Holes position inspection - Calculation of centre distance and plug sizes of a gauge
fisa
please looking help regarding the calculation of centre distance and plug sizes of a gauge for checking holes to holes ...
regards
asif
Proud Liberal
The tolerancing scheme you have on the drawing does not lend itself to a direct correlation with a functional gage such as the one you've shown. The biggest issues are:
  1. There are no datums identified on the print.
  2. The hole location tolerance zones are defined as rectangular (tolerance block is ± .xxx). Any attempt to create the gage with this tolerancing will require a significant reduction in your total tolerance (the gage will reject parts that meet the print) or if designed to always accept good parts, it will also accept some bad parts.
CONCLUSION: you don't have any good options with this print (gage-wise). If you want to propose a good GD&T solution to your customer, you will also need a solid understanding of the part function and any downstream operations / assemblies it undergoes.
fisa
thanks
thanks for your advice. if i can explain the application of this plate holes ...then there is any possibility to define tolerances of specific holes for location gauge?
also i have find some standard for define tolerance ..but cant understand how to interpret or relate with this drawing. it .
please check attachment for details..
F Conversion of coordinate dimension holes to position dimension Design and Development of Products and Processes 3
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
optomist1 Tolerance of Position - Pattern of Holes at MMC - Datum Feature Reference Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Bidirectional True Position Tolerance Call-Out for Holes for Process Capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
G GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes Various Other Specifications, Standards, and related Requirements 16
D Procedure for Fixture Gages that check True Position of holes General Measurement Device and Calibration Topics 4
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
L Inspection Equipment Accuracy - Measuring the diameters of small holes Measurement Uncertainty (MU) 5
I Proper gauging of tight tolerance (reamed) holes General Measurement Device and Calibration Topics 4
S Internal Audits: Rabbit Holes or Marked Roads? Internal Auditing 13
Marc Security holes enable attackers to switch off pacemakers World News 3
optomist1 Measuring Threaded Holes in Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
M Drilling Close Tolerance Holes - Advice needed on Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M Measuring Holes in Material Stack - Carbon Composite-Aluminum Alloy-Titanium Statistical Analysis Tools, Techniques and SPC 6
J Drawing Callout: "Holes must be in line" No Tolerance specified Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
S GR&R for Dowel Pin Holes Using Deltronics Pins Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Ron Rompen Very Unique Prototype Requirement - Cutting Holes in Tubing Manufacturing and Related Processes 2
C Composite Materials Machining - Out of Specification Holes in Parts Manufacturing and Related Processes 8
L Plug Gages and Tapered Holes - Compensation for Heat Treat Distortion General Measurement Device and Calibration Topics 1
J Blueprint Note: Rectangular Distribution is Permissible - Concentricity of Two Holes Capability, Accuracy and Stability - Processes, Machines, etc. 5
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Press Brake Tooling / Back Gauging - Holes for the back stop instead of the Part Edge Manufacturing and Related Processes 8
Marc EMP device to shape and punch holes through steel World News 2
S Countersink Tools - Burrs on the bottom and at the top of the holes Manufacturing and Related Processes 3
J Distance between two holes tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
T Holes or Voids in co-extruded 65A TPE & 50D part Manufacturing and Related Processes 9
S Plating Internal Threads in Tapped Holes - Go Gage no longer enters Manufacturing and Related Processes 23
R How to chart hole location? Stamping parts with 4 holes each Statistical Analysis Tools, Techniques and SPC 22
R How to measure countersink angles of countersunk holes in sheet metal panels General Measurement Device and Calibration Topics 20
Hershal Favorite haunts - Our favorite feeding toughs and/or watering holes Coffee Break and Water Cooler Discussions 14
J Proper use of gauge pins - Inspecting thru holes of plastic parts General Measurement Device and Calibration Topics 19
G Flex Plugs - Gage R&R (GR&R) - Threaded plugs used to check location of tapped holes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
L Gaping holes beginning to appear in the bow of Battleship ISO ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Excel and Powerpoint 'Holes' Excel .xls Spreadsheet Templates and Tools 0
Marc Accuracy & Explosive Bolts - Using pin gages to measure reamed holes General Measurement Device and Calibration Topics 8
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
F So my quality management position is being marginalized by my job. Quality Manager and Management Related Issues 10
M True position, calculating theoretical distances General Measurement Device and Calibration Topics 0
Sidney Vianna Food & Beverage Safety Lead Auditor Open Position - USA Job Openings, Consulting and Employment Opportunities 0
R Whats different between these position CE Marking (Conformité Européene) / CB Scheme 10
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 6
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 10
L Form-dependent position prevention control FMEA and Control Plans 1
M Informational EU – Official position on EUDAMED delay Medical Device and FDA Regulations and Standards News 9
