Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts
Ron Rompen
I have been assigned to find a humidty test standard for evaluating the corrosion resistance of the parts which we make and ship to various OEM's.
My initial thought was to use ASTM D1735 (100% humidity in a heated environment), however when I conducted my initial trials the parts failed miserably (not really a surprise, but......).
Our test provider suggested that the test protocol was too aggressive, and suggested that we use a non-condensing test, however they failed to suggest one, and I am not really familiar enough with test methodology to suggest (or even look for) one.
Can anyone with any experience in this field provide a guideline? All I need is the name or number of the standard - I will do the rest of the work :)
Thanks in advance.
Marc
Fully vaccinated are you?
Re: Help with Corrosion (Humidity) Testing Procedure
Can you be a bit more specific about the parts as well as the test requirements? I did a lot of environmental testing, but mostly on electronic assemblies.
HANG ON WHILST I THINK......
Marc
Ron - What is the material (I assume it's an alloy)?
Ron Rompen
Morning Marc. The parts are sintered powdered metal (transmission components, so never exposed to regular corrosion processes after assembly) which are coated with a rust inhibitor immediately prior to packaging and shipment.
We have had several complaints for 'rust' this year which (IMHO) is directly attributable to the excessively hot and humid weather we experienced, however I have no hard data to support this theory. When I did send parts for testing (as noted before) they were found to have >90% corrosion on all surfaces after testing (72 hrs @ 100% RH @ 100°F). The test provider (a 3rd party) has recommended a non-condensing test, but hasn't provided any additional information.
Yes, I could go back to my customer and ask what -=THEY=- recommend, but I don't want to open that can of worms just yet; there is no test requirement on the prints currently, and I don't want to nudge them towards adding one.
Ron Rompen
Thank you Jean....I will go through that one (OMG its a huge document!) and see if I can tweak it for use with our parts.
Ron Rompen
Just realized that I neglected to answer the question - the material is steel.
Marc
Ron,
I used to write test plans (EDCTP's and QAPP's) years ago and used MIL-STD-810. Be sure to look at Part One (especially 14 and 15) to determine the conditions your parts will experience. Humidity is method 507, but again - Conditions of the test can be different especially considering transportation.
I remember doing some work for Lucas some years ago where they switched transportation methods (cast iron foundation brake cylinders) and rust inhibitor didn't work. They had to add individual wrapping (!) of a rust inhibitor paper for each part.
I know there are a couple of discussions here with regard to rust not having been seen before and being blamed on unusual high humidity but off hand didn't see them in a search today. I wish I still had contacts at Borg - I worked with them in Gallipolis, OH some years ago on sintered metal transmission parts (I think they sold that plant not long after I was there).
The test lab is right in that you would probably want non-condensing humidity - But again - Your transportation profile and storage profile may actually show the parts are subject to significant temperature changes which would induce condensation.
I guess the big thing is this is "new" and if nothing else has changed the weather may actually be the factor.
One thought - Are they receiving rusted parts or are they finding them at the line or somewhere else? I mention this because I have seen customers change their storage, etc. which induced problems. Sometimes a trip to the customer's plant can be of value.
I haven't looked lately so I'm not up to the "latest" technology, but in years past when a "new" problem came up I have used tracking packages which monitored temper, humidity and vibration from shipping to receipt and identified transportation heat and humidity problems (especially with rail transportation) in the south-west US and into Mexico.
Well, just a few thoughts.
Oh, and Jean - Thanks for the MIL-STD-810 reference. Getting old - I worked with "C" and "D"! I hadn't seen "G".
JeantheBigone
Here in the soggy south of the US we have had problems with P/M low alloy steel parts that had not been oil coated both upon receipt and when it had been on our floor for "too long." This wasn't the manufacturer; the parts were shot peened prior to us getting them, and it was the shot peener who was supposed to oil coat them. I don't have any systematic studies of it, but it did seem to correlate with high temperatures and the rainy part of the summer. We were able to rework by shot peening, but we had to do it on a kan-ban basis because cleaning them up and leaving them out on the floor was an invitation to let them get those ugly red spots again.
bryan willemot Wanted: in need of start up Lock out Tag out program in Excel or Word, your help is much appreciated Occupational Health & Safety Management Standards 1
L Quality Manual Help for Service Sector/Service Organization (Government Contractor/IT Services) Quality Management System (QMS) Manuals 5
K Help with ISO 14971: Benefit-Risk Analysis ISO 14971 - Medical Device Risk Management 3
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
A Help understanding what it takes to implement a QMS that is ISO 13485 compliant ISO 13485:2016 - Medical Device Quality Management Systems 4
T Need 5 why’s help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
T Minitab Coding Help Using Minitab Software 0
G Help:Risk Management - Accessories US Food and Drug Administration (FDA) 1
T Containment help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Kevin Walters IAQG Required Audit Days Needed (Please help) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
M Can someone help me with this CMM programming question? Manufacturing and Related Processes 2
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
marmotte Help with Surgical Class I + 510(k) exemption US Food and Drug Administration (FDA) 0
T Help with updating procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
P Looking for help with an Ansys Workbench problem Manufacturing and Related Processes 0
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
O New metal detector, ccp -help! Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
J Help needed on clauses identification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S HELP in setting-up QMS Quality Tools, Improvement and Analysis 4
R Need help on calibration result analysis Measurement Uncertainty (MU) 17
S Help in SMART goals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
A Please Help With EOQ Calculation Manufacturing and Related Processes 2
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
S I need help in corrective action plan Nonconformance and Corrective Action 15
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 14
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
Edward Reesor ISO 19223 Discussion (Help) Other Medical Device Related Standards 1
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 52
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
A Nonconformity help IATF 16949 - Automotive Quality Systems Standard 5
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A Help needed with locating conector Design and Development of Products and Processes 0
Y CER: can "state of the art" help to make up for literature search on equivalant devices? EU Medical Device Regulations 1
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Help on formulating a LP minimization problem Manufacturing and Related Processes 2
