How Calibration Precision checks are implemented in medical device companies
H
Hamaltonian
Hi all,
As you may be aware, CFR Title 21 820.72.b states that "Calibration procedures shall include specific directions and limits for accuracy and precision."
I understand how accuracy is checked, i.e. comparison to a known standard value, I also understand the meaning of precision but my question is- How do you implement precision checks into a calibration procedure? What is common practice in industry to ensure CFR Title 21 820.72.b is adheared to (with regard to precision limits)?
i.e How does precision fit into calibration activities?
Thanks for your help in advance,
H
dwperron
Another interesting subject.
"Specific directions and limits for accuracy" is typically the manufacturer's tolerance. This is because, minus any other guidance, it is assumed that the instrument performance will be within manufacturer specifications. It does happen that limits for accuracy can be determined for the application requirements that the instrument is measuring, and those can be used in the calibration procedure (for example, you only need to know the refrigerator temperature to within ±5°F, not the accuracy of the monitoring device). In most cases the specifications are what determines "accuracy".
How about "precision"? The easy way to determine precision is to analyze a set of multiple measurements. But what do you do about the specific limits for precision? Most instruments do not have specifications for precision (or repeatability), so the manufacturer does not supply guidance. Again, you can derive your own based on your determined measurement requirements.
In most cases, when there is no guidance concerning "precision" requirements, you can make a series of measurements instead of a single measurement, using the manufacturer tolerance as the limit for both accuracy and precision. How many measurements? I'm afraid there is no guidance there, I've seen 3, 5, and 10 measurements used. The requirement is to have a procedure that tells you how many measurements to take and what the limits are on the measurements.
Also, it wouldn't hurt to get guidance from your auditor, if possible.
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
D Precision Balance Verification and Calibration Process General Measurement Device and Calibration Topics 3
E Precision Instruments Calibration Instructions General Measurement Device and Calibration Topics 4
J CFR Title 21 820.72.b Calibration Procedure Accuracy and Precision Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course General Measurement Device and Calibration Topics 1
G PMEL (Precision Measurement Equipment Laboratory) Calibration Course Professional Certifications and Degrees 10
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
