HMLV Lean Questions - PCB manufacturing industry Value Stream Mapping
claymanz
Hi there.
I am working in PCB manufacturing industry. It is somehow like a HMLV manufacturing. Therefore, I am wondering anybody can help on below questions when I do Value Stream Mapping:
1) Different products share same production line, how can I calculate the available time for the production line for 1 kind of product?
2) The P/N I am used in this process might not be the same P/N I used in next process as there are many P/Ns running in the production line. Is it okay for data collection from different P/Ns or do I need get a mean value from 5~10 samples?
3) Even for the products within one product group, they might have slightly different process flow (e.g. some of them have surface treatment in the middle of the process flow, some of them have surface treatment at the end of process flow), do I need distinguish them from each other when I perform VSM?
4) Is it possible for HMLV to implement Lean?
Thanks for your guys' help and looking forward for your reply!
:thanx:
W
wmarhel
Take your total time and your total quantity by product (P/N). Determine what percentage of production is made up by each part and use that percentage to allot a period of time to it.
Product A: 100 pcs.
Product B: 200 pcs.
Product C: 100 pcs
Total Time: 480 minutes
Product A gets 120 minutes of available production time, Product B gets 240 minutes, etc. It will give you a starting point to begin massaging as needed.
What exactly are looking at as far as data, takt time? Cycle Time?
Yes, if it is significant, or it would cause you to not meet takt. If your below takt, then it isn't as important at this stage. Focus on something that is exceeding your allowable takt time.
Yes, you just need to be a little creative in your approach. Think about the concept and you could apply it to your situation. Don't try to take something right out of a book and attempt to apply it, you need to make it your own.
Wayne
claymanz
First of all, thank you for such a detailed reply, Wayne. But I still got some questions to ask, can you help further?
Product A: 100 pcs.
Product B: 200 pcs.
Product C: 100 pcs
But the mix of products on this machine will change from time to time, do you think I need do weekly average or monthly average to make it typical?
Yeah, the data like Change over time, Cycle time, etc. Need mean value from a few samples, right?
Wayne
Do you have any readings or case studies for me to learn? I don't think I understand "Lean" thoroughly, what if my own way is wrong from the begining?
Thanks again for your kind help!:thanks::thanks:
W
wmarhel
Ideally, you should determine takt daily. I can't say for sure, but I would be willing to bet that are groups of parts that fall within 10-20% of each other as far as cycle time. For those parts that where the cycle is extreme from the rest of the population, you may need to come up with an alternative. If your only running a handful of parts with a lot of history, you could possibly determine takt farther in advance for planning purposes.
For instance, I once had a family of products made up of nine different sized units (Sizes 2-10). After all the various options/configurations, we had over 700 unique models that we might build. From an assembly line standpoint, we took all size 2 units, and sizes 8 through 10 off the main line and placed them on a secondary line (the volumes for these units also wasn't very high). The variance for the sizes 3 to 7 was <25 sec. Not perfect, but considering that I was able to reduce my overall cycle time by >30%, with half the WIP (work-in-progress) it was a definite improvement. This was also in a seasonal business, so it gave us the flexibility that we could reduce our finished goods requirements as well.
You need to do a spreadsheet of all the part numbers you'll run across this line/operation and try to identify product families and similar cycle times.
Yes, you'll want this data to help in creating the product families.
Two books I would recommend:
Implementing a Mixed Model Kanban System by Mike Vatalaro. Mike is a pretty sharp guy and this book will help answer a lot of your question regarding different products across the same line/process.
Creating Mixed Model Value Streams by Kevin Duggan. Another good book, and I think this too will help answer some your questions.
First, there is no "right" way to be lean or even to go about becoming lean. If you something isn't working, change it. Just be sure to take the time to learn why something does or doesn't work and modify accordingly.
