Help with CAPA for an IATF finding regarding inspection documentation
Azaarus
Quality Supervisor for automotive plastic injection molding here. Last week we had an IATF surveillance audit. All in all the audit went well, and we walked away with two minors (one in maintenance and one in quality). I am having a very hard time with trying to come up with a corrective action for the quality hit.
Here is the long story: I have been hounding on my quality team about inspection documentation since I started here in early 2020. I have been asking them to write EVERYTHING down on their in process inspection sheets, including down time, process adjustments, issues, high scrap, visual defects... basically everything. No one was listening. Finally, after I was reviewing the inspection sheets I found that everyone was writing OOT numbers for our coating measurements, not documenting it, not having a supervisor sign off, and not documenting adjustments or additional shots that were checked after adjustments and I lost it. I wrote EVERYONE in the department up. This was about a month ago. They started getting better, but still not doing what I asked, and it came back to bite us.
Jump to last Monday. IATF auditor is here, doing his thing. He was looking over the inspection sheet that was being used at the time, and he pointed out that there were OOT measurements written down. They were signed off by the supervisor, so I know the inspector told the supervisor the numbers were low... but noting else beyond that was documented. No one wrote down that an adjustment was made or that another shot was checked after the adjustment. No notes were written about the adjustment, what was done with the parts to ensure no defects escaped, the timing, how many other parts were checked after, etc. So, we got hit for inadequate inspection documentation and traceability. I 100% agree that we deserved that hit, especially since it has been an ongoing issue for so long.
My problem now is that I can't think of adequate corrective and preventive actions other than retraining and verifying inspection documentation in real time (which I really don't have time for). I don't think it is a systemic issue at all, because we have multiple work instructions on proper procedures and documentation processes for inspection and reaction to non-conforming product, the team has been adequately trained, and they know what they are supposed to be doing, they just don't do it. Can someone, ANYONE, please give me some guidance with this?
Johnny Quality
Azaarus,
What is the reaction plan in your control plan when measurements are OOT? Why was that not done?
Could you give us the non-conformance from the auditor?
Mikey324
Without seeing the process sheet, I wonder if it is in need of revision? Just speculation, but I've seen some of these things so complicated no one even tries to fill them out. Maybe you could look at rearranging the sheet to make it flow more smoothly??
Again, this may not be the issue at all, but it is how we corrected an inspection sheet at my place. This particular form was never completed consistently, specially between inspectors. It was extremely overcomplicated and much of the document wasn't even necessary. We streamlined it, provided training, and problem was solved.
Azaarus
Azaarus,
I do not have the NC from the auditor yet... waiting on corporate to get it in the system.
The (simple version) reaction plan is to:
1. place product on hold (write it down!)
2. inform the supervisor (write it down!)
3. supervisor makes adjustment and signs off on inspection report
4. inspector documents the adjustment that were made
5. inspector measures parts after adjustment and documents measurement
6. product on hold is given a disposition by me.
I have no idea why this wasn't followed. Everyone in quality has been here for some time, and they all know the process. They know where to find the QMS if they need to reference a work instruction. They know that everything needs to be documented. Like I said, I have been having a problem with all three shift inspectors documenting and following procedures correctly, to the point that I recently wrote the whole department up. I need to do something to change the department's mentality, but I am at a loss as to how.
Mike S.
Happy to be Alive
I don't know 16949 requirements, but when 3 shifts worth of people are all refusing to do something you have a serious problem. This isn't isolated. There is a "rest of the story" and you need to find it. Usually 3 shifts of people aren't just doing something that they know is outside the procedures because they are hardheaded jerks.
Perhaps someone above them, their boss maybe, is telling them it's okay?
Does following the procedure prevent them from meeting some other quota?
paccnc
You may want to ask them to answer the Corrective Action. Put the ownership on them for the N/C. You may find the roadblock as to why it isn't being followed correctly.
I have two suggestions:
  • Can you make the form electronic with data validation and mandatory fields when an OOT value is entered?
  • Get them together, present the requirements that MUST be met, and ask them to develop the solution that meets those requirements. This will give them a pride of ownership and make them more likely to use the solution
leftoverture
Hello Azaarus. I work in an injection molding environent also, so hopefully I can provide some insight. First, are you using IQMS? IQMS has an SPC data collection module that makes it much easier to record the data. So if you have IQMS, I would start there. We collect ALL of our inspection data electronically, and our calipers, micrometers, indicators, etc are almost all connected directly to the computer. Makes it real easy.
Beyond that, I usually find that if someone is not following a process (in your case, recording the data and subsequent actions) it's usually because it is not convenient to do so. SO if something like IQMS SPC is not an option, find a way to simplify your data collection. Work with your team to solicit their ideas on how to simplify the process and then they will have had a say in the new system. The other obstacle could be a company cultural one, they get away with it because they are not held accountable, but I would start with a team effort to simplify.
It is extra important to have your team and the production supervisor team involved. SO get appropriate members on your 8D team and work the corrective action process.
Best of luck.
S Help in SMART goals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 2
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
A Please Help With EOQ Calculation Manufacturing and Related Processes 2
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
S I need help in corrective action plan Nonconformance and Corrective Action 15
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 8
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
Edward Reesor ISO 19223 Discussion (Help) Other Medical Device Related Standards 1
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
A Nonconformity help IATF 16949 - Automotive Quality Systems Standard 5
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Help needed with locating conector Design and Development of Products and Processes 0
Y CER: can "state of the art" help to make up for literature search on equivalant devices? EU Medical Device Regulations 1
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Help on formulating a LP minimization problem Manufacturing and Related Processes 2
N Help with understanding Process Controls Manufacturing and Related Processes 7
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
