How can I help my calibration suppliers?
Diana Cadwalader
:confused: I am in a bit of a jam. My company is ISO/TS16949. Under this certification, our calibration suppliers must be 17025 certified. Not all of my suppliers are and now we absolutely MUST start re-sourcing them if we are to maintain our own certification. One of my suppliers is a scale calibrator for our scales we use to weigh count our product. We have been with them since the beginning and do not want to lose them. They are not certified but would like to be. THey have all of their documentation, they have done internal audits, etc. but are being told that the process for registration takes a minimum of five months. Is this normal for this standard???
I have also been told that one supplier got certified and was then told by their customer that the registrar was not acceptable or qualified. Is there a list of approved registrars?
In addition, I would like to be able to post information on our supplier web for these suppliers so that they can more quickly understand the standard and get their certification. I am new in this area, so any guidance is so appreciated.
D.Scott
16949 - 7.6.3.2 gives an option to accreditation to ISO/IEC 17025. You could provide evidence that the external lab (scale company) is acceptable to the customer.
Note 1 allows that such evidence may be demonstrated by customer assessment, for example, or by a customer-approved second-party assessment (2pCP) that the lab meets the intent of 17025 or national equivalent.
The 5 months quoted is probably because of backlog for the registrar in completing the audit. Once a lab is audited and recommended for certification, the actual process usually takes about 3-4 weeks. Availability of auditors is usually the big holdup.
I would suggest you contact the AIAG for a list of approved AIAG/PRI 2nd Party (2pCP) auditors and see if your suppliers can go that route. It was set up by the Big 3 as a reasonably low-cost approval program to allow smaller labs to meet Note 1.
The following link is still active although it specifically states "QS-9000". I am making an assumption that it is either still active or a similar one must be available for 16949. The page lists the "customer approved" second parties to meet the alternative "approval". It also lists the "approved" certification bodies for 17025.
I hope this helps a bit.
Dave
Diana Cadwalader
17025 requirement for suppliers
Thank you for your reply.
I missed the link somehow. Will ALL customers accept a letter of compliance from one of the second party approved?
In addition, we are using the scales for weigh counting end product and they do not really impact the quality of the product we are producing. Could we exempt them from the requirement for 17025 if they have all the traceability, etc on the certs that they provide to us?
D.Scott
The 2pCP program is an AIAG program specifically to address the alternative approval by the customer. All of the Big 3 have stated it is acceptable (I have no documentation of that - maybe try AIAG).
I would have thought the quantity of the product would have a direct impact on the packaging requirements of the customer which would impact quality. That is, of course, just my opinion. The standard states that you must determine the measuring devices needed to provide evidence of conformity to requirements. If there is no requirement to how many parts you package then you may not need to identify scales as such a device. If it isn't important though, why do you care about the count now?
One solution could be to have the scale company provide you with a set of calibrated transfer standards and you could then do your own "verification". The scale company would still do whatever they do under your maintenance agreement. If one of the scales was found to be beyond a given tolerance, it could then be taken by the scale company and replaced, fixed, or whatever. You, technically, wouldn't care if the scale itself was calibrated because you are using the transfer standard weights to verify the scale is suitable for your use. A similarity would be if you needed a certain amount of light, you could use any light bulb. The light meter (transfer standard) is what would need to be calibrated.
The point being made here is that if you do your own verification using transfer weights that are traceable to a national standard (copy given to you of the certificate provided to the scale company from the state or where ever they have their weights checked), there would be no requirement for the scale (Maintenance) company to be certified to 17025. You would be responsible for the "calibration/verification" and would have to conform to the requirements of 7.6.3.1 (internal labs). If the scale company does the calibration, they must be accredited.
Dave
Hershal
Metrologist-Auditor
Yes, there is a list.....
http://www.ilac.org
http://www.aplac.org
http://www.nacla.net
To boil down the list somewhat, there are currently five internationally recognized bodies that do or can operate in the U.S.: IAS, A2LA, NVLAP, L-A-B, and SCC/CLAS. Any of these bodies should be accepted.
One other potential is one I call "creative financing" that being a - collaboration - of the lab and the customer who needs/wants their services.....
Hershal
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
M Help with uncertainty calculation in the calibration of a Pyrogen Test Processor Measurement Uncertainty (MU) 7
E Help me with Surface Plate Calibration General Measurement Device and Calibration Topics 10
B Urgent Help With Calibration Issue AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Indysoft Calibration Software Thread Plug Template Help General Measurement Device and Calibration Topics 2
P HiPot Calibration help needed General Measurement Device and Calibration Topics 10
S Primary Temperature Standard to -65 degrees C - Calibration Help General Measurement Device and Calibration Topics 3
N Fluke 724 Calibration help needed General Measurement Device and Calibration Topics 8
S Ultrasonic Thickness Gauge / Step block - Calibration - help General Measurement Device and Calibration Topics 3
M Help writing a Radiometer Calibration Procedure General Measurement Device and Calibration Topics 3
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
M Source code and explanation for computer simulation in camera calibration, HELP Calibration and Metrology Software and Hardware 2
C CCT (Certified Calibration Technician) test - Is there somewhere I can get more help? Professional Certifications and Degrees 2
C Software Validation - GageTrak Calibration Software - Please Help Calibration and Metrology Software and Hardware 6
C Calibration process study help needed - Have I have selected a correct test design? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Outsourced Process - Calibration - HELP! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Senior Project Help - Setting up a calibration laboratory General Measurement Device and Calibration Topics 5
C Opening a new Calibration Laboratory - Need help General Measurement Device and Calibration Topics 8
A Help Locate Calibration Services in Thailand General Measurement Device and Calibration Topics 3
Q Help With Calibration of Software - Microcontroller firmware General Measurement Device and Calibration Topics 2
N Confused by calibration concepts - Seeking help with the basics General Measurement Device and Calibration Topics 9
C Help and Advice Requested: Calibration of Weight Sets General Measurement Device and Calibration Topics 3
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
