products and Processes 0
Y CER: can "state of the art" help to make up for literature search on equivalant devices? EU Medical Device Regulations 1
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Help on formulating a LP minimization problem Manufacturing and Related Processes 2
N Help with understanding Process Controls Manufacturing and Related Processes 7
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
