Hello Covers,
Hope you all are doing great. My thanks in advance to all of you.
I am writing down the exact wordings of API for better understanding.
Audit type - Recertification
Finding type - Minor Nonconformance
Product impact - Potential
Requirement/ MS standard - Program Agreements
Description - A Licensee agrees not to use the API Monogram on products in a fashion likely to confuse customers as to the identity of the actual Monogram Licensee. If another entity’s name is marked on the product, the Licensee’s name and Monogram license number shall be closer to the Monogram than any other marking, and the Licensee’s name shall be larger than the name of any other entity.
Objective Evidence - Product: Ring Joint Gasket - RX50
Job code ref.: XXXX Supplied to customer M/s. ABCD, was marked with customer name ABCD on the product.
The size of marking used for punching the licensee and the customer was 3 mm, which lead to the confusion.
The facility having 2 dot punching machine fitted with 3 mm punch only, no lesser size punch was available with facility.
The marking procedure ref.: XXXX Rev 6 Issue 4 Date 1 Jan 2019 does not address the control on part 2 requirements.
Nonconformance description - API Monogrammed Ring Joint Gaskets do not conform to requirements of Part-2 of the API Monogram Licensing Program Requirements.
