Hole Form Dimension - Shaft dimension which is +-.015
jdm2008
I have a shaft dimension which is +-.015. I've been seeing issues with circularity on this dimension and and the suggested change was to add a form error(circularity of .015).
Wouldn't the status quo already have as strict a tolerance? To meet the basic dimension around the entire circle, form error must be less than .015. Also isn't dimensioning the part in this way actually making the tolerance less strict since the part could be +.013 and have a form error of .010?
Re: Hole Form Dimension
You want to control the two things--size and circularity--separately. If the diameter tolerance is ?.015 and you applied a circularity tolerance of .015, the effect could be the opposite of what you want. If the size tolerance is what it needs to be, determine how eccentric the hole can be without causing trouble, and use that as a guide for setting the circularity tolerance.
True Position
A diameter tolerance is (in ASME Y14.5 world) always applied to the 'functional diameter', either the outermost points of a male feature or inner points of a female feature. (aka what the mating part would see.)
What type of gage are you using? What process made the OD in question?
Kingsld1
Form tolerances such as circularity are a refinement of the size tolerance. Currently your size tolerance would allow .030" of circularity. The purposed change would retain the size tolerance but cut the allowed circularity in half.
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
R Through-Hole Electronics - Checking Lead Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B Counterbore - Hole or feature? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I 3 legged 5 Why - Hole diameter Oversize caused by Gauging Problem Solving, Root Cause Fault and Failure Analysis 9
T Optical Comparator measuring of Position of a Threaded Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Slotted Hole Dimensional Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
I Hole dimension out VS in tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Inspecting a difficult part - Measuring the centre of a hole to the edge of a rod Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
V Checking for Oversize Hole - Dimensioning question APQP and PPAP 7
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
F How could this Hole Diameter and True Position problem have been Detected & Prevented Nonconformance and Corrective Action 27
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E SAE-AS8879 Threaded Hole Gaging - .4375UNF-3B and .4375-UNJF-3B Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J Basic Dimension Chaining - Second hole has a basic dimension from the first hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Hole Limit Dimension Values Placement - Smaller Limit On Top? Manufacturing and Related Processes 3
L When and how to apply Bonus Tolerance MMC - Hole Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
R Maximum allowed eccentricity for any shaft or hole diameter Misc. Quality Assurance and Business Systems Related Topics 7
S Weld Cell Repeatability Studies - Origin - The 'drilled hole panel' Methodology Manufacturing and Related Processes 3
O How to report Profile of a Sphere crossed by a Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
S Cp Cpk of a hole filleted for control P/NP Statistical Analysis Tools, Techniques and SPC 4
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
V How to design a gauge (fixture) for measurement of distance between two hole Design and Development of Products and Processes 23
T GD&T: Boundary - Callout for an Oblong Hole (Slot) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
J Measuring Hole @ .00005" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Criteria for taking Dimensional Measurements of a Painted Hole in a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Measuring a .250 diameter hole +/.005 in Thin Laminates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 23
P Liquid Nitrogen to shrink fit a new plug into a hole in a casting Manufacturing and Related Processes 7
Proud Liberal Using Three (3) Gage Pins to Check Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Pancho What's the weight of a solid steel sphere with a 6" long cylindrical hole through? Brain Teasers and Puzzles 8
Jen Kirley Hole in one! Coffee Break and Water Cooler Discussions 17
R Trying to decipher drawing - Hole Size Manufacturing and Related Processes 12
A AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M What would Cause hole size smaller during the punching process of plexiglass? Manufacturing and Related Processes 7
M Countersink Hole Inspection - Old School Technique. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
H E Coat (Electrocoat) Pin Hole Paint Defects - Help needed Nonconformance and Corrective Action 3
M Cp, Cpk, Dpm, or other? Diameter of a Hole - Non-Normal Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 20
D Hole Surface Profile Tolerance Discussion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
R How to chart hole location? Stamping parts with 4 holes each Statistical Analysis Tools, Techniques and SPC 22
