Jake with the Calipers
Long time lurker, first time poster, hoping someone can set me straight on on setting up SPC to reflect our process accurately.
We are currently using Mitutoyo MeasurLink Realtime and I have two measurements on a part that I have been tasked with setting up an SPC program using standard deviation and I have kind of hit a wall and I am not sure if it is limitations in our software or a lack of knowledge on my part, quite possibly both.
For a bit of background on this part we have always ran higher than nominal on these two dimensions to mitigate any potential issues with a mating part (that we do not manufacture). This is a deliberate decision to help avoid a misfire/mismatch.
As I understand it although our spread is tight (good Cp and Pp values) since we target above center of the tolerance zone our Cpk is going to suffer and not accurately reflect our decision of running the parts higher than average. The typical answer would be make the parts closer to the middle of the tolerance zone to improve Cpk but we really want to remain above that center to avoid any chance of a functional failure. Currently my Cpk for these features is floating around 1.0, would love to get above that magical 1.33 barrier ...
Tolerances:
Feature 1: 0.083" +/- .003" ..... we target/average about 0.0852"
Feature 2: 0.410" +/- .003" ..... we target/average about 0.4124"
In our SPC software I have the shifted our target to 0.0852" and 0.4124" for those features while keeping the LTL and UTL as defined by the print and that seems to have helped slightly but I still don't believe it accurately reflects our process. What should my next steps be, if any, to get a Cpk that better reflects our intentions? Do I need to adjust or shift my LTL and UTL? Or do we need to use a different metric for proving our stability?
I would attach some data but I appear unable to do so as a new user.
Tolerances:
