HF/RF Generator for dielectric strength
morph
Hello everybody,
We are developers and manufacturers of HF electrodes and would like to check them in accordance with the standard IEC 60601-2-2 - 201.8.8.3.103 for their dielectric strength with RF-frequency.
Our electrodes are approved for a maximum voltage of 1.5 kVp or 2.0 kVp.
Can you recommend a HF generator that can generate this voltage considering the given crest factor (cf between 2,0 and 2,8)?
Many Thanks.
N Electrosurgical generator with switchable sockets - creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
O Selection of a calibrator (pressure generator, temperature) for my field devices General Measurement Device and Calibration Topics 2
S Defibrillator Requirement for ME Equipment connected to HF Electrosurgical Generator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Using a Rhode FSH6 Tracking Generator General Measurement Device and Calibration Topics 2
R Does an Outside Steam Generator need to be Registered in the EU? EU Medical Device Regulations 2
M Diesel Generator Stack - Sample port guidelines required Miscellaneous Environmental Standards and EMS Related Discussions 2
G Is cardiac waveform generator a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Jerry Eldred Philips PM5645 Teletext Generator Procedure General Measurement Device and Calibration Topics 3
T Reference Spectrum Generator for In-House Calibration General Measurement Device and Calibration Topics 2
Scott Catron Warning Sign Generator - An essential part of your safety program... Coffee Break and Water Cooler Discussions 3
Ajit Basrur Random Insult Generator (RIG) Coffee Break and Water Cooler Discussions 2
T HP3325A Function Generator - Troubleshooting Modulation on Output General Measurement Device and Calibration Topics 8
B The Idea Generator - Quick and Easy Kaizen Book, Video, Blog and Web Site Reviews and Recommendations 1
A Dielectric withstand of applied part IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B IEC 61010-1 - Voltage / Dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Production Line Test Brasil - High Voltage Dielectric Strenght Test Other Medical Device Regulations World-Wide 5
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
O Is it mandatory for Medical Devices to work properly after dielectric strength tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B Standard for Dielectric Strength Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S IEC 60601-1 Electrical safety testing - Dielectric Strength Test - 8.8.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B Dielectric Test of Battery Powered Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Dielectric Strength of Electroshock - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Transformer Compliance Testing, overheat then humidity treat, then dielectric test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Input to Ouput Dielectric Strength PSU IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Dielectric Test for Ambulatory ECG Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
C INMETRO 350 Dielectric Strength Test to IEC 60601-1 clauses 18, 19 and 20 Other Medical Device Regulations World-Wide 5
S Issues with Dielectric Strength Testing - IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Current Limit in IEC 60601 Dielectric Strength Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Dielectric Strength of Triple Insulated Wire to comply with 2MOPP IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
I Dielectric Test for HF Surgical Equipment (IEC 60601-2-2 clause 201.8.5.1.2) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Internally Powered Medical Device and Dielectric Strength IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
D IEC 60601-2-37 - No Dielectric testing specifications? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
M Testing Tensile Strength of Materials AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Test Method Validation for Tensile Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Tensile Strength Testing of Rubber Underwear Manufacturing and Related Processes 2
D What is your Sterile Medical Device Pouch Peel Strength Spec? Other Medical Device Related Standards 3
N Strength verification of surgical instruments ISO 13485:2016 - Medical Device Quality Management Systems 5
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
D Hot Plate Welded Plastic Strength Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
triathlonx13 Rubber - Tear and Adhesion Strength Peel Cross Head Speed Design and Development of Products and Processes 3