Wayne
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
G Lean Kaizen: continuous, step-by-step improvement in the Lean direction Lean in Manufacturing and Service Industries 0
L Lean Transformation - How do you get Senior Leadership engaged Human Factors and Ergonomics in Engineering 6
I New to LEAN but not to Quality - How to run Kaizen events Lean in Manufacturing and Service Industries 1
JAMESH Building a "Lean" Job Shop Training Program Training - Internal, External, Online and Distance Learning 0
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
J Lean MFG (manufacturing) process and Work order templates Lean in Manufacturing and Service Industries 6
eule del ayre Lean Six Sigma for Quality Management System Lean in Manufacturing and Service Industries 10
T ASQ Lean 6sigma BB examination Six Sigma 3
Marc ASQ Lean Six Sigma Conference March 4-5, 2019 - Phoenix, AZ ASQ - American Society for Quality 0
Bev D ASQ Lean Six Sigma Conference March 4-5, 2019 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
qualprod How to start with Lean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Lean's New Buzzword: Leader Standard Work Lean in Manufacturing and Service Industries 8
S Levels of Lean Six Sigma Certification Six Sigma 3
J Excellent Resource on Statistics / Lean / Six Sigma Book, Video, Blog and Web Site Reviews and Recommendations 2
B Looking for Lean Manufacturing Articles in Spanish Lean in Manufacturing and Service Industries 4
L Lean Book for Basic Knowledge Lean in Manufacturing and Service Industries 2
0 Suggest a Lean Book for Upper Management Lean in Manufacturing and Service Industries 6
M Lean Time Line (History and Theory) Lean in Manufacturing and Service Industries 5
tony wardle Lean and TS16949 - Integration Lean in Manufacturing and Service Industries 4
E Lean Manufacturing in Oil & Gas Industry Lean in Manufacturing and Service Industries 4
Bev D ASQ 2015 Lean Six Sigma Conference: Bev D's Presentation Problem Solving, Root Cause Fault and Failure Analysis 9
L Lean in the ISO9001:2015 World Lean in Manufacturing and Service Industries 1
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
O Implementing Lean Intranet Sharepoint Lean in Manufacturing and Service Industries 6
Q Advice for the Implementation of a Lean/Six Sigma Program Six Sigma 9
D Any experience with the SME/AME/Shingo/ASQ Lean BOK/Certifications? Lean in Manufacturing and Service Industries 2
O Lean Tools in Labour Intensive Manual Manufacturing Lean in Manufacturing and Service Industries 20
A Lean and ERP software Lean in Manufacturing and Service Industries 0
J Lean Appropriate KPIs for a Distribution Centre Lean in Manufacturing and Service Industries 1
J Lean Transformation Project - Distribution centre in Europe Lean in Manufacturing and Service Industries 1
Crusader Recommend a LEAN service company that you hired Lean in Manufacturing and Service Industries 4
N Lean Six Sigma Deployment Six Sigma 2
F Looking for some type of training on Lean Manufacturing video or web training Lean in Manufacturing and Service Industries 7
DanteCaspian Free Poster Download: LANGUAGE OF LEAN CULTURE (2017 Revision Attached) Lean in Manufacturing and Service Industries 14
C Availability of Lean Manufacturing Training The Woodlands TX Training - Internal, External, Online and Distance Learning 4
T Relationship between ISO9001 and Lean Lean in Manufacturing and Service Industries 15
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
S Lean Hospital - Implementing a quality/lean/six sigma program Lean in Manufacturing and Service Industries 3
E Lean application in Regulatory Affairs Lean in Manufacturing and Service Industries 3
G Has anyone used shlomo Aviv-lean consultant? Lean in Manufacturing and Service Industries 1
O Lean Manufacturing Implementation Lean in Manufacturing and Service Industries 7
P Integration of Lean and Six Sigma Six Sigma 3
D When you're not Lean enough for JIT (Just In Time) Lean in Manufacturing and Service Industries 9
8 Lean Specialist Job Interview - Revision & Question Lean in Manufacturing and Service Industries 1
C Who should develop a LSS (Lean Six Sigma) project charter? Six Sigma 2
L How Lean Can Manufacturing Get? Lean in Manufacturing and Service Industries 7
C Ideas on Implementing Lean and 5S Methods Lean in Manufacturing and Service Industries 6
S 45 Minutes of Lean Training to many Suppliers during a Supplier Conference Lean in Manufacturing and Service Industries 4
