How Can I Prevent A Labeling Error?
Ninja
Looking for Reality
#11
Are you talking about the shipping labels or the temp labels?
I figure this is what Jim meant...if not, it is what I mean...
Can production put the official shipping label on the container?
If it fails QC, put a REJECT label right across the shipping label.
Assuming it passes QC, no relabeling is required.
Why do it twice and run the risk of error if you can just do it the once?
If production knows enough to label with product, customer, qty, etc....why not just have them put the label on it and be done with it?
David-D
#13
I'd agree with the previous poster who suggested moving it upstream to minimize opportunities for error but I'd add a bit more.
First, I'd suggest combining the two labels (product information and shipping information) as one and installing them early (at/before filling); the label couldeven include barcoding to confirm weights, material, etc at time of filling or to give tradability during movement, release, shipping, etc.
I think having QC put a label on it to reject and otherwise assuming it is good is a high risk. Any bypassing of QC could accidentally get uninspected or nonconforming material to be accidentally released/shipped. There is the same issue if it potentially is accidentally removed. Instead, I'd put a large area on the base label stating that it is NOT released for shipment. When it finally is approved by QC they then paste an approved label over the message obliterating/obscuring it only once it is approved for release. Alteratively, you could otherwise remove/obliterate the part that says don't release but it is probably nicer to explicitly label that the product is good.
This will be a bit more intensive but should be morr mistake proof. Hopefully, it could also be directly integrated with the ordering system to generate/populate/create the labels. The incorporation of barcodes (1 or 2D) will also help for tracking now or in the the future depending on your current capabilities of your systems and potentially add further protection and value.
As an aside, you also might consider in the long run looking at some of the current inkjet type printing capabilities now available to automatically mark/label the containers; there seems to be some pretty good capabilities out there now.
David
Wes Bucey
Prophet of Profit
#14
I would have to observe the process from raw material to shipping dock to be certain, but my past experience tells me there are several options to mistake proof the process of labeling. First, and foremost, of course, is to understand the problem is with the process, NOT WITH THE INDIVIDUAL APPLYING THE LABEL! (the comment "Recently we had another issue where she switched up the packing slip documents between two other shipments." means the company is aiming at the employee, NOT the process.")
NOTE the sample label mentioned does not seem to be attached.
I presume, from the OP description, the REAL packaging of product is done in flexible plastic bags which are then inserted in sturdy plastic cartons to protect them from damage during shipping and storage. It appears that labels need to be affixed to the plastic bags first, then to the outer container.
POSSIBLE ROUTE TO CONSIDER:
Sometimes, management and employees are so indoctrinated into a current system they simply can't envision another process to incorporate mistake proofing measures. In such cases, it may be worthwhile to bring in an "expert from afar" to look at the process with new eyes. There are a number of sources of such experts ranging from independent consultants to label company staffers who can provide this expertise.
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
L Procedure to Prevent Corruption Misc. Quality Assurance and Business Systems Related Topics 24
E EN/UL/CSA 61010 -1 (ed3) Safety and use of Software to Prevent Electrical Hazard CE Marking (Conformité Européene) / CB Scheme 3
Z PFMEA Detection Controls and Ranking - Prevent Shipment FMEA and Control Plans 3
Stijloor Woodpeckers!!! How do we prevent woodpeckers from causing damage? Coffee Break and Water Cooler Discussions 46
T How to Prevent Misidentified Product Manufacturing and Related Processes 5
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
S How to Communicate with Production People to Prevent Quality Arguments Quality Manager and Management Related Issues 21
P How to prevent the LED wrong polarity when insertion on the production line? Problem Solving, Root Cause Fault and Failure Analysis 8
G "Prevent Pollution" element of Policy Statement Miscellaneous Environmental Standards and EMS Related Discussions 6
Q Completing 8D in the section "System Prevention Action To Prevent Recurrence" Customer Complaints 10
P Prevent Occurrence of Nonconformance: Its implementation effectiveness Preventive Action and Continuous Improvement 20
G Idea To Prevent Mix-up of Medical gases Preventive Action and Continuous Improvement 7
R Corrective Action Does Not Prevent Reocurrence! Nonconformance and Corrective Action 25
D D7 Prevent Recurrence vs. TS 16949 8.5.3 Preventive Action Nonconformance and Corrective Action 2
Wes Bucey Some companies "muzzle" employees to prevent them talking to press Philosophy, Gurus, Innovation and Evolution 7
J 8-D for mislabels - How to prevent, or at least detect, mislabels Nonconformance and Corrective Action 4
A How to Prevent External Thread Damage? Manufacturing and Related Processes 8
D Defect Prevention - We first have to observe a defect before we can prevent? Nonconformance and Corrective Action 10
S Setting FMEA Scope - Trying to prevent infant mortality rate FMEA and Control Plans 1
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 1
D Hazard symbols and labeling ISO 13485:2016 - Medical Device Quality Management Systems 1
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
D Labeling requirements for reagents, etc ISO 13485:2016 - Medical Device Quality Management Systems 4
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
L Medical-grade power adapter labeling Other US Medical Device Regulations 2
Y Labeling difference for storage and operating conditions EU Medical Device Regulations 1
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
K China Medical Device Labeling requirements - Language China Medical Device Regulations 3
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
JoCam Labeling to Customer Requirements EU Medical Device Regulations 1
Z Labeling for Medical Device Samples - Surgical instruments 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
D Do User Manuals (Not Device Labeling) HAVE to be in their national languages for these countries? Will English Hardcopy not do? EU Medical Device Regulations 12
S How to decide which medical device symbols go on label and labeling? US Food and Drug Administration (FDA) 5
M MDR Legacy Medical Device Labeling compliance timeline EU Medical Device Regulations 3
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Labeling for off-label use - Prevention of off-label use of a medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
P UDI labeling for power module IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Labeling - 2017/745 - EUMDR Requirements and Trademark Issues EU Medical Device Regulations 0
DitchDigger UDI, Labeling Accessories, General Insanity, Etc. US Food and Drug Administration (FDA) 1
K Labeling requirements - Date of manufacture for software devices EU Medical Device Regulations 5
E Annotated US Prescribing Labeling US Food and Drug Administration (FDA) 0
