Y
I'm now in the midst of setting up MSA for the company. I've encountered several equipments which i think i may need some inputs frm the member.
1) The laboratory has burettes to measure the concentrate of the chemical. The usage of the burette is to drop certain acid onto a chemical solution. Once the color changes, the lab assistant will stop the procedure and calculate the amount of acid used. This will determine the chemical concentrate.
2) There's this jig to measure the viscosity of the chemical. The procedure is to pour the chemical into the jig. Once it is full, the lab assistant will release the chemical via a tiny pin-hole. At the same time he will start the stop watch. Once the steady flow discontinue, he will stop the watch and determine the time. This will be used to calculate the viscosity.
Can we measure the MSA for these equipments ?? Thanks
