Help with updating procedures
Hi can someone help please,
the company i work for has recently asked me to oversee the ISO standards 9001, 14001 and 45001 and all the procedures had my previous managers name on them
for example at the start of each one they have 4 boxes
Prepared by: his name dated May 2019
Reviewed by: his line managers name dated May 2019
Approved By: the company owners name dated May 2019
Process Owner: his name dated May 2019
My question is if i update the policy to say the process owner is now MY NAME and date it Feb 2022 is that the correct way to do it?
And do i then update the version number at the bottom to reflect the update of the document?
We have an audit coming up in May 2022 so i wanted to make sure all the paperwork was correct..
John Broomfield
trucks79,
As the System Manager you should not own all the processes specified by your documented procedures. Enable the participants to own their system instead of expecting them to keep you happy.
Each process in your process-based management system should owned the person who knows best how the process works well.
You may be the expert in auditing and removing root causes of potential/actual nonconformity and be the best person to own these processes.
You seem to have way too many people involved in approving your documented procedures. Can they be reviewed by the process team for accuracy (thereby earning process owner’s approval) and by the boss of the process owner?
John
ED76
What value does having a named process owner give? Our system states that revisions to documents should be prepared by someone in the same technical function as the previous author, this allows the person who knows the process best to take responsibility for it if the previous author is no longer with the company or has changed role.
Depending on how many procedures you have you are looking at a lot of updating by May for only this one, minor change. I would be inclined to update the procedure which sets out the format of your documents to remove the requirement for there to be a named document owner and have a written plan to remove it from each document when they are revised for another reason.
There are better ways of doing this, and (most importantly) to stop this from being repeated. Documents don't need all that stuff on them. I'd suggest that you revise your document control procedure and create a "Document Change Notice". Use this to record all the background, approvals, dates and other details of the change and remove this redundant into from the procedures.
Mike S.
Happy to be Alive
As others have noted, you (or any single person) owning all the processes is probably a bad idea. I seriously doubt you own all the processes, nor should you.
What I do is make the process owner the TITLE of the actual process owner, i.e. Manufacturing Manager, Purchasing Manager, HR Manager, etc. and I as QM also approve it because I am responsible for QMS doc control and ensuring the document meets the requirements of the standard.
With respect, the OP's issue isn't about who "owns" what procedure. It's getting out from under a bureaucracy of names and approvals IN documents. The idea of "Process Ownership", while laudable, isn't specifically required by ISO 9001 and, might be a "bridge too far", when the burning question is the names on documents being incorrect. It likely feels like boiling the ocean to make those type of changes.
Mike S.
Happy to be Alive
IMO a "document change notice" is itself added work and not an improvement over names and approvals on the documents.
The OP proposed changing the policy to make him the process owner and asked if we felt that was the correct way to do it. I suggested an alternative.
Who knows how many docs would be affected but if he is going to make a change, I'd suggest changing the rules so that if someone else is in his shoes in a year, they don't have to waste their time doing this again. If the procedure says "Joe Smith has to sign the work order" and Joe retires, the document is no longer correct. If it says "the production manager has to sign the work order" it doesn't matter how many different people hold that title.
Thanks everyone for the replies i am very grateful so if i change the process owner of the documents like for example Finance Manager, HR Manager, Admin Manager, IT Manager ect ect that would be better?
Also if i make changes to the document at what point do i change the details at the start of the document (as shown below)? would i change the review date to the date i made the changes?
That is the part i am struggling with, on the footer it says revision number 1.3 so i understand that will become 1.4 and so on but at what point does the main document details at the beginning change?
Process Owner: FINANCE MANAGER MAY 2022
Strange, because design responsible organization usually use a parallel system called an ECN and I've never heard anyone complain that that's extra work and it keeps drawings/specs free from all kinds of information which doesn't need to be present IN the document - for the benefit of the user...
T Design & Development in Updating Machines and Equipment - ISO 9001 Help Design and Development of Products and Processes 4
T 5 Why's Help Needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
M Lead Auditor Log book Help. General Information Resources 1
J Help Needed Customer and Company Specific Requirements 1
P True position with bonus Excel help Manufacturing and Related Processes 8
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
D Little Help with "Tooling Change Program" for perishable tooling (8.5.1.6) IATF 16949 - Automotive Quality Systems Standard 4
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
A Help required in establishing Laboratory Information Management System as per ISO 17025, Cl.7.11.2 ISO 17025 related Discussions 0
R Help Understanding Current Role; Distributor, Manufacturer, or Importer EU Medical Device Regulations 4
D HELP gage card not popping up Using GAGEpack Software 2
bryan willemot Wanted: in need of start up Lock out Tag out program in Excel or Word, your help is much appreciated Occupational Health & Safety Management Standards 3
L Quality Manual Help for Service Sector/Service Organization (Government Contractor/IT Services) Quality Management System (QMS) Manuals 5
K Help with ISO 14971: Benefit-Risk Analysis ISO 14971 - Medical Device Risk Management 3
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
A Help understanding what it takes to implement a QMS that is ISO 13485 compliant ISO 13485:2016 - Medical Device Quality Management Systems 4
T Need 5 why’s help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
T Minitab Coding Help Using Minitab Software 0
G Help:Risk Management - Accessories US Food and Drug Administration (FDA) 1
T Containment help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Kevin Walters IAQG Required Audit Days Needed (Please help) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
M Can someone help me with this CMM programming question? Manufacturing and Related Processes 2
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
marmotte Help with Surgical Class I + 510(k) exemption US Food and Drug Administration (FDA) 0
P Looking for help with an Ansys Workbench problem Manufacturing and Related Processes 0
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
O New metal detector, ccp -help! Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
J Help needed on clauses identification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S HELP in setting-up QMS Quality Tools, Improvement and Analysis 4
R Need help on calibration result analysis Measurement Uncertainty (MU) 17
S Help in SMART goals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
A Please Help With EOQ Calculation Manufacturing and Related Processes 2
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
S I need help in corrective action plan Nonconformance and Corrective Action 15
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 14
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
Edward Reesor ISO 19223 Discussion (Help) Other Medical Device Related Standards 1
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 52
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
