How can I die cut foam - I'm thinking of a simple hand machine?
harry
#11
...................Yes Mould and Die. In the USA it written as "Mold and Die." "Dye" in this combination is a misspelling.
Jim will correct me if I am wrong...:D
Stijloor.
I did the first editing of this thread's title and just to make sure that the word 'dye' is not wrong, I did some searches. This page of webster's dictionary seems to agree to it:
n. 1. Color produced by dyeing.
2. Material used for dyeing; a dyestuff.
1. Same as Die, a lot.
If you google 'dye cut', 'mold & dye' or 'dye cast', you'll find that they are very much in use. There are company names such as 'American Dye Casting'.
Whether it's wrong use of the word or not, it seems the use of this word is deeply entrenched and I conclude that the OP is not wrong to use this word.
#12
"Dye" in this sense is wrong. Stamping tools aren't "lots" so the association you posted isn't relevant. (See the first definition here.)
In a brief bit of Googling, I saw no direct references to companies use the "dye" spelling in their names. Try a ThomasNet search and see if you come up with any tool companies with the word "dye" in their names.
harry
#13
I agree with you. As I said, whether it's wrong use (or wrong interpretation) of the word or not the use of this word is quite deeply entrenched - just use the key words that I used/suggested to 'google' and you'll see it.
#14
Harry, the interwebs are full of misspelled words. The fact that you can find the word misspelled many times in a Google search is not an indication that the usage is "entrenched"; it's an indication that there are lots of poor spellers out there.
harry
#15
Sure, wrong use doesn't legitimized it. In this case, both words are commonly pronounced in the same way.
somashekar Adhesive Seepage from Die Cut Parts Edge Manufacturing and Related Processes 13
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z Stamping Press Die Specification Manufacturing and Related Processes 2
Hershal 19 "Hot Shots" Fire Fighters Die fighting Arizona Fire World News 1
V When to Notify Customer about Die Modification APQP and PPAP 4
V Query on TS 16949:2009 Certification for a Tool and Die Sales & Service office IATF 16949 - Automotive Quality Systems Standard 3
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
V PPAP 7 of 8 Cavities after an injection mold die repair? APQP and PPAP 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Causes of Porosity of Die-Castings and How to Improve Die-Casting Manufacturing and Related Processes 10
A Tool and Die Manufacturing Job Progress Tracking Tools / Spread Sheets Manufacturing and Related Processes 7
A Powder Coating Chipping for Aluminum Die Casting Parts Supplier Quality Assurance and other Supplier Issues 11
T PFMEA of Die casting Process--Help needed? FMEA and Control Plans 5
S "Acceptable" PPM Level for Aluminum Die Casting Benchmarking 3
A Seeking a Die Casting Supplier in China - Guangdong, Zhejiang and Jiangsu Supplier Quality Assurance and other Supplier Issues 6
A Helical Cooling for Aluminium Die Casting Dies Information wanted Manufacturing and Related Processes 3
A Aluminium Die Casting DFMEA example wanted FMEA and Control Plans 6
N In Process Control checksheet for Die Cutting (eg. carton) Document Control Systems, Procedures, Forms and Templates 2
J Salt Spray Test on 3 year old Zinc Die Casting Chromed part per ASTM B 117-03 Manufacturing and Related Processes 2
T How can I streamline a corrugating firm especially in tool and die making Manufacturing and Related Processes 4
L Work Instructions for One Time Tool Build - Tool and Die Shop Manufacturing and Related Processes 6
P Variables Gage R&R study for 8 Cavities tool - Die casting industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
P Generic Label Die Cutting Process flow Manufacturing and Related Processes 5
T Die Cutter for Kevlar Fabric Manufacturing and Related Processes 10
B Electronics Die Component - Military Standard 883 vs. MIL STD 750 TM2010 B. Various Other Specifications, Standards, and related Requirements 4
A Process or Work Instruction (WI) to Change a Progressive Stamping Die Manufacturing and Related Processes 2
W How can I deterime the load of the DCM? Die cast machine loading Lean in Manufacturing and Service Industries 4
J New at aluminium die casting process (injection, trimming, spc, finish, defects) Manufacturing and Related Processes 3
B Can a Die Machine & Repair Shop be Certified to TS16949? IATF 16949 - Automotive Quality Systems Standard 1
M Melt flow tests using a "half die" Any suggestions? Plastic pellets Manufacturing and Related Processes 2
M Casting defect in brass gravity die casting - Manufacturer of taps, faucets Manufacturing and Related Processes 5
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
D Single Minute Exchange of Die - Preparing to launch a SMED project Manufacturing and Related Processes 14
P Die (Press Tool) Manufacturing Process Key Indicators (KPI) Manufacturing and Related Processes 5
A Quality Initiatives Die Out - What Can We Do to keep Them Going? Misc. Quality Assurance and Business Systems Related Topics 10
M Tooling management - Drawing change control for tool and die drawings IATF 16949 - Automotive Quality Systems Standard 1
DuncanGibbons How are part cut out specimens made and tested? Manufacturing and Related Processes 1
J Painted cut threads - ASME Pipe Suppliers Manufacturing and Related Processes 6
Hershal Fire disaster in Southern California (Blue Cut fire) - August 2016 Coffee Break and Water Cooler Discussions 22
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
Jim Wynne Measure Twice, Cut Once: The French Railroad Snafu World News 18
Y How to cut off Extremely High and Low Data Statistical Analysis Tools, Techniques and SPC 2
Q Do cut-in ECOs trigger "control of nonconforming product" procedure? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
AnaMariaVR2 Lazy Lawn Mowing (Lazy Way to Cut the Grass!) Funny Stuff - Jokes and Humour 5
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
