Help with MU and ISO17025 basics - Hired as a CMM programmer
True Position
#11
Almost got my Type A estimates done for each category of tool, figure I'll finish up the CMM and depth micrometer today. Leave the Type B stuff which I'm still somewhat lost, but figure I can work my way through tomorrow.
Just recieved a copy of the standard an hour ago, I'll read it tonight with a strong drink, or three.
micron master
#12
Hawat,
Believe me when I say this:
I do not often recommend A2LA for anything.
That being said, go to their main page and find the
"document finder" link. When there, find the "A2LA
guide to expression of uncertainty". They actually have
some examples in there that will help you. IIRC they have
an example that covers what you need, and if not, there is one that will be close.
True Position
#13
For the more experienced out there
I just checked a bore 5 times, re-alligning each time.
My results were:
52.6805
52.6803
52.6803
52.6801
52.6802
Standard deviation of that set is .00014832
For a type A uncertainty of .000066mm?
While that does make me happy, I'm worried my math is screwed up somewhere since it's such a small number. Of course, I'm going to have a lot of type B uncertainty due to temperature fluxuation multiplied by the potentially large lengths.
Just wanted a quick check if that looks reasonable to people who see these things more often then I.
Hershal
Metrologist-Auditor
#14
I come up with a Type A pretty close to yours so you likely are OK.
As for the brekdown in ranges of measurements, it is a good practice unless you have a need to do uncertainty for every discreet measurement. Just make the breakdown real, in that the ranges should reflect reasonable change points. Calipers/micrometers have some built-in points with gage blocks, but you have to establish yours based on the measurements.
As for the temp, the GUM method is to go by the readings at the time, but taking worst case over the week will work just as well for your use I suspect.
Hope this helps.
Hershal
True Position
#15
Sorry to be bumping my own thread.
Sorry to be bumping my own thread, but I just had one of my uncertainty calculations called into question for a particular measurement.
If you were measuring a hole's position in X or Y with a height gage w/o gage pins, you first measure the bottom of the hole, reset your height gage/indicator, and then measure the top.
Now, for the uncertainty, would it be reasonable to double the uncertainty for the height gage? I gave just the straight uncertainty I had for the tool and got comments about being worried. If they want a bigger number, I can give them one, but I want it to be a reasonable assumption I would be making.
Hershal
Metrologist-Auditor
#16
For the height gage itself, take the uncertainty listed on your accredited cal cert, divide by two to get it back to standard uncertainty and that number is ready for use.
However the top and bottom readings will have some uncertainty value which is determined by the Type A calculations.....each of those two readings will have a Type A contribution to your uncertainty.
Hope this helps.
Hershal
W
waderl
#17
Hawat,
We are a small independent Biotech/Pharmaceutical calibration lab and went through our initial ISO/IEC 17025 accreditation 3 days ago. We took 1 major and 3 minors, the major being our uncertainties for our scope. It looks like the post 3 weeks ago by Hershal is a good start. I’m feeling your pain and having trouble too. The formula in the two manuals (Measurement and Good Practice Guide No.11 by Stephanie Bell and EA-4/02) are really hard to follow with my little experience. Our auditor only wants the best measurement (type B) in each area (pressure, temp, speed …..) for our Scope of Accreditation. Can anyone direct me to a good step by step example of figuring out a best measurement?
Thanks for your help.
True Position
#18
In that regard, I did luck out. Micron Master's suggestion to check A2LA's site for information had two quite good documents on uncertainty of measurement, one specific to dimensionals, which was even more helpful. I'd recommend checking the thing they have first, it's more readable then most things out there.
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
M Thanks for the help Coffee Break and Water Cooler Discussions 0
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Burn out - Tips to help combat QC burnout Career and Occupation Discussions 9
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational From RAPS: Danish Regulators Seek to Help Smaller Companies With EU MDR Compliance Medical Device and FDA Regulations and Standards News 0
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
B [Help] Customer Engagement Survey for MBA Project - due Apr19 Manufacturing and Related Processes 0
B Help with Customer Engagement Survey for MBA Project - due Apr19 General Measurement Device and Calibration Topics 0
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
JoshuaFroud FDA Form MDSAP AU F0029.1.004 - Help with Completion US Food and Drug Administration (FDA) 0
supadrai Aviation MRO Project facility coming to U-Tapao airport in Thailand - Help Career and Occupation Discussions 2
E Small one man shop with QMS (shoptech e2) | AS9100 cert help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 46
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
