Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment?
FloridaST
We need to do a better job at covering 6.4.1 Work Environment, specifically the requirement for evidence of procedures for health/cleanliness and clothing. I'd like to tie this in to our Preservation and Handling which does cover clothing and contamination of product so it may be a good fit here. Would this be advisable or should I create a separate document? Either way, would anybody have an example I can look at for inspiration? Thank you.
yodon
There's no requirement for a "procedure" - you just need to document the requirements. You could document the requirements in the Preservation and Handling SOP a long as you're covering all work areas.
FloridaST
Thanks for clarifying, I focused on the words the auditor used and he mentioned "procedure" so I took it at face value without confirming in the standard.
Hi - wondering if you have an example of what you documented for health requirements?
Hi_Its_Matt
I'll throw my 2c in. I recommend you read carefully the requirement of 6.4.1.
(emphasis mine)
6.4.1 Work environment
The organization shall document the requirements for the work environment needed to achieve conformity to product requirements.
IF the conditions for the work environment can have an adverse effect on product quality,
THEN the organization shall document:
1. the requirements for the work environment AND
2. the procedures to monitor and control the work environment.
The organization shall:
a) document requirements for health, cleanliness and clothing of personnel IF contact between such personnel and the product or work environment could affect medical device safety or performance;
b) ensure that all personnel who are required to work temporarily under special environmental conditions within the work environment are competent or supervised by a competent person.
This means you must first understand (1) what the product requirements are, and (2) how the work environment can impact the ability to meet those requirements.
If it is a requirement that the product be provided sterile, then that means controlling the cleanliness of your manufacturing environment to a certain level, such that you have consistent product bioburden levels, and can validate your sterilization process.
If even the smallest amount of contamination can have an adverse effect on product quality, then you may require that employees not come to work if they are feeling sick, and be temperature tested before every shift [health]. You may require that they shower before entering the manufacturing floor [cleanliness]. You may require that they wear a fully protective suit - smocks, gloves, goggles, respirator, etc [clothing].
If some amount of bioburden is acceptable, then maybe you don't need the temperature check, and maybe hand washing instead of showering is sufficient. Maybe instead of the protective suit, you let people work in their jeans and t-shirt. It all depends on what is needed to achieve product requirements.
Once you know what the necessary work environment requirements are, document them. Then you document the controls necessary to make sure that you consistently meet those requirements. Whether you do it in a "Preservation and Handling" procedure, or in some other location doesn't really matter. As long as the controls are implemented and effective, and your work environment continues to meet its requirements, you should be good.
K Curious to know do seo friends? Coffee Break and Water Cooler Discussions 0
BradM Hurricane Harvey - Texas - August 2017 - Any South Texas Friends out there? Coffee Break and Water Cooler Discussions 10
A Any friends from Black & Decker? Supplier Quality Assurance and other Supplier Issues 1
B Just saying HI to old cove Friends Coffee Break and Water Cooler Discussions 7
S Favour Friends-No reply QS-9000 - American Automotive Manufacturers Standard 0
V Anyone have templates for FDA GMP Guidelines for supplement manufacturers? US Food and Drug Administration (FDA) 0
A Has anyone implemented the Adobe Acrobat Sign Validation Pack to be 21 CFR Part 11 Compliant? ISO 13485:2016 - Medical Device Quality Management Systems 9
R Does anyone know how ASQ exam requirements are verified? Professional Certifications and Degrees 3
B Does anyone copyright their internal QMS documents? Document Control Systems, Procedures, Forms and Templates 24
Sam.F Anyone knows velocity 360 training Training - Internal, External, Online and Distance Learning 11
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
S Has anyone had experience with Intellect eQMS? ISO 13485:2016 - Medical Device Quality Management Systems 1
G Does anyone know about tobacco-free nicotine pouches? US Food and Drug Administration (FDA) 2
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 5
L Did anyone hear business registration ontario? General Information Resources 1
Q Does anyone know what this call out means? Manufacturing and Related Processes 3
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 3
A Can anyone explain UKRP guidance relating to Northern Ireland? UK Medical Device Regulations 2
L Is there anyone joined Qserve's trainings? EU Medical Device Regulations 0
H Has anyone undergone MDR FQA review yet? EU Medical Device Regulations 10
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 3
Ed Panek Is anyone familiar with Article 60 Certificate of Free Sale EU Medical Device Regulations 6
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
A Can anyone share a Distribution Agreement template under MDR 2017/745? EU Medical Device Regulations 6
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
Watchcat Anyone had an MDR technical file review/audit yet? EU Medical Device Regulations 13
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 15
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
GreatNate QMS in SharePoint - Is anyone doing this? Manufacturing and Related Processes 10
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 13
G Anyone working with or planning to do business in the CBD (cannabidiol) industry? US Food and Drug Administration (FDA) 1
