How about another torque discussion? Assembly processes
dwperron
There have been many discussions concerning torque tools and their care and feeding and calibration.
We are having a different discussion, so if this has been covered please point me in the right direction.
Otherwise, here we go...
We have assembly processes here that have a requirement to properly attach fasteners with the correct amount of torque.
The drawings will give a tolerance for the torque setting value for the fastener, let's say ±10% for the sake of discussion.
We use various tools that are calibrated with accuracy ranging between 2% and 6%.
This kind of an accuracy ratio is not optimal, but this is the real world.
My question regards the ±10% tolerance on the drawing for torque values. Does this kind of a tolerance make sense to the mechanical engineers and metallurgists out there? Are there any studies to show how much variability you can have in the torque settings for fasteners without affecting the security of the joint? How can you tell how much is "too loose" or "too tight".
Jen Kirley
Quality and Auditing Expert
Good day dwperron,
My experience with prescribed torques comes from submarine mechanical assemblies. I do not remember the allowable error we had, but based on end application (generally water tight seals on saltwater, oxygen or high temperature, high pressure steam boundaries) the allowable error depends on the fastener size, material type and heat treatment, the size and material type/heat treatment of the housing/flange, the type and size of gasket (if any) or surface finish on machined surfaces, and the cost of getting it wrong.
Based on these variables it is impossible to guess here what is the appropriate error in torque. I would defer to provided specifications.
GRP
If I am being too obvious kindly disregard, but torque leads to a tension stress on the fastener. Given the material properties and the geometry of the fastener you want an upper bound stress below yield, with a safety factor dictated by the industry and/or application. So at least, the upper specification limit should be constrained by this.
I have read a technical paper from a fastener manufacturer that stated that only about 10-30% of the effort expended in tightening a screw ends up as "tightening force" of the joint, the rest being absorbed to overcome thread friction and screw head to workpiece friction.
At any rate, too tight is breaking the fastener, too loose is any torque which does not "use" or take advantage of the fastener properties to withstand torque-induced stress to the effect of tightening the joint. There must be plenty of standards and tables for this.
Marc
Fully vaccinated are you?
I think the issue is that "too tight" will not necessarily actually break the fastener at the point/time of assembly. It may partially strip the threads on the fastener, or the threads in the threaded hole it is being tightened into which may not be obvious to the assembler. Or it may stress the fastener its self causing it to fail (e.g.: through fatigue) at a time when the finished product is in use.
John Predmore
There is no simple answer because a torque specification is a multi-dimensional multi-faceted dynamic reliability problem. While threaded fasteners have been around for hundreds of years, our modern understanding of fastener joints has changed since I was in engineering school. For example, split ring lockwashers, which were commonly used 40 years ago, are now discouraged because they can make a fastener joint less reliable. Every fastener application is a unique design study. The good news is, with the Internet, there are many resources including chapters of design textbooks available to a mechanical designer. There is much more information online than is possible to copy and paste here. But be wary of simplistic answers to a complex question.
Too tight also becomes a concern with a gasketed joint as the gasket may be deformed too much or damaged when over torqued.
dwperron
Good day dwperron,
I understand, and I did not do a good job at describing what I am searching for.
I am trying to determine how much torque is recommended for a joint (and how that number is determined) and to see if there are any "industry standards" regarding what might be considered an acceptable range of torque values for that joint.
Establishing a torque specification correctly is a fairly complicated process. The first step is determining the clamp force required for the joint. Then you determine the number and size for the fasteners. This will establish the axial force required for each fastener, which can then be translated into a torque specification. The allowable range of torque must be determined by the allowable range in clamp force.
See Engineering Fundamentals of Threaded Fastener Design and Analysis and POCKET GUIDE TO TIGHTENING TECHNIQUE for more detail.
D Yet another torque question... Assembly processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Can PLM be in the OEM position for another company? EU Medical Device Regulations 1
K 510(k) Manufacturer question (private label and manufacture under another persons 510(k)) US Food and Drug Administration (FDA) 1
Q Can I use Cpk to compare if one part is usable in another part? Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
U Adding another Subcontractor EU Medical Device Regulations 3
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
F Internal transfer of work from one line to another? Qualification and Validation (including 21 CFR Part 11) 3
C FDA Establishment registration - Buying some medical devices from another manufacturer Medical Device and FDA Regulations and Standards News 5
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F ISO 13485 - EU countries that could request another audit ISO 13485:2016 - Medical Device Quality Management Systems 2
M Can a PLD Registered in only one state sell prescription drugs to one in another state Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
J IVD CE transfer to another manufacturer EU Medical Device Regulations 4
F Adding a medical device in another medical device package EU Medical Device Regulations 2
M Informational From RAPS – Another Notified Body Bows Out Ahead of EU MDR: ‘Investment Too High’ Medical Device and FDA Regulations and Standards News 2
M Medical devices as an accessory from another manufacturer EU Medical Device Regulations 2
M Informational FDA Preps for Device Shortages as Another Sterilization Facility Will Close Medical Device and FDA Regulations and Standards News 0
I Another design change or new product? IVD device ISO 13485:2016 - Medical Device Quality Management Systems 6
S Our products borrow DHF documents from a previous DHF for another product ISO 13485:2016 - Medical Device Quality Management Systems 2
S Internal Audits performed by another local business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
Wes Bucey Another year - still happy! Covegratulations 5
M 2 Quality Manuals after merging with another company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Can we have our CE mark on another Manfacturer's parts ? EU Medical Device Regulations 3
G How to cover another manufacturing "site" or warehouse into current ISO 13485 cert ISO 13485:2016 - Medical Device Quality Management Systems 7
M Licensing of a 510K to another manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
P Who can give another company ISO Cert? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Requirements for Marketing Collateral for product distributed by another company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tensile Testing Transfer from one site to another site Manufacturing and Related Processes 2
A Medical Device Licensing - We are planning to sell another product Canada Medical Device Regulations 2
JoCam Control of Works Transfer to another location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Assessment Question - We are using another company's procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
5 Transfer of an ISO 13485 Certificate to another Company ISO 13485:2016 - Medical Device Quality Management Systems 4
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
J Auditor approval by AABs already authenticated by another AAB from other sector AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R How to address an audit of another facility that is not ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 9
C Is it required to mention another non certified organization in our Quality Manual ? ISO 13485:2016 - Medical Device Quality Management Systems 9
S Validation and Qualification when moving to another Facility Qualification and Validation (including 21 CFR Part 11) 2
D Device that makes another Device (Active Implant Medical Device) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Q Non Conformity of Support Processes - Need another NC form? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Movement of Final Product from One Warehouse to Another Manufacturing and Related Processes 2
S Our device as part of another company?s device ? FDA liability? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
Wes Bucey Another twist on email spam After Work and Weekend Discussion Topics 6
J How to change the Manufacturing Site to another Contract Manufacturer Japan Medical Device Regulations 1
Q How to determine if another company is our Supplier? Supplier Quality Assurance and other Supplier Issues 3
Q Need Guidance - One job offer with another one in the works Career and Occupation Discussions 26
G Subcontracting work (manufacturing) to another company location EASA and JAA Aviation Standards and Requirements 4
F Not another thread about what Environmental Aspects are... Miscellaneous Environmental Standards and EMS Related Discussions 19
