How Can I Simplify This Process Flow?
NikkiQSM
Hello Covers,
I wanted to ask for your thoughts on how to simplify our Order Tracker Process... What it comes down to is that the Order Tracker is passed through so MANY hands before the job ships out. Sometimes it is even passed back to the same person a number of times. We have used this process for many years, but after our Management Council Meeting yesterday, I felt I could get some good advice from the knowledgable covers here.
A Little background, we are a medical plastics compounder, and we are ISO 9001:2008 certified. Basically, we produce the plastic pellets that medical device manufacturers use to make their devices.
The Order Tracker contains a cover sheet, which has spaces for each person to sign off as they get the Order Tracker. It also contains a New Order Form, Formula Sheet (recipe for the compound) and process sheet (how to extrude the material).
Here is the process:
#1. Customer Service takes an order from the customer and fills out the New Order Form.
#2. The New Order Form is given to Scheduling who verfies that we have the materials here to run the job, and if need be orders more materials.
#3. The Order Tracker documents are printed off, The New Order Form is put in with this packet and is given to Process Engineer to review the process for acceptance.
#4. The Order Tracker is given back to Scheduling, who schedules the job.
#5. The Order Tracker is given to Production and they produce the job as the formula / process sheets instruct.
#6. The Tracker goes to QC, where the QC RESULTS documents are added.
#7. The Tracker is given to the QC Manager who reviews all the documents to ensure that we made the product as requested by the customer.
#8. The Tracker is given to Logistics to arrange shipping.
#9. The Tracker is given back to the QC Manager to review the labels and packaging and ensure they are correct.
#10. The Tracker is given to Customer Service so that they can inform the customer that it is shipping.
#11. The Tracker is passed on to the Quality System Manager to record ship dates for tracking on-time delivery.
#12. The Tracker is passed down to the office assistant to scan the Order Tracker into our system.
#13. The Tracker is passed onto the Assistant Production Corrdinator to deduct the materials used in inventory.
#14. The Tracker is given to HR for invoicing.
#15. The Tracker is given back to the office assistant to file.
While all these steps seem necessary - I feel it is going through too many hands...
Any and all thoughts are appreciated.
Best Regards,
Ninja
Looking for Reality
Lots of the right hands, but the floor map goes in circles...
Some initial thoughts:
Hello Covers,
#3. The New Order Form is given to Scheduling who verfies that we have the materials here to run the job, and if need be orders more materials.
#2. The Order Tracker documents are printed off, The New Order Form is put in with this packet and is given to Process Engineer to review the process for acceptance.
#4. The Order Tracker stays in Scheduling, who schedules the job.
#9. The Tracker stays in Logistics who prints the labels and packaging and ensure they are correct.
#10. A memo is given to Customer Service so that they can inform the customer that it is shipping.
#11. Shipping/Logistics inputs the ship dates for tracking on-time delivery.
#4a. The Tracker is passed down to the office assistant to scan the Order Tracker into our system. (combine this with #4 above, why not just print to pdf when the initial print takes place?)
#13. Production should have done this already back in #5.
Best Regards,
Again...just initial thoughts...
HTH
CS - Engineering approval - Scheduling - Production - QC - Logistics - Bill it out
A stray thought...does every single job need engineering approval? Is every job so very unique?
NikkiQSM
Yes. Every single one of the jobs gets reviewed. Before AND after production in case adjustments had to made to the process.
Each product we produce is very unique and different - basically a job shop we are - if only we just made rubber duckies everyday :)
Mazoku
You might benefit from Job Shop Software such as JobBoss or Jobscope. having everything electronic helps speed the processes. Scheduling would not have to manually check for availability of materials, required documents can be better managed and controlled and your QC manager would not need to review each time for correct documentation. Ship dates, invoicing, customer contact info, logistics, filing, tracking delivery, etc. can all be handled by the software.
As for unneeded steps, I don't see the purpose of having the QC manager inspect the labeling and packaging of the products. Create an easy to follow shipping flowchart or checklist to assure that labeling and packaging is done correctly every time and there is no need for inspection by the QC manager. Same goes for inspecting the tracker for correct documents. Someone once told me "quality by inspection is not quality." Also, tracking ship dates can be done by anyone, whoever first received the ship dates can log it in a database and the QC manager can review at his own convenience.
Bill McNeese
I would imagine that the actual process is more complicated once you add in the steps when something isn't correct - what happens then? who gets involved? Good suggestions here on improvement.
But I think those closest to the process would have great ideas on what to do I would suggest pulling together the people who do the process and construct a detailed process flow diagram - with all the rework included when things aren't correct. Some immediate things will be obvious most likely to improve the process. You can get as fancy as you want and add how log each times takes.
You can also rate each step as the following:
  • A step that actually creates value from the perspective of the customer.
  • A step that creates no value but is currently required by the product development, order filling or production systems (type one muda) and cannot be currently be eliminated.
  • A step that creates no value and can be eliminated immediately (type two muda).
Michael_M
Can you combine some of the steps. For example, #6, #7, #9, and #11 all seem to be QC. Can the arrangement be made to go:
#6, #7, #9, and #11 all at the same time (one step).
Can #13 be combined with #4 at #4 (deduct the material before use)
John Broomfield
Hello Covers,
Best Regards,
Nikki,
This looks like a jobs preservation process! Does your company use QuickBooks for its accounting?
If so you can interface with Fishbowl order processing and inventory management software:
http://www.softwareadvice.com/scm/fishbowl-inventory-scm-profile/
If not QB then select software according to your accounting software.
Best to engage those involved in the improvement project though.
Best wishes,
John
Bhooshan Karandikar
Apart from Michael_M's suggestions, other possibilities seem to be:
& then #2 combined with #4
Also # 12 may be combined with #15
L
lokeky1
The order tracker is used to track which process the job is at presently. To streamline the order tracker is therefore identical to streamlining the entire operation (door to door).
To streamline the door to door operation, follow the suggestions by the Womack et al. Do VSM first. Identify value etc....
M Hundreds of Processes! How to simplify ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Chennaiite Chaos --> Bird's eye view, simplify & visualize Coffee Break and Water Cooler Discussions 0
C Change Management - How can we simplify and reduce our QMS? Misc. Quality Assurance and Business Systems Related Topics 1
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 7
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C OEE and In-process Inspection Manufacturing and Related Processes 2
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I Release checklist EO sterilization process Medical Device and FDA Regulations and Standards News 3
V Informational SMMT IATF Oversight - OEM KPI Process IATF 16949 - Automotive Quality Systems Standard 4
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
D Social Media Feedback process for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 6
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
B Supplier of design and manufacture process ISO 13485:2016 - Medical Device Quality Management Systems 10
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Pmarszal External Standards and Regulations Management Process Document Control Systems, Procedures, Forms and Templates 10
A Design process goal for ISO 9001 Manufacturing and Related Processes 23
S Process Map for Supplier Process Maps, Process Mapping and Turtle Diagrams 5
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Procedure equals a process? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Changes in process dispersion, and location hypotheses tests Using Minitab Software 3
M Process Creation Advice Needed Design and Development of Products and Processes 3
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
H Human Resources Process Document Control Systems, Procedures, Forms and Templates 2
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
J Powered wheelchairs (Class IIa) in the process of CE marking and use in hospitals CE Marking (Conformité Européene) / CB Scheme 4
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
